Consensus Solo II Setup? - Page 2 - Lexus IS Forum
post #16 of 39 (permalink) Old 06-16-2005, 12:28 AM
my set up on 245 azenis( the old ones)
zero toe all around - max negative up front max positive in the rear which is about -1.5 and -.9
operating temp on the old azenis is around 98 and they usually need to be cooled after the second or third run even when it's below 80 degrees outside, so bring a spray bottle. 43psi up front and 37-38 rear gives a good temp gradient for asphalt.
edit- .1 deg toe in upfront .1 deg toe out in rear.. this helped dial out some mid corner/corner exit understeer
2001 msm
04&05 STX midiv Champion
itmstgofast is offline
post #17 of 39 (permalink) Old 04-04-2006, 10:21 PM
cone killer
FWIW heres my set up for DS
2002 IS 300 5 Speed with LSD
traction control OFF (DUH)
custom valved konis
set to 1 turn in the front (out of 2)
1.5 turns in the rear (out of 2)
TRD yellow front bar (30mm solid)
Kosei K1-TS 17x7 50mm offset (14 lbs each)
Hoosier 225/45/17
50-52 front 46-48 rear
(i ran the lower pressure with out passengers)
-1.25 camber front
-1.00 camber rear
0 toe all around
i ran this set up on smooth concrete
approx 50 degrees low humidity LOTS of wind and a mile up
GREAT balance AWSOME slaloms just a hint of oversteer under power but VERY predictable
10th on index out of 189
first time out with brand new (still stickered) hoosier SO4's
with only 3 runs
theres more to come!!!!
Donnie
Donnie is offline
post #18 of 39 (permalink) Old 04-27-2006, 02:45 PM
with only 3 runs
I drove Donnie's car at the 04/16/06 Autocross here in Denver...and these are my post-event notes...
* I'm still a Novice - I've been to 8 Events and 1 school.
* Because I was Donnie's Co-Driver, I ran with him in the local X (Experts) class. Having a car marked "179X(N)" isn't all that common...
* Had I not tagged one cone on my second run, I would have placed "not Dead Effin' Last" in X, which is my goal for the season.
* Even with my tagged cone, I bested the D-Stock cars by a full 5 seconds - and a full 7 and a quarter seconds if my fastest run were clean...
* My runs were a full 10-12 seconds faster than what I can manage in my dedicated autocross MR2, which is a light, nimble vehicle...
* Even in my noobness I was only about 3 seconds back from Donnie...
* I've seen the light and...
* I'm selling my '03 Vibe GT (DD) *and* '85 MR2 (Dedicated Autocrosser) and buying an '02 IS300, and modding to match what Donnie's done thus far...
Sometimes it *is* the car...
jonathonbarton is offline
post #19 of 39 (permalink) Old 06-01-2006, 11:42 PM
Just to share my test & tunes...
2001 IS300 e-shift, LSD.
removed spare tire.
Traction off, Power buttom On.
K&N drop-in.
EBC green-stuff brake pads (too dusty, not recommended)
TRD yellow sway, f/r.
Tein H-tech springs, stock shocks.
16x8 FD RX7 wheels all around
Sumitomo HTR-Z 225/45/16 front, 245/45/16 rear (to have the rear higher)
16 to 20-degree Celcius dry day (not hot, just normal vancouver weather), i have 42 front, 37 rear.
Zero toe all around.
front -1.1 camber, rear -0.6 camber.
Competing in STX w/ vcmc & ubcscc under CACC/SCCA solo II.
Good front grip turn-in. Have the option to exit with full power.
turbo den is offline
post #20 of 39 (permalink) Old 06-28-2006, 10:37 PM
cone killer
Slight change in set up
rear camber (-.6)
rear toe 1/16th toe out
everything else has stayed the same
Donnie
Donnie is offline
post #21 of 39 (permalink) Old 06-29-2006, 08:13 AM
Cone Killer
rear camber (-.6)
Donnie
Yeap, those look like the numbers most everyone ran in the rear.
