When you sat dead. You mean no power at all or just engine died?
No power at allWhen you sat dead. You mean no power at all or just engine died?
Yes I did think of that but haven't had time to check... I did drop the trans a little while ago im hoping I didn't tighten the ground enough and screw backed out ...check your grounding. If you don't have proper connection on your grounding, it will cut out all power.
