I got busy at the end of the year with activities and travel. I was able to install a fumoto valve in the oil pan. I don't really like how it sticks out.
I've dropped that tire off track a few times; all it would take is a rock to break it off. I'm thinking about adding a front skid plate to protect the oil pan and valve and a mid-skid plate to protect the headers. I procrastinated on solving the injector issue because I didn't really want to drop a ton of cash buying new ones. I ended up taking them back to the place that cleaned and tested them. I was told they need to be installed and used immediately after testing. I waited around 10 months to use them so I bought that they had just got gunked up from sitting. I had them recleaned and tested. It was covered under their warranty so it was hard to not do. They found and fixed the stuck injector, also a few others were dripping.
I felt good about reinstalling them and getting back on track. I also cleaned the fuel rail and replaced the fuel damper. It was a little dirty so I thought that could have led to some of the issues.
Yesterday I got oil back in the motor and reinstalled the fuel rail. I also put in new spark plugs and leads. I started it again and ran it for like 30 seconds. It fired right up and sounded really good. I looked under the car and saw these wet spots.
I kinda thought it was just some moisture or something. I went to start it back up so I could drive it back into the garage and it immediately locked up. I knew enough from the last few times that when the dash went dark from the extra power draw of the starter I stopped cranking it. I took out the spark plugs and found cylinders 6 and 7 had a lot of fuel in them.
It's worth noting the injector that failed last time was in cylinder 4. So basically 3/8 of the injectors have failed open. If it weren't my money I would have replaced all the injectors the last time this happened. Now I don't think I have an option. I consider myself fairly risk averse and I think all these injectors need thrown out. I'd imagine they are an extremely reliable mechanism but this set must have had some damage done to them. Monday I will look into buying some new injectors. Unfortunately I believe that also means I need a new base tune. The stock AC Delco injectors are like $140 per. There are cheaper options but I may go with some from the company that cleaned my injectors. I did drain my oil again and it didn't seem like any fuel really got into it. It's amazing how long it takes to drain 8.5qts of oil. I'd imagine the trap doors in the oil pan slow it down but it takes like an hour. I'm gonna reflush the oil cooler lines too. Fortunately I planned for failure and had the accusump closed off so fuel couldn't get into it. I also looked into the fuel gauge reading empty. Turns out my fuel tank is just empty.
I did my due diligence and checked the resistance of the sensor. I also disconnected the fuel pump, plugged it in and checked the gauge was working. It seems fine. Now I just need to get a gas can so I can fill it up. Probably should have done that when I had it on a trailer.
