This is just a summary of all the previous posts (sorry its so Long) if I've missed something, please add:
Summary List of Early build Flaws
6MT
1. Popping out of gear (mostly 1st) (some replaced 1st gear, main and counter shaft)
2. Difficulty getting tranny into 2nd and 4th gears
5AT/NAV and 6MT
1. Vibrations at 35 and 55
2. Memory in Seats lost for no apparent reason
3. software upgrade for misfires instead of coil pack replacement
4. Glove box rattle, warped or misaligned.
5. Re-calibrated Crankshaft position sensor
6. stuck thermostat valve
7. Hood misaligned
8. trim areas not flush
9. door handle inserts missing
10. rattle in sun visor housing when open or closed
11. ‘headliner’ not flush with trim
12. ‘parcel tray’ rattle with loud music near subwoofer (never heard it called the parcel tray)
13. ‘click’ when applying brakes (hear this in other Hondas)
14. Plastic ‘wiper’ inside door frame scratches tinted windows (need felt)
15. Sulfur or rotten egg smell with hard acceleration
16. Steering wheel alignment off on delivery and also after delivery and driving
17. MID flashing at high RPMs
18. Butt wrinkle/padding in seats
19. Miles to empty not accurate in MID – possibly gas guage not accurate (fewer posts on this)
20. Engine shifting to overdrive too soon for engine speed
21. Parking brake out of adjustment – too loose (car uses gear instead of the e-brake=parking brake) up or down hill.
22. Carpet out of drivers door trim
23. A-piller sticking out from trim/buckling/bubling
24. Center dash speaker cover rattle
25. Other isolated trim issues (one time occurances)
26. Rear quarter panel where window meets trunk – WELD Mark
27. Driver side wind noise
28. NO Heat (mentioned twice)
29. Outside temp read off
Below is an early list in the thread (many similar to above);
1. Headliner on drivers side is in contact with windshield so it clicks over bumps (2 known cases) – Dealer found broken mounting clips, repaired other case was fixed with felt
2. Drivers door leather was not tucked in near aluminum trim, reinserted it.
3. Steering wheel is off to right, car tracks straight, wheel needs adjustment, dealer did not fix.
4. Parking brake is out of adjustment, have to pull to top to get it to not rely on transmission. Dealer repaired, but within 2 days out of adjustment again, need to re-adjust, especially noticeable on a downhill incline.
5. Outside temperature reading in MID is about 8 degrees high (even after driving), after dealer fix, now 7 degrees off.
6. Driver’s window vibrates at top when fully closed (if down slightly, it is ok). Dealer adjusted window regulator (others have complained about this)
7. About 8 paint defects (small, very small imperfections, such as particles or dust under clear coat) and one scratch near lower black grill near center of car.
8. Rear deck rattled (many complaints of this) with radio on – fixed with foam at center of deck where it meets rear window as it was vibrating against window.
9. Gaps inconsistent in hood to fender fit, both sides, and drivers front fender to headlight. Also, plastic rocker molding on drivers side was about ½” in behind front wheel
10. Leather wrinkles on lower seat bolster in outboard position (not only one to indicate this) – regional says this is normal. Treated the leather this last weekend.
11. Butt print on seat bottom (many complaints)
12. Vibration in car at different speeds (not only one to complain) – dealer rebalanced tires, better, but regional said with these low profile tires, when cold, they are slightly out of round, and when heated, it will go away (I have seen this also, and there was another post on this. Not sure if tranny related.
13. Glove box rattled (other complaints on this also) – dealer moved striker in
14. Memory seat setting disappeared (other complaint about this also)
15. Pass front door rattles occasionally (other complaints) – not found
16. Third brake light cover was loose, rattled with bass and also allowed red light to shine on inside of rear C pillars – dealer repaired.
17. Fuel gauge slightly off, at ¼ takes 10 gallons, 7 gal left.
18 Car up shifts way too early, at steady cruse (not pushing it) it is in 4th just shy of 30mph and 5th just shy of 45mph, makes cruising at these speeds full of vibration as engine lugs as it is not turning enough rpms.
19. Part of back edge of star portion of wheel/rim is not smooth, was not sanded/finished properly, also one is not painted on center hub portion (can not see unless you look inside where it mates to rotor.
20. One exhaust tip has a large silver weld exposed inside tip, visible from rear of car.
21. Noise when pulling away when car is cold and normal acceleration, sounds like a flap is being actuated, but felt throughout car, lasts less than a second (other complaint on this) – dealer did not find.
BTW, trannies are going on the manaul TSXs and TLs and a couple of automatic TLs already:egads:
No car is perfect but this is as ridiculous as the last model.
