trunk dome light - Lexus IS Forum
post #1 of 14 (permalink) Old 10-17-2010, 02:28 AM Thread Starter
trunk dome light
It's out and I just changed the bulb in it, still no light though. It doesn't seem to be getting any power back there. The brake lights and side markers work fine. I looked at the fuses on the passenger side kick panel, but I wasn't sure which actually went to the trunk. Thoughts?
nate87 is offline
post #2 of 14 (permalink) Old 10-17-2010, 08:30 AM
Geezer
bartkat's Avatar
Is there a switch on the light?
MOLON LABE
bartkat is offline
post #3 of 14 (permalink) Old 10-17-2010, 10:09 AM Thread Starter
I hope it's not something dumb like turning on the light switch, but to my knowledge there's no switch. Unless you know something I don't know ha ha.
I'll look through all the kick panel fuses again. Are there fuses located anywhere else?
nate87 is offline
post #4 of 14 (permalink) Old 10-17-2010, 11:41 AM
Geezer
bartkat's Avatar
I know there's a switch on the 2nd generation IS but not sure on the IS300.
MOLON LABE
bartkat is offline
post #5 of 14 (permalink) Old 10-17-2010, 11:46 AM
Jedi Knight
Tigger's Avatar
There's no switch for the 1st gen. My suggestion is if you have a voltage tester is to see if there's a current flow. If you're replacing it with LED reverse the polarity.
Also, check the harness for any short...
2003 Lexus IS300 - Graphite Gray Pearl 5MT (sold)
2010 Lexus RX350 - Starfire Pearl
2014 Mercedes-Benz E350 Sports - Polar White
2015 Toyota Sienna Swagger Wagon - Super White
Tigger is offline
post #6 of 14 (permalink) Old 10-17-2010, 12:24 PM Thread Starter
I do want to put a cathode replacement in the trunk but I have to get this power issue squared away first. Checked with a voltage tester and there is no juice period.
nate87 is offline
post #7 of 14 (permalink) Old 10-17-2010, 05:44 PM
actually there is a courtesy switch for the trunk light and it is located within the lock/latch assembly of the trunk. The switch wiring consists of a white w/black stripe wire and red w/yellow stripe wire that goes back to the Body ECU(not the engine ECU..this ECU is located near the driver side kick panal and terminal is labeled LGCY).the red w/yellow stripe wire is grounded via the switch when trunk is open which sends the signal back to that ECU to turn on the light. Obviously check for +12 vdc at the light as Tigger stated ...and if you don't have it there..then I would bet that the switch located within the latch/lock assembly has failed. there is no separate fuse for that particular light...as all courtesy lights are on the same fuse...therefore if it was a fuse...all of your door courtesy lights would not function as well. You will have to remove the upper latch mechanism to get access to the switch. This info comes directly from 02-05 service manual.
post #8 of 14 (permalink) Old 10-18-2010, 06:21 AM
also wanted to add...since you are planning to upgrade to LED lighting...make sure the polarity is correct as tigger also mentioned as some LED's blow if the polarity is reversed. Obviously you need to square away the problem with power...and hopefully my last post should clear up that issue.
post #9 of 14 (permalink) Old 10-09-2014, 10:59 AM
Turns out the problem was the courtesy switch on the passenger front door was bad. All working now, except being able to open the trunk via the remote.
2001 IS300
E-Shift
Spectra Blue Mica
LSD
Tein CS V2.0 w/ EDFC
Greddy EMU
Alucard13 is offline
post #10 of 14 (permalink) Old 10-10-2014, 06:35 AM
press and hold the trunk release button for 3 secs?
Jaysz28 is offline
post #11 of 14 (permalink) Old 10-10-2014, 07:36 AM
Quoted: 87 Post(s)
make sure the key lock is verticle, and not horizontal. If it's horizontal, manually turn it with the key. That's to keep the valets out of your trunk while you eat lobster, or whatever.
-'03 MSM IS 300 5-Speed w/LSD - #REKT. Parted out
-'05 TCM Scion xB
-'08 Mazdaspeed3 Sport - Zoom-zoom.
RazoE is offline
post #12 of 14 (permalink) Old 10-12-2014, 02:54 AM
Tried that already, I can turn the key but it won't come out in that position
2001 IS300
E-Shift
Spectra Blue Mica
LSD
Greddy EMU
post #13 of 14 (permalink) Old 05-08-2019, 09:44 PM
I’m having a similar problem. Mine has been intermittent and I have no idea why it sometimes works and other times doesn’t. Thoughts?
Jstevens35 is offline
post #14 of 14 (permalink) Old 05-09-2019, 02:26 PM
Quoted: 322 Post(s)
Originally Posted by Jstevens35 View Post
Iím having a similar problem. Mine has been intermittent and I have no idea why it sometimes works and other times doesnít. Thoughts?
Try swapping bulbs. Sometimes it could have a bad contact. Other than that I would trace the wires back and look for a bad connector or fried wire.
Careful & Consistent
Map light and Dome light on when you open the door? haiimbrian Showroom 28 05-04-2010 08:54 PM
How to remove the light bulb inside the trunk *the bulb inside the plastic dome* no-more Showroom 6 02-24-2009 06:08 PM
HELp Alarm wont arm CEL on Track light flashing after led install dome light isftw Showroom 5 12-18-2008 11:04 AM
UPDATE: My DOME LED light 1/30/2008!! *license plate & trunk* nigellllll Showroom 61 02-08-2008 06:40 AM
map/dome light fuse? dome light wont work ChinoXS203 Showroom 2 02-16-2007 09:15 AM
