1 - 1 of 1 Posts
Hi guys! Those of you who have done an Aristo swap using the TT 4spd auto into a 02-05 IS/GS300, how did you wire the ECU input pins for A/T Indicator P and R gear?
On the 01/Aristo harness, P and R gears are on the body plugs going into the ECU. On the 02+ harness, they are on the engine plugs going into the ECU. Not sure why Toyota would make a switch like this, but using Aristo everything (ecu, tranny, harness) means I need to get the P and R signal from somewhere.
1 - 1 of 1 Posts
