1st attempt at rev matching:2002 is300 5spd - Lexus IS Forum
post #1 of 15 (permalink) Old 02-21-2011, 11:17 PM Thread Starter
so i went out tonight for a few hours to learn how to rev match, started out kinda rough but i some what got the hang of rev matching from 4th to 3rd; 3rd to 2nd. but i had the hardest time getting from 2nd to 1st. some times it wouldn't go in at all, most of the time it started grinding which kinda scarred me so i would stop trying to shift. and a lot of the tries that i did get into 1st it would grind just a lil bit. there were some shifts i manged to do very smoothly w/o grinding. one thing i noticed was that when i was driving very slow in 2nd, i didn't need to blip the throttle as much when rev matching and down shifting, about 900-1000rpm. but when i am going faster i needed much more blip, around 2000rpm. is this correct or was i wrong in thinking this? and how can i get better at down shifting into 1st? any help would be much appreciated and just FYI this is my 1st stick shift. TIA
2015 Subaru BRZ Limited 6spd (I miss the IS)
-Sold- Tracked/AutoX'd 2002 IBP Is300 5spd
3 Pedals FTW
BlueTezza39 is offline
post #2 of 15 (permalink) Old 02-22-2011, 08:52 PM Thread Starter
is there not anyone who might have a tip or pointer?
3 Pedals FTW
post #3 of 15 (permalink) Old 02-22-2011, 10:28 PM
Patriot
Quoted: 11 Post(s)
depends on your speed and what gear you are trying to get into. its rev matching so you vary your revs depending on your speed. I used about 1000 rpm for every 5 mph when going into 1st gear, ie-25mph=5000 rpm. 2nd gear is a little different...i use about 4500 rpm at 40 mph. 3rd gear, about 5k at 70 mph and if you are rev matching into 4th, then you are at a high speed track. just keep doing it and you will get a feel for what revs work best for the speed/gear combo you are looking for.
2004 Black Onyx 5 speed
Koni | Eibach | SRT | Megan | Apex'i | ACT | Fidanza | Mizu | Ralco | PLP | Figs | Valentine One
2010 Mercedes-Benz C63 AMG, 426 rwhp
VFA-11 The Red Rippers
chrisridebike8 is offline
post #4 of 15 (permalink) Old 02-23-2011, 06:21 AM
Faster you go, higher the rev. If you ever notice, when you're driving and you downshift letting go of the clutch the rpms will jump up. So when you're "rev matching " your matching those rpms when down shifting so that the motor dose not jerk at the sudden rpm change. Keep that in mind while driving. Might help. I say, as your driving normal, watch your speed and where your rpm is at during that speed just so you can kinda get an idea of what rpm to rev to when rev matching while down shifting. Hope that helped and I didn't confuse you lol
Lexus IS300 AR
Altezza||HKS||JOE-Z||Megan
1999 Honda Accord R.I.P.
2002 Honda Civic SI EP3 SOLD
2002 Audi A6 Quattro SOLD
dai_ka_IS is offline
post #5 of 15 (permalink) Old 02-23-2011, 12:36 PM
its also generally not necessary to shift to 1st unless you are stopped or barely rolling. Otherwise i just keep it in 2nd since 1st gear is so short anyway
drew11588 is offline
post #6 of 15 (permalink) Old 02-23-2011, 01:09 PM Thread Starter
thanks appreciate it, and will the downshift to 1st eve r be as smooth as the other gears? and how bad will it be on my tranny if i'm grinding while i learn?
3 Pedals FTW
post #7 of 15 (permalink) Old 02-23-2011, 04:41 PM
Yeah you should be able to get it smooth but that's if you're driving super slow lol. I've only gotten to 1st on the streets when I didn't feel like braking just wanted to take off. But on the tracks, its rare.
Lexus IS300 AR
post #8 of 15 (permalink) Old 02-24-2011, 12:54 PM
Technical Poseur
Quoted: 31 Post(s)
The syncros for first gear are not back cut so you shouldnt be able to shift into 1st faster than about 8-10 mph. They do this intentionally so you dont accidentally drop it into 1st at speed.
-Tom- is offline
post #9 of 15 (permalink) Old 02-24-2011, 03:52 PM Thread Starter
ok thanks for the help, and is 1st gear not going to be used much on a track bc i plan on going to a track once i get alright at driving a stick, its a lot different then a z71 avalanche ha.
3 Pedals FTW
post #10 of 15 (permalink) Old 02-24-2011, 04:48 PM
Yes its totally different lol. No 1st is rarely used. Only when you mess up and end at a dead stop do you go back to first. Otherwise, lowest you go is second on any corners.
Lexus IS300 AR
post #11 of 15 (permalink) Old 02-24-2011, 05:11 PM
Technical Poseur
Quoted: 31 Post(s)
Even if youre autocrossing you wont need 1st gear on tight corners.
-Tom- is offline
post #12 of 15 (permalink) Old 02-24-2011, 06:37 PM
^^exactly
Lexus IS300 AR
post #13 of 15 (permalink) Old 02-24-2011, 09:28 PM
its not impossible but its absolutely not necessary to downshift to 1st. You can engine brake in 2nd, and you can do tight corners in 2nd. I only use 1st to accelerate after a stop. Most cars make it difficult for you to downshift to 1st to be honest, if you don't match the rpm right you will damage your synchros.
2002 GGP IS300 5MT w/ LSD
shenmecar is offline
post #14 of 15 (permalink) Old 02-25-2011, 01:12 AM Thread Starter
ok thanks i really appreciate all the help
3 Pedals FTW
post #15 of 15 (permalink) Old 02-25-2011, 02:51 AM
NP let us know how it goes.
Lexus IS300 AR
tips/advice: rev matching, heel toe BlueTezza39 General Discussion 3 02-22-2011 09:37 AM
Rev-matching downshifts and response time of paddle shifter questions IS-F-I-Found IS-F 15 07-19-2007 10:12 AM
rev matching ucool22 Go Fast Stuff 16 07-07-2006 09:46 AM
A/F ratio while Heel and Toeing /rev matching, punched it and let go. asukadc Go Faster 29 01-28-2006 11:52 PM
