Cluster options (sticky?) - Lexus IS Forum
post #1 of 76 (permalink) Old 12-12-2011, 12:23 PM Thread Starter
Alright so after seeing how many different clusters there are out there, I decided it'd be a good idea to make a thread for them.
1)Stock IS300 cluster 2001-2003 (Automatic) MPG, Volts, coolant temperature
2)Stock IS300 cluster (manual) MPG, Volts, coolant temperature
3) Altezza (manual) Coolant temp, Volts, oil pressure
4) Altezza (automatic)Coolant temp, Volts, oil pressure
5) Altezza Digital RS200 (manual, 9k rpm limit)oil pressure, volts, coolant temperature -
6) TRD (automatic, 10k rpm limit) Coolant temp, volts, oil pressure
7) TRD (manual, 10k rpm limit, tachometer on left) Coolant temp, volts, oil pressure
8) TRD (manual, 10k rpm limit, tachometer in the middle) Coolant temp, volts, oil pressure
9) Modellista (manual)coolant temperature, volts, oil pressure
10) Altezza Automatic (Oil pressure, volts, coolant temp)
11) Australian IS300 Automatic (L/100km, volts, coolant temp)
12) Altezza 1F GE (coolant temp, volts, km/L)
13) RS200 limited edition yellow (oil pressure, volts, coolant temp)
14) 04-05 Manual USDM IS300 (MPG, Volts, coolant temp)
15) 04-05 Automatic USDM IS300 (MPG, Volts, Coolant temp)
16) Custom made
Let me know if there's anything else I should specify in my descriptions.
Enjoy
Jerm__ is offline
post #2 of 76 (permalink) Old 12-12-2011, 12:27 PM
Quoted: 9 Post(s)
I like the all black look that the Modellista has!
Too many people try to impress others and build their car to what they know someone will like.
You lose sight on what you like, when you simulate your likes around others dislikes.
-PhillyB
What the Fitment
N V ME is offline
post #3 of 76 (permalink) Old 12-12-2011, 12:52 PM
crazy question.... I notice the altezza clusters have a higher redline compared to the Lexus cluster... I assume the lexus will still redline at 6500 with a Altezza cluster, unless modded?
2002 BO LSD
Tokico|Eibach|HKS|GReddy|FIGS|RMM|TunedParts|
tc02is300 is offline
post #4 of 76 (permalink) Old 12-12-2011, 12:56 PM Thread Starter
^thats correct, the type of cluster used doesn't change the engine's actual cutoff. You'll need to use some kind of piggy back or standalone to change the cutoff.
Jerm__ is offline
post #5 of 76 (permalink) Old 12-12-2011, 02:37 PM
Hey Jerm, I'd have to go with the Altezza Digital RS200 *hands down* reason being is that it looks the cleanest and digital is the new thing now. hyper white LED bulbs will make it look 100x better than anyone's here in the U.S. are you planning on getting this done to your car bro? I highly suggest you do and def post up photos once it's on your car.
+REP for a cool thread. gives everyone a concept of all the alternative gauge clusters
IRONMAN IS300
quicktojudge is offline
post #6 of 76 (permalink) Old 12-12-2011, 02:49 PM Thread Starter
^Thanks man.
There are a couple people on here with that cluster. check it out: https://my.is/forums/f90/my-new-jdm-d...pdated-415208/
this is a good link also
https://my.is/forums/f90/jdm-rare-trd...tional-427208/
Jerm__ is offline
post #7 of 76 (permalink) Old 12-12-2011, 03:10 PM
Technical Poseur
Quoted: 31 Post(s)
I think what I would do if I were ambitious enough (and had enough engine mods to get a higher red line) I would do an Altezza digital cluster and then run a Dakota Technologies signal conditioner on the speed input signal so that the KM/H would actually be displaying MPH.
-Tom- is offline
post #8 of 76 (permalink) Old 12-12-2011, 04:18 PM Thread Starter
^yee, would be a sweet mod. I don't need the MPH conversion though But the Digital Altezza one is def. the nicest one.
Jerm__ is offline
post #9 of 76 (permalink) Old 12-12-2011, 04:25 PM
where can i get the RS200 if i wanted to?
'03 | JDM | GROM | SRT | HKS | Megan | L-Sportline
53XU5.
"Our cars will never be civics, IS300's are much nicer and much more refined, you must also never forget we have a 2jz." - T57-IS300
(LOL)
ravasmout is offline
post #10 of 76 (permalink) Old 12-12-2011, 06:24 PM
Blue Devil
LO 21's Avatar
#5 - yes, manual only
#6 - that's actually automatic. they make a manual one also, The-IS has one
©2006 my.IS
IS300 '01 - Spectra Blue Mica | ELIXIR | SRT 2.75 Turbo | V161 6-speed | Volk GT-M | Tein CS |
IS F '12 - Ultrasonic Blue Mica | ISS Forged Exhaust | WALD Diffuser | Ventross Trunk | Lexon Roof Spoiler |
LO 21 is offline
post #11 of 76 (permalink) Old 12-12-2011, 06:25 PM
Blue Devil
LO 21's Avatar
i would be your source for that
they come straight from japan, only from japan
i have a contact there who will ship to me if requested, and if available
i didn't see any available for about a year, and then 2 popped up at the same time. so you just never know, its hit or miss.
©2006 my.IS
LO 21 is offline
post #12 of 76 (permalink) Old 12-12-2011, 07:57 PM
Quoted: 27 Post(s)
At least the TRD manual cluster also came in a version with the speedo in the center and tach on the left.
2002+ and 2001 IS300 clusters are slightly different. 2002+ models have a grey trim piece around the back. Just makes it look a little more modern I guess.
white_is is offline
post #13 of 76 (permalink) Old 12-13-2011, 08:32 AM Thread Starter
Thanks for the heads up Leon and Corey
I'll update the first post when I get home
Jerm__ is offline
post #14 of 76 (permalink) Old 12-13-2011, 09:45 AM
Fokai 1008
Quoted: 14 Post(s)
i never knew there were so many , still like mine the best tho ....and i dont see to many custom clusters
ISR220 Build
https://my.is/forums/f219/isr220-neo-...2011-a-391109/
Adam P is offline
post #15 of 76 (permalink) Old 12-13-2011, 10:41 AM Thread Starter
Jerm__ is offline
Tiptronic Faster shifting options? and Redline Holding Options? IrUzAl Go Fast Stuff 10 10-15-2009 11:40 AM
Can someone make the price/options list for the new IS sticky? BUD001 General Discussion 0 10-16-2005 11:05 PM
