01 IS300 LS1 Drift Build
12100 Views 181 Replies 12 Participants Last post by  Rigel
10
I bought a 01 IS300 with 180k miles two years ago to use as a drift car.
Automotive parking light Car Vehicle Automotive side-view mirror Automotive side marker light
I manual swapped it with an AR5 a few months after buying it.
Tire Motor vehicle Hood Automotive tire Automotive design
In the front I have extended lower control arms, cut spindle, and I designed and machined a new lower ball joint/tie rod pickup for more angle.
Hood Automotive tire Automotive lighting Automotive design Bumper
Tire Automotive lighting Automotive tire Bicycle tire Tread
I have BV toe and traction links in the rear as well as a welded diff. I also got an Apex exhaust and coil overs and have lowered it a bit. I’ve done some events and practice days with it and so far it has been flawless besides the harmonic balancer pully flying off at my last practice.
Tire Wheel Car Automotive side marker light Automotive parking light
Motor vehicle Automotive tire Automotive design Automotive wheel system Automotive exterior
In April I got a 36k mile LS1 from a 02 Pontiac Firebird at a price I couldn’t refuse. My goal for the motor is to keep it stock for now but do all the reliability mods for drifting. I will also be using the AR5 I already have as there was a pretty simple adapter kit from Fabbot. I will be using a LS7 flywheel and clutch, as they work with the trans adapter kit. My engine came with an auto trans so I just needed the bell housing from that. I bought a Canton drift oil pan, trunnion upgrade, valve springs, lifters and a harmonic balancer. I also decided to replace all the seals, the motor has been sitting for almost 16 years.
About a month ago I started working on the engine and intended to swap it over Christmas. Once I removed the valley cover I saw the motor was full of sludge.
I am guessing the oil had been changed once at most in its short life. Wear looked minimal but there was sludge everywhere.
Automotive tire Automotive lighting Vehicle Bumper Auto part
I ended up tearing it completely down and sent it out to get cleaned. I am still waiting for the shop to get it back to me so I can start rebuilding it.
Automotive tire Motor vehicle Tire Rim Bumper
Motor vehicle Gas Engineering Machine Automotive exterior
Picture frame Interior design Gas Engineering Machine
See less See more
Reactions: 1
41 - 60 of 182 Posts
4
Are you going to use the stock GM hydraulic TOB or an aftermarket one like Tilton? I think I’m going to go twin disk clutch since I have my engine out. The Tilton looks like it’ll bolt right up to the AR5 front bearing retainer to me.
I am using the stock GM TOB with a LS7 clutch and flywheel. I don’t see why a Tilton wouldn’t work if it in the same mounting pattern as the GM.
Motor vehicle Engineering Rim Machine Auto part
Automotive tire Rim Motor vehicle Automotive wheel system Auto part
I haven’t really thought about an electric rack. I was thinking the electric pump because it would save me time vs mounting a belt driven one. Also I can package it better. I think the electric rack will be more work than the electric pump at this point and I want to limit scope creep on this project. I think when this motor is in and working I might start looking for a rack. It would allow me to mess with the steering geometry which might be nice.
Funny enough I helped my dad swap an electric steering box on his 28 Model A. It was a little different setup but it was super easy to install once I came up with a mount for it.
Motor vehicle Hood Vehicle Automotive lighting Automotive design
Motor vehicle Hood Automotive design Automotive exterior Rim
See less See more
Reactions: 1
Yep, I looked at the Tilton engineering plans for the clutch and did some measuring, it looks like it’ll work to me. I asked Tilton, but their engineer said they had not documented use of their HTOB with an AR5.
Looks like the FabBot AR5 - Ls adapter?
That HTOB you have is different than the Solstice one I have. The Solstice doesn’t have a bleeder, you have to vacuum bleed it. If it will fit, and I bet it will, I recommend getting a billet bearing spacer for that HTOB. It’s cheap insurance for if the plastic one shits the bed and ruins your day. Check it here.
Yeah I hear you on scope creep. I’ve got sidelined too many times by “while you’re in there”. That Model A looks pretty neat. You’ll have experience from that when/if you go electric rack on the IS.
