2004 IS300 8N6 - JZX110 R154 manual swapped with driftmotion 19lb flywheel, action stage 3 sprung 6 puck disc, and driftmotion driveshaft - F&F type 2 Coilovers, Eibach sway bars, Full Godspeed rear arm set, Adjustable front upper control arm, Lexibreak steering knuckles + rca kit + rack spacers, Battery relocated to trunk, ABS relocation, Xcessive poly engine mounts, driftmotion trans cross member and poly trans mount, cubespeed JZX110 shifter, FR-S LSD swap, Aftermarket HID's and LED Tail lights, Trunk strut mod, kenwood speakers all around, incl. tweeters, infinity 12" shallow mount subwoofer with infinite baffle, pioneer 5 channel amp, external TPMS system, Atoto S8 3gb/32gb Android stereo, TURBOCHARGED with CX Racing manifold, downpipe, and intercooler setup, Garrett T04S 60-1 turbo, Tial 50mm BOV, Turbosmart hypergate 45mm gen 4 wastegate and FIC 6 piggyback. FMS 550cc pnp injectors. Manual ECU swapped.
Alex's 2004 8N6 IS300 NA-T build
