Gurgling fluid sound behind my glovebox? - Lexus IS Forum
post #1 of 97 (permalink) Old 05-08-2010, 10:57 PM Thread Starter
Sometimes when I take off from an intersection, I hear a gurgling of fluid... percolating... seems to be coming from somewhere behind the glove box. Sounds like I'm brewing coffee, but no delicious smell of Columbian blend in the morning. What might this be? Anyone have this sound in their dash?
-J. Arro
2002 Lexus IS300, Graphite Grey Pearl
Arro is offline
post #2 of 97 (permalink) Old 05-09-2010, 04:11 AM
Check your coolant reservoir. It's empty. Fill it back up and get rid of the bubbles in the system.
file_id is offline
post #3 of 97 (permalink) Old 05-10-2010, 01:02 AM Thread Starter
Ok I'll fill it tomorrow. How do I bleed the air easiest on this particular car?
-J. Arro
Arro is offline
post #4 of 97 (permalink) Old 05-10-2010, 04:50 AM
By lifting the front of the car (parking on a slight incline should be sufficient). Leave the engine running.
- Greg '03 BO SD 5-spd.
Originally Posted by EricK
I'm a f#$%&r then
MrGregski is offline
post #5 of 97 (permalink) Old 05-11-2010, 10:22 AM
i have the same thing happening to my car!
jsquareD is offline
post #6 of 97 (permalink) Old 05-11-2010, 11:05 AM
Could also be that the drain line on the a/c coil is clogged. The coil is located in an enclosure inside the firewall on the passenger side. As warm air is cooled by the coil, it creates condensation that drips to the bottom of the enclosure and then out thru a drain line. That's why you sometimes see a small amount of water under the passenger side when you park after using the a/c on a hot day. If the drain is clogged, water get trapped in the enclosure and makes a gurgling of sloshing sound. You can disconnect the drain line from outside the firewall and blow it out with compressed air. If the line doesn't drain, the clog is in the enclosure and that may be a job for a shop. Be careful. If the enclosure gets too full or you open it from the wrong side of the firewall, the passenger footwell will fill with water. Good luck.
pwcopy is offline
post #7 of 97 (permalink) Old 05-11-2010, 12:45 PM
Quoted: 20 Post(s)
which cap do you undo? the one on the radiator or the one on the resevoir?
I just noticed my car does this too, it does in the 2-3krpm range, or is that normal?
Adankid is offline
post #8 of 97 (permalink) Old 05-11-2010, 04:10 PM
from i heeard the noise can also be a servo motor going out. Like with mine when i change the temps i hear a squeaky kinna noise if i leave it on warm it makes no noise when its on cool it makes noise...so depends on the squeak.
GGP IS300-2.75 srt turbo-megan coils, rotora bbk, volk le-37's,custom tinted tails, black pearl badging, lots of other stuffs..
MSM IS300-intake, chrome shortie antenna, painted calipers...
Slvrbullet is offline
post #9 of 97 (permalink) Old 05-13-2010, 01:16 AM
the girgle mostly happens when i turn the car on when its on an incline. sometimes even on flat surfaces. i hear it closer towards the center control panel.
jsquareD is offline
post #10 of 97 (permalink) Old 05-13-2010, 05:16 AM
I am betting you have the same annoying problem I did. Does the gurgling happen to increase with rpm's? If it does....then there is def air in your coolant line. Mine happened b/c I neglected to check the resovoir which was empty. Fill it up...and do what the previous poster said.start with a cold car. Take off the radiator cap. Jack up front of car high as possible. Start car and turn on high heat on the blower(this bleeds any air in there too). Allow car to warm up until the thermostat to open. At this point you should be able to start to see the coolant to flow in the radiator. Be CAREFUL not to run it too long as it will boil over in about 4-5 min from start. Any air in the lines should surface as new coolant is pulled in. Stop your car...lower it...and you should be good. This made it about 95% quieter and worked for me. I always forget t check that res. Good luck....hopes this helps
post #11 of 97 (permalink) Old 05-23-2010, 06:29 PM
forums are great.... ive been having the same issues for about two months!!
notatl is offline
post #12 of 97 (permalink) Old 05-26-2010, 08:57 AM
Well I guess nobody has checked their coolant resovoir? If it is empty...you most likely have air in your system and needs to be bled out as I described above how to do. Check that first.
post #13 of 97 (permalink) Old 05-26-2010, 10:25 PM
checked mine and it was cracked, patched it up and now theres no more gurgling!
jsquareD is offline
post #14 of 97 (permalink) Old 05-27-2010, 11:09 AM
And here I thought (as well as my step dad the mechanic) that this noise was only in my head.... Thanks for the tips guys I'm checking mine tonight
'02 SY IS300
lexusxchick is offline
post #15 of 97 (permalink) Old 05-27-2010, 07:54 PM
uhhh I have gurgling and EXTREMELY LOUD buzzing behind my glove box. It's driving me insane. Is it the AC motor? WTF will this cost me?
joejaeg3r is offline
strange gurgling sound- any help? JAEohEN Basic Help & Repair 22 10-19-2007 01:21 AM
Rough gurgling noise? XxPloSiV Basic Help & Repair 8 02-16-2005 12:16 AM
gurgling sound when i start my car... jdmaltz General Discussion 7 12-26-2004 12:09 PM
Gurgling Sound krosner General Discussion 1 09-29-2004 08:24 AM
Gurgling sound from race pipe PBsIS Go Fast Stuff 7 09-28-2004 05:58 PM