Reactions: 1
Yes it is the Fabbot kit. I remember looking into the billet spacer but totally forgot about it. Thanks for the reminder. The TOB came with the kit and it looks like it's for a 1998-2002 F body LS1. Unfortunately their doesn't appear to be a billet spacer for that style TOB. I assume the different style TOB are interchangeable but I will have to find out for sure. It will take a few weeks to get the billet spacer anyways so I'm working on another option. I'd like to get the motor in this weekend
Reactions: 1
4
So I was unable to find a billet bearing support for my slave. After taking it apart I see why, the whole assembly is needlessly complicated. Regardless I decided to make my own.
Camera lens Camera accessory Gas Wood Auto part
I also reused the outer plastic retaining piece. It was way too much work for what it is but at least now it shouldn’t melt assuming all my bonds hold up. Two of the dark gray failed after an elevated cure so I added the lighter gray bond which should be a bit tougher. I’m not really sure how hot that area will get however at least there will no longer be a catastrophic failure if things get to hot, which they will. After getting the slave rebuilt I installed the lines and bell housing. I’m using a remote bleed line for the slave as I won’t have any access once I mate the trans. I am using an auto bell housing with no cutouts in it. I also had to adapt the -3 fitting on the slave to a -4 fitting on my clutch line hence the hardline.
Wheel Automotive tire Locking hubs Motor vehicle Automotive design
Vehicle Engineering Gas Motor vehicle Train
Today I got the starter, flywheel, and clutch on, it should be ready to install tomorrow. I just need to mate the trans and drop it all in. I also got the harness on the motor earlier this week. I need to rewire it and simplify but I want to get the motor running before I tear into it.
Wheel Tire Automotive tire Product Motor vehicle
See less See more
Reactions: 2
That’s bad ass machining your own billet bearing support!
Reactions: 1
Thanks I probably would have been better off buying a new slave but I didn't want to wait for shipping.
Reactions: 1
9
I got the engine in today. It only took around an hour and a half with 3 friends. It fits really well, probably better than the stock motor.
Motor vehicle Automotive tire Vehicle Mode of transport Automotive exterior
Motor vehicle Vehicle Gas Engineering Auto part
Car Vehicle Automotive tire Motor vehicle Hood
As a quick reminder it's a 02 LS1 from an f-body. I am using the ar5 I already had in the car with a Fabbot ar5 to LS conversion kit. That uses an auto 4l60e bell housing. I also used xcessive LS engine adapters with their is200 poly engine mounts. The mounts are slotted so that gave me some room for adjustment. I pushed the engine back as far as I could. There is about a .25"-.5" clearance between the oil pan and sub frame, that was my driving limit.
Hood Automotive tire Automotive lighting Grille Vehicle
The bell housing is 4"+ bigger than the r154 I had. I was worried I would need to clearance the trans tunnel as it isn't very big. However it ended up fitting fine. I can't quite fit my hand in the gap between the tunnel and bell housing but their is enough room everywhere. I have good access to all the bell housing bolts so hopefully clutches won't be to bad.
Hood Automotive tire Automotive lighting Motor vehicle Grey
Tire Hood Automotive tire Tread Motor vehicle
The trans ended up moving about 1.25" forward. I was able to rotate my trans mount 180 and all 4 holes lined up. It was not planned but I worked really well. The shifter sits a bit forward but it shouldn't be noticeable.
Automotive tire Motor vehicle Bumper Vehicle door Automotive exterior
Motor vehicle Automotive tire Automotive exterior Rim Gas
Instead of lengthening my driveshaft I think I will make a new tail shaft to driveshaft adapter that is a bit longer.
Black Fixture Window Automotive tire Gas
The last big fitment thing are headers but I am still waiting on them. I might try the stock ones I have now. I will have to move the ABS so I have more space to install them. Everything else fits really well and servicing the motor should be pretty easy. I highly recommend this swap so far. It seems like everything was meant to fit
See less See more
Reactions: 4
Nice, sits in there pretty snug!
4
Monday I started installing the clutch master cylinder. I got a land cruiser mc because I need a smaller bore. My previous mc had studs threaded into it where the land cruiser just has thru holes. I made some threaded inserts for it and gave the mc a spot face. With the inserts, the studs fit and I was able to get everything connected. I also ended up shortening the banjo bolt because it was too long.
Automotive tire Blue Light Automotive exhaust Vehicle brake
Today I got the Dedicated Motorsports headers.
