Does not start after timing belt and seal replacements. - Lexus IS Forum
post #1 of 2 (permalink) Old 01-20-2019, 08:41 AM Thread Starter
Replaced cam and crank seals along with timing belt and valve cover gaskets. I have pretty much quadruple checked the mark alignments and everything is spot on. Turns over but kinda sounds like a sputter. Crank timing teeth are not broken. Not really sure what else there is to do except to check for spark, fuel and compression. Smells like there's fuel getting to it. Just scared that I could have possibly bent a valve. Can the compression test confirm whether or not I have bent one? Also feel free to share your thoughts or experiences. Thanks.
Keelin is offline
post #2 of 2 (permalink) Old 01-20-2019, 03:10 PM
Quoted: 339 Post(s)
If it ran before. You may have the marks off. Or did all the power cables get hooked up again. If all that. Then check the compression.
Mike's '02 AR L-tuned mm71522 Member Build Threads - Lexus IS only 1364 11-23-2018 09:53 AM
DIY: Complete Timing Belt+Water Pump+ Seals mm71522 DIY/tutorial forum 39 10-23-2018 10:35 PM
What timing belt parts to buy? treehunna General Discussion 6 05-27-2018 04:42 PM
Cam Seal Leaking or VVTi Gear? Stanri010 General Discussion 6 05-16-2018 06:18 PM
VVTI pulley moved during timing belt and cam seal change bsportxx General Discussion 11 04-28-2016 09:32 AM