How did ya get -1.25 camber in the front?? I thought we could not get more than -1.0 camber in the front?
https://my.is/forums/showthread.php?t=265815
METEORO is offline
post #22 of 39 (permalink) Old 06-29-2006, 08:15 AM
Cone Killer
Wow that is very impressive!!!!
METEORO is offline
post #23 of 39 (permalink) Old 06-29-2006, 11:03 PM
cone killer
the shop that i took it to does alot of toyota stuff i told him to get as much as he could using the factory adjustments
Donnie
Donnie is offline
post #24 of 39 (permalink) Old 09-11-2006, 07:23 AM
shocks?
I'm considering purchasing an IS300, trading in my mazdaspeed protege. One thing that gives me pause is the soft and more disconnected feeling of the suspension. I love how tight the msp is. Will a good set of autocross shocks and a bar get me there? How dramatic is the difference? How much will they cost?
Thanks in advance. =]
murph1379 is offline
post #25 of 39 (permalink) Old 09-11-2006, 12:05 PM
Speed Enthusiast
punter's Avatar
You won't be disappointed!
The IS comes alive with sways alone. Of course, modding being what it is, you'll likely want to go to shocks and springs too. I just finished that journey myself. Started with sways, loved it. Put Koni's on, loved it more. Put Eibach's on, love it even more!
I haven't autocrossed it yet but have been to the track. In all honesty, you'll probably want at least sways and shocks for the track.
So to alignment, has anyone experimented on track as opposed to autocross? I'm hearing that close to maximum negative camber is good at the front, half way at the back, and if anything, a little bit of toe out at the front and neutral at the back. A lot of positive castor seems the way to go here to maximize negative camber under cornering.
I understand that autocross setups could be poorly suited to track use, especially high speed tracks, as they can be VERY unstable.
I had the chance to measure temps across the tire at Laguna Seca a while back. The suspension was at the factory settings, and the car had only the TRD sways at the time. The temps at about 38 psi (cold) in front and 34 psi (cold) in back were pretty even across the tire. The hot pressures were about 45 psi in front and 40 in back.
Does anyone have any input as to racing specs?
I have attached a short article on the subject too.
http://www.advancedracing.com/chassissetup.php
'02 MSM E-shift
PLP Tower Brace, Injen Intake, A'PEXi WS Cat back, TRD Yellow Sways, Koni Yellows, Eibach Springs, Hawk HPS pads, Goodridge lines, ATE Super Blue, Brembo slotted front rotors, Figs heat shield, Teck Grounding Kit...
punter is offline
post #26 of 39 (permalink) Old 10-15-2006, 05:43 PM
New to the IS 300 and need advice
autocross a miata and want my IS 300 more for high speed stuff ( hwy and posible track days).
I found this email string which seems to end a long time ago but addresses alignment settings for autocross.
I am looking for assistance with recommendations for what to set the car for higher speeds than on an autocross.
Also recommendations on aftermarket additions that will help the car.
I am used to using:: revalved for autocross Koni yellows , larger front sway bar, Hawk pads,LSD and -1.2 negative camber front[ max i can get], -1.5 in rear to reduce power understeer....small amount of toe out front and same small amont toe in in rear for straight line stability with max caster. works great on a 99 miata but the IS 300 is significantly different and would like to hear from those of you that have learned all the tricks to make this car handle beyond the factory's expectations.
thanks for you help.
Jim Clark
2002 Silver IS300
1999 Miata Sport (autocross)
Marietta, GA
w2okq is offline
post #27 of 39 (permalink) Old 04-12-2010, 04:10 PM
Just put 285/30/18s on my rear and 255/35/18s up front A6's on a 18x8f and 18x9r on a +38
toy704 is offline
post #28 of 39 (permalink) Old 04-12-2010, 08:48 PM
What class are you running with those sized tires?
91TB78 is offline
post #29 of 39 (permalink) Old 04-12-2010, 10:17 PM
Dsp the itr in my class is so fast this was my only option
Just got it to fit last night thanks to the Eastwood fender roller and finisher pics coming soon
toy704 is offline
post #30 of 39 (permalink) Old 04-12-2010, 10:46 PM
after
before
toy704 is offline