Hand tool Bicycle part Table Tool Nickel
I am mixing and matching kits with the headers and xcessive engine mount. I was hoping to get lucky but unfortunately they don't fit. The xcessive motor mount sit the engine farther down and are biased a bit to the passenger side. The passenger side header hits the chassis at the caster arm mounting point. I think I can make enough clearance with a hammer without affecting the pickup point.
Hood Automotive tire Automotive lighting Automotive design Motor vehicle
The driver's side header hits the steering rack.
Musical instrument Guitar Automotive lighting Hood String instrument
I'm going to try to lift the motor a bit and put spacers under the engine mounts. I think if the motor were a 1/4" higher I could fit the steering rack. The steering shaft and joint will still need to fit through the header so hopefully there will be enough clearance. If that doesn't work I may have to get the headers modified to fit. I really like how the motor fits right now and I don't want to move it too much
See less See more
10
I lifted the engine up a bit and was able to get the driver’s side header to fit. I added about 0.8” of washers to the drivers engine mount.
Vehicle Automotive lighting Automotive tire Light Motor vehicle
Vehicle Car Grille Automotive lighting Automotive tire
I think I will need to raise the engine a full inch to provide proper clearance. On the driver side it’s not an issue. However the passenger side is a different story. There is a rib on the bell housing that hits the trans tunnel. I think I can just grind it down and it will clear. The other issue is the lower heater core hose hits the head. I think I can either bend or weld a 90 deg bend to clear the head. Unfortunately to do either I will have to remove the heater core which looks like a big job.
Automotive fuel system Automotive tire Automotive lighting Motor vehicle Vehicle
I ignored those issues and started working on the fuel lines. I printed new fuel line clips so I can add the extra hard line for the fuel return. I think they came out pretty well and look factory. I need to make a few adjustments but they are good enough for now.
Circuit component Automotive tire Audio equipment Electronic component Wood
Automotive tire Tool Gas Auto part Gear
Tire Automotive tire Tread Synthetic rubber Grey
I used 5/16” to -6 AN compression fittings to either end of the return hard line and the end of the supply line. I leaked checked one of the lines to 100 PSI and no leaks.
Watch Product Analog watch Automotive tire Gauge
I am using a Corvette fuel filter/pressure regulator, this simplifies the fuel lines. I mounted it under the pedals near the steering shaft. It was the only reasonable place I found to mount it. I will probably add a heat shield to protect it from the header. One tip I learned was get some very strong magnets. I had 2 16lb magnets I used to hold the regulator in place while I finalized the position and checked fitment.
Motor vehicle Black Hood Automotive design Automotive fuel system
I then added a rivnut and bolted it in.
Automotive tire Water Rim Vehicle Wood
I also made the regulator supply and return lines, EVAP line, and supply line to the fuel rail. I just need to make a return line to the fuel tank.
Motor vehicle Hood Automotive exterior Vehicle Auto part
See less See more
Reactions: 1
If I understand correctly in this picture your still using the evap solenoid leading to the charcoal filter. Are you also still using the purge valve that feeds the intake in the stock configuration?
I need to look at the evap system. Honestly I just did that cause it looked right. If it isn't to much work I will keep the whole EVAP system. I'm not sure the pros and cons of keeping or removing it.
I am in the process of doing the same on my 1J swap but my harness doesn't have the purge solenoid connecter. I might just remove it and run a straight line to the intake. I wasn't sure if that would cause any funky evap behavior. Thanks for the reply and sorry to hijack.
4
I posted the fuel line clips if anyone wants to print their own. I also got my fuel return line finished. I made a plug to replace the regulator.
Wood Tool Bicycle part Drill accessories Gas
Camera accessory Camera lens Cameras & optics Camera Lens
Then I added a bulkhead fitting to fuel pump and a line down to the hardline. Unfortunately the fitting is to tall and hit the cover. I need to get a 90 degree bulkhead fitting.
Automotive tire Motor vehicle Fluid Rim Automotive exterior
I also still need to add the internal fuel line.
I made the drive shaft adapter\extension and now the drive shaft fits.
Pipeline transport Automotive tire Water Asphalt Wood
See less See more
Reactions: 1
Thanks for posting the STP file for that hardline clip.
Already 50 downloads? !?
Don't suppose you can share a sldprt file I'd be able to easily modify?
The ones on my firewall for brake lines mostly broke when I installed my new ABS lines.
