1 - 1 of 1 Posts
I swapped a 2j from an aristo in my is and I used the stock twins everything stock from the jdm motor but I am using the body harness from the is I have it running but it’s running rough I found that the coil pack that fires cylinder 2 and 5 isn’t getting proper spark it seems it’s getting one big spark when I crank it but once it starts it’s as if it’s not even working you can unplug the plug wire over cylinder 5 and it won’t change the way it runs it also won’t rev at all any help would be much appreciated thanks.
1 - 1 of 1 Posts
