TapTurn: One-Touch Signals and Funky Flashers! - Page 4 - Lexus IS Forum
 24Likes
post #46 of 64 (permalink) Old 01-05-2014, 09:53 PM Thread Starter
Quoted: 595 Post(s)
Yeah the group buy would have only been 10% off, so only like $10 lol. Still worth every penny!
post #47 of 64 (permalink) Old 01-06-2014, 09:01 PM
I received the unit today and installed it within 30 minutes. One thing I noticed that my hyper flash was gone but my flasher warning is still lit on my cluster. Is it suppose to turn off too or still be one since I have LEDs? Also after installing I noticed that my DRLs don't turn on now. Is that suppose to happen too or did something happen during installation? Overall I'm satisfied with my order and the unit. I really enjoy the strobe package!
RrAaCcOoOoNn is offline
post #48 of 64 (permalink) Old 01-06-2014, 11:17 PM Thread Starter
Quoted: 595 Post(s)
^^^ What is a "flasher warning"? And this thing has nothing to do with the DRLs lol.
post #49 of 64 (permalink) Old 01-07-2014, 12:44 AM
^^^ Since I changed the bulbs to LED's it uses less voltage so the car thinks that the bulb is "out" and so it sets off the light in the cluster telling you that one of the blinkers are out. Also I know that the relay has nothing to do with the DRL's but i was just curious because it stopped working after i installed it, but im not blaming it on the unit
post #50 of 64 (permalink) Old 01-07-2014, 01:24 AM
Anyone installed this with regular stock bulbs?
Nice write-up. Thanks!
IS300 - it's a Love/Hate relationship.
valhallab is offline
post #51 of 64 (permalink) Old 01-07-2014, 05:43 AM
The warning light is only for tail and brake lights, not for the signals.
pierre_2zzge is offline
post #52 of 64 (permalink) Old 01-07-2014, 06:03 PM
nice i will check it out too thks
jeff300 is offline
post #53 of 64 (permalink) Old 01-07-2014, 08:01 PM Thread Starter
Quoted: 595 Post(s)
That's the brake light bulb indicator lol, not the signals. You could always put the stock flasher back in to see if the DRLs work again, I've got mine disabled.
It works fine with stock bulbs, you can see videos of it on a Subaru with regular bulbs.
post #54 of 64 (permalink) Old 01-21-2014, 10:44 PM
Well I got my Tap Turn today and installed it. Here is a quick summary on how to install as there are no instructions.
The flasher relay module is located behind the fuse box in the driver side kick panel.
1. (this step not necessary but made it way easier) I removed the foot rest by the clutch so I had room to pry the fuse box out. Just pull it hard its held in by 2 plastic clips that you can get at.
2. Remove the Driver side kick panel so you can see the fuse box. This is covered on the forum in detail but heres a rundown. There is a black finger screw by the pedals, just use your fingers to unscrew it. I also unpop the plastic trim along the side of the frame next to the seat where it meets the kick panel to make it easier to pull it off. Now pull the kick panel towards you and it will pop off.
3. Now you are looking at a beige colored fuse box. Along the bottom is a silver 10mm bolt. Use a ratchet and extension to unscrew this.
CLOSE UP
4. Near the top you will see a pink box. There is another silver 10mm bolt. Unscrew that.....youll need the extension so you are not super uncomfortable.
5. Stick a flat head behind the lower part of the fuse box and pry the box forward so that you can see the RED flasher relay (its also labeled FLASHER on the back of the fuse box).
6. There are plastic clips on either side of the relay, one you can see the other you cannot. Pry off one side and then yank the relay out.
7. Stick new Tap Turn relay in and hit your hazards to make sure it works.
8. Re assemble.
Hope thats helpful
TobiasSing likes this.
shockwave2501 is offline
post #55 of 64 (permalink) Old 01-21-2014, 11:33 PM Thread Starter
Quoted: 595 Post(s)
Yeah, we've got a DIY or two on how to do this, I posted a pic there. But good idea to post that here as well, that's exactly what I did!
post #56 of 64 (permalink) Old 01-22-2014, 12:13 AM
Oh I didn't realize that you had posted a DIY. Oh well at least it's a very complete thread lol. Thanks again for showing all of us this mod!
post #57 of 64 (permalink) Old 04-17-2016, 09:56 PM
Quoted: 10 Post(s)
You're going to give people a seizure with this setup
Mrhiguy is offline
post #58 of 64 (permalink) Old 04-18-2016, 01:56 PM Thread Starter
Quoted: 595 Post(s)
and you're giving everyone a migrane with all these posts XD lol Irvin
post #59 of 64 (permalink) Old 11-14-2018, 12:01 PM
Quoted: 14 Post(s)
Sorry to bring up an old thread, but I had a question about this module. I had one of these in my 2015 WRX, but it actually ended up causing an electrical fault with my BIU (Body Integration Unit, basically an ECU used for the interior) which was a hassle to deal with. Has anyone ran these modules, well custom relay, on their IS300 without any issues? Were you running OEM bulbs or were you able to just run plug and play with LED's no problem?
1989 Nissan 240sx Coupe
2002 Lexus IS300 SportCross
2007 Nissan 350Z
2015 Subaru WRX
Tihsho is offline
post #60 of 64 (permalink) Old 11-14-2018, 02:23 PM Thread Starter
Quoted: 595 Post(s)
I (creator of this thread) have been running this same flasher relay module since I installed it ... wow, 5 years ago. It's been absolutely flawless. I have all LED bulbs all around. Since this time, Diode Dynamics has also released a cheaper version. But this car isn't a WRX.
flashers wont go off when car is off Turbo Tony Basic Help & Repair 2 02-21-2008 07:38 PM
INSTALLED HEADLIGHTS (now flashers don"t work) wtf castlevania Showroom 12 07-14-2007 09:26 PM
High Beam Flashers zeindog13 General Discussion 5 07-20-2003 07:58 AM
High-Speed Flashers Malnodnarb Showroom 4 12-04-2000 01:35 PM