Yeah pm me your email and I will send the file. I'm going to make those as well. All mine are broken too
10
This week I finished the fuel system. I machined the step on a 90 degree bulkhead fitting. I then used an o ring to seal it. I added the fuel return line in the tank and finish the rest of the lines.
Drill Fluid Microscope Liquid Wood
Motor vehicle Automotive fuel system Automotive exterior Gas Automotive tire
I also started work on the abs relocation. I straightened all the lines so I can rebend them. I started designing a bracket to mount the abs block. It's taken a few revisions but I think I've found a place for it. It's very tight with the ECU also in that area.
Jigsaw puzzle White Wood Backsaw Font
Hood Motor vehicle Automotive design Headgear Sports equipment
Trunk Bumper Automotive tire Motor vehicle Automotive exterior
I designed a few more clips as well. I made one that holds the clutch and fuel supply lines. I also made 2 for the brake lines. I should only need a few more. They are easy to make and everything looks really clean.
Light Motor vehicle Automotive exterior Automotive design Gas
Automotive tire Motor vehicle Alloy wheel Rim Bumper
Yesterday I finally addressed the header fitment. I ground down some areas where the trans was hitting. I also added 2 washers under each engine mount to lift it a bit. The driver's header still hit the steering rack so I decided to just clearance it. A little time with a hammer and it fit. The passenger side also hit the frame and starter so I clearanced it as well. I need to get a new shorter starter to clear the headers. I hate to dent brand new parts but it's the only reasonable solution. I also bent the heater core lines so they don't hit the head anymore. The engine is sitting in its final position so I can start on oil lines and the rest of it.
Car Land vehicle Vehicle Hood Light
Automotive tire Automotive exhaust Motor vehicle Automotive lighting Muffler
Automotive tire Automotive lighting Fluid Drinkware Automotive exhaust
See less See more
Reactions: 2
Looking good, man! A lot of nice work. It's always fascinating to see how other people attack the same or similar problems... Back in college, I did Formula SAE and by far the best part of the whole process was going to competition and checking out how other teams approached the project. Some teams either had a CNC shop hookup or tons of money - so they designed all kinds of fancy 3d-profiled billet parts. Other teams (like ours) had neither, so we designed our parts to be made on manual mill/lathe - or be fabricated. Some teams were really into composites. The rules were so open, it left room for all kinds of innovations and interesting ways to skin the cat. Always neat to check it out.
I was hemming and hawing over how to relocate my ABS pump. I really didn't want to use flexible lines, but I didn't think I could re-bend the original hard lines and have them come out looking nice... and I was unwilling to put in the effort that was going to be required to bend up a set of custom hard lines from scratch... I could use some firewall brake line clips like you made (and I have a buddy with a 3D printer...so maybe hook a brother up???)
Last, are those the Dedicated Motorsports LS-swap headers? Are they just not quite right or is there something unique about your installation that makes them not work just so?
See less See more
Reactions: 1
2
Small world, I did FSAE in college too. Similar situation we built the car for around $12k. I made sure we had enough money to buy the sweet OZ wheels though. We were not fast and didn’t make it every year but it was fun to build a car from scratch. We were lucky enough to have a Haas MiniMill, however no one knew how to use it. That’s where I taught myself to run a CNC mill.
Wheel Tire Land vehicle Vehicle Car
Gas Auto part Audio equipment Composite material Metal
I will post the brake line clips in a few weeks. I need to work on the clip that holds them to the firewall.
I am using the Dedicated header but Xcessive LS mounts because they are a lot cheaper and nicer IMO. The Dedicated headers are really nice but clearly don’t work very well with the Xcessive mounts. Because I am running the AR5 with a 4L60 bell housing I have less room then the T56, which the kit is meant for.
See less See more
Reactions: 2
4
I was out of town most of the week so I wasn’t able to get much done. I started on a mount for my power steering pump. It will be tight but it should fit right behind the passenger headlight.
Motor vehicle Hood Vehicle Automotive exterior Gas
Motor vehicle Light Automotive fuel system Gas Automotive design
I did a test fit with my radiator and to overflow tank hits the water pump. The tank is also in the way of the upper rad outlet. I'm thinking of cutting it out of the fan shroud and mounting one remotely. I don’t see any options for fan shrouds without the tank.
Automotive tire Hood Vehicle Car Automotive design
Motor vehicle Automotive tire Automotive design Automotive exterior Automotive wheel system
See less See more
