HKS CAMP2 Replacement? - Lexus IS Forum
post #1 of 9 (permalink) Old 12-05-2018, 10:49 AM Thread Starter
Quoted: 14 Post(s)
I'm looking for a gauge setup that I can go in and check a few things without having to pull a scanner or have a plethora of gauges on my dash. I remembered looking at the HKS CAMP years ago and remembered the CAMP 2 came out, but it seems like it's been past its prime and finally went to being discontinued. Does anyone else offer something like this? Ideally, I'd like to feed the video stream to an OEM Navi unit, but I could feed it to a double din screen if necessary.
1989 Nissan 240sx Coupe
2002 Lexus IS300 SportCross
2007 Nissan 350Z
2015 Subaru WRX
Tihsho is offline
post #2 of 9 (permalink) Old 12-07-2018, 06:56 PM Thread Starter
Quoted: 14 Post(s)
Nobody has anything on this? Hrm...
How hard is it to come by a CAMP 2? I can get the accessory packages easy, just can't seem to find the main unit.
2007 Nissan 350Z
2015 Subaru WRX
Tihsho is offline
post #3 of 9 (permalink) Old 12-07-2018, 09:17 PM
Quoted: 38 Post(s)
Second time I have posted this in a week lol
I put a 7" android tablet in the navi unit and ran Torque through it
el_jefe is offline
post #4 of 9 (permalink) Old 12-10-2018, 09:49 AM Thread Starter
Quoted: 14 Post(s)
Interesting, I'll have to search for a write up on this if you have one.
The only issue I have with retrofitting a tablet are for the following:
1) Power Cut Off - Ideally I'd rather not have the tablet run when the car is off. I don't want a parasitic drain from the batter to keep the device up either. Ideally, I'd look at this like my old car PC days and have a remote wire trigger the power so that there is a startup power signal and a safe shutdown signal so the device is off when the car is off.
2) Heat - Tablets these days with decent resolution and that are not laggy generally run hot. Being retrofitted into a dash means they are going to get less circulation (also don't want to cut into the vents to cool it off) which means the battery inside is a ticking time bomb of acid. Not only that, but this location is where the sun will be beating on it, so not only is the device producing heat, but it's absorbing it from the sun.
That said though, the functionality and the built in features of a tablet are hard to beat. I just need to figure out how to do it right.
2007 Nissan 350Z
2015 Subaru WRX
Tihsho is offline
post #5 of 9 (permalink) Old 12-10-2018, 11:06 AM
Quoted: 230 Post(s)
how about something like this? if i understand correctly, you are after something like this:
https://store.partsshopmax.com/unive...auge/EVDM.html
although there is no way to incorperate into the nav or a double din
Lucy; 04 manual sportdesign
mesooohoppy is online now
post #6 of 9 (permalink) Old 12-10-2018, 02:06 PM
Quoted: 38 Post(s)
No write up, I just got bored.
The power cut off issue can be dealt with in software, but I never got that far. I used a kindle fire as a proof of concept, and with the amazon overlay it was a PITA to make automate work right.
Heat wasn't and isn't an issue. Also, no acid in tablet batteries, it's lithium ion or a variant. They don't leak.
I'm probably going to pull the tablet, and make a docking station with a qi charger in it, as I honestly dont use this for much.
el_jefe is offline
post #7 of 9 (permalink) Old 12-23-2018, 08:35 AM
Quoted: 18 Post(s)
IF you got the money to splash, you should go for one of these.
Just placed an order for one. This will sit in the place of the factory Navi.
7" Full colour TFT IPS graphical LCD multi gauge
Shady89066 is offline
post #8 of 9 (permalink) Old 12-26-2018, 09:10 PM Thread Starter
Quoted: 14 Post(s)
Interesting @Shady89066, I'll look into it more. The only problem with that setup is that it's dedicated. It looks nice, but I'm trying to get everything setup so I can have the display show readouts and automatically shift to reverse camera when the car goes into reverse.
2007 Nissan 350Z
2015 Subaru WRX
Tihsho is offline
post #9 of 9 (permalink) Old 12-28-2018, 04:10 AM
Quoted: 7 Post(s)
I remember looking into the PLX gauges at one point to have multiple readings without several gauges. You can have it mounted in cluster or in a gauge pod and do all modern stuff with smartphones too.
Goopi is offline
Lexus IS Fog Light LED Bulbs! Install Video! Luxeon LED Replacement Housings! New SLF Diode Dynamics Diode Dynamics 12 06-21-2018 04:28 PM
Bilstein B6 Front Shock replacement - Loud "thunking" over bumps in front bvanbens2002 Stop, Drop and Roll 1 08-08-2017 08:14 PM
IS300 Clutch Replacement DIY difficulty? Sassper Basic Help & Repair 8 09-09-2016 04:56 PM
