Automatic headlights stopped shutting off. - Lexus IS Forum
post #1 of 15 (permalink) Old 02-25-2011, 03:14 PM Thread Starter
I have a fairly consistent schedule. I go to work in the morning, get off at 5 and then go to class till 9. When when I get home from class it's dark. I park the car, get out, and then hit the lock twice to lock it and then turn off the auto lights. Well Some days when I don't have class, I'm getting home and it's just starting to get dark. I did the same thing and lock it twice.
ANYWAY, I came home one day and locked it the usual 2 times to shut the lights off out of habit, but I since it was still light, I didn't notice they were still on and they kill the battery.
I'm trying to figure out why the lights do not shut off any more. I can click lock on the key-fob as many times as I want and the signal lights flash but the headlights stay on. I can't figure out what changed to make them stop working.
What I do now is when I turn the car of, I switch the lights to on for a second and then back to auto and they turn off.
Ant ideas?
Shadowen925 is offline
post #2 of 15 (permalink) Old 02-25-2011, 04:05 PM
Open and close the passenger doors, a switch is sticking.
- Greg '03 BO SD 5-spd.
Originally Posted by EricK
I'm a f#$%&r then
MrGregski is offline
post #3 of 15 (permalink) Old 02-25-2011, 07:10 PM Thread Starter
I tried opening and closing all the doors as well as just pressing on the switches. They are all good. So now I don't know.
post #4 of 15 (permalink) Old 02-25-2011, 07:39 PM
I'm confused. Your thread title says auto headlights not working properly, but your thread sounds like your talking about your interior dome light. Which one, so I can be sure I can help?
post #5 of 15 (permalink) Old 02-25-2011, 08:02 PM
Check the ground and relay like so.
JohnnyChimpo is offline
post #6 of 15 (permalink) Old 02-25-2011, 09:39 PM
If you are referring to the dome light not going out then you need to check the plunger (courtesy) switches that detect a door closed, as Greg mentioned. They may "feel" operational but you need to physically pull them out and test with a meter. When the door is open the switch is closed, so if the switch has continuity while being pushed..then a bad switch.
post #7 of 15 (permalink) Old 02-25-2011, 10:46 PM
While pressing your key for automatic lock. Listen to hear if all your doors are locking. If you have a bad actuator not locking your door, your lights won't turn off since your car isn't securely locked. Try that.
NAVY Veteran
///Injen Intake///Injen Header Heat Shield///HKS Dragger 2 Exhaust///Alphawerks Y-Pipe///Halo's from TunedParts///3k HID fogs///JDM Rain Visors///20% Tints all around///
240sx_is300 is offline
post #8 of 15 (permalink) Old 02-26-2011, 12:41 AM Thread Starter
Greg was right, more or less. I was having a problem with the headlights. The problem was that Since the switch on the driver side door has a loose wire or something, it never thinks the door opens. So when I go to lock it, it's like I never got out of the car. Anyway. I wiggled the switch (plunger) when i got out and made the door ajar and dome light flicker so after I shut the door and tried locking it twice, it worked as expected.
I just have to figure out what's making that switch always think the door is closed. Probably a lose wire.
post #9 of 15 (permalink) Old 02-26-2011, 07:51 AM
I bet its a bad plunger switch contact like I said. Don't think its a loose wire.
post #10 of 15 (permalink) Old 02-26-2011, 02:01 PM Thread Starter
Could be. My biggest issue is time. When I do get some time, I'll go unscrew it and see what I can figure out.
Thanks for all the help.
post #11 of 15 (permalink) Old 02-26-2011, 11:25 PM
See if you can squirt some electrical contact cleaner into the switch. That will clean the contacts as well as provide a bit of lubrication to the plunger mechanism.
WJB
Ventura, CA
2002 GGP 5-speed, ClearShield, Borla Cat-Back, Ralco RZ Short Throw Shifter, Greddy Counterweight Shift Knob, JDM Dash Tray, Gold Calipers, CDD-Brake Union Mod, 2003 Cup Holder, Black Pearl Emblems, Dash Kit, LED Interior Lights, Grom Audio iPod/AUX Integrator
2005 Honda ST1300A
wjbertrand is offline
post #12 of 15 (permalink) Old 02-27-2011, 09:07 PM Thread Starter
I just picked one up for like $10.
I couldn't get it apart inside and I couldn't pull the passenger side one out far enough to swap them. Since it was cold and dark, I didn't want to pull interior paneling apart to get to it or even spend much time on it. So I just got a new one. The problem is definitely the switch.
post #13 of 15 (permalink) Old 02-28-2011, 03:26 AM
Becareful you don't lose the wiring into the mounting hole when you remove the wiring off the old switch
post #14 of 15 (permalink) Old 01-14-2017, 03:21 PM
Hey guys I am having the same problem............(yes I know the thread is 6 years old but this could help future users)
I think your door sensor may not be working
Here's somethign from Club lexus.....
DIY - Trouble with door jamb sensor solved.
I've been having issues with the driver's side door jamb sensor, which detects whether or not the door is open, not operating correctly for a while. In my case, when the door was opened, it would intermittently not detect the door is open. The LEDs on the door itself as well as various other things like the courtesy lights would either sometimes not activate or flicker on and off randomly.
Sorry, no pics as usual but it's a simple operation.
What I did to solve the problem was remove the sensor (switch) from the door jamb. It is a single bolt. I thought at first that it was a matter of the switch itself getting sticky and needing lubrication so I removed the rubber boot from it and wiped it down well with silicone lubricant.
At this point after plugging it back in, I noticed that it would not operate at all when attached to the harness but not attached the vehicle. I realized then that the screw holding it to the chassis must actually be providing the ground. When I started screwing it back in, while the screw was loose, it was flickering on and off as before but when I held it in certain positions the flickering stopped.
Now, the bolt holding it was far from loose to begin with but there must have been a layer of corrosion or something that I loosened up just by removing it and re-tightening it because after I got it good and hand tight my problems were gone and the ground was properly restored.
Some of you claim to have issues with your lights not automatically turning off, the default state of the circuit seems to be open (door closed, which is smart of Toyota this should effectively cover the switch going bad) so I'm not sure if this will help you at all. My problem was the car not thinking the door was open, not with not detecting that the door was closed. In your cases, it may not be the ground that's the problem and it may very well be the physical switch is not travelling to the closed position and simply doing the lubrication may help.
not.a.real.pony is offline
post #15 of 15 (permalink) Old 01-19-2017, 09:47 PM
Thanks for reviving this since i had those problems, ill try em out tomorow.
Landmaster is offline
Sensitivity of the automatic headlights argh Basic Help & Repair 8 09-03-2010 09:04 AM
shutting off brandon77 Go Faster 13 02-24-2008 08:57 PM
Amps shutting off Split2nd Mobiletronics 14 06-27-2005 07:57 PM
aftermaket automatic headlights DHCrocks Mobiletronics 8 03-17-2004 05:50 PM
