Aftermarket Headlight Vs. Stock Headlights - Need a facelift - Page 4 - Lexus IS Forum
 12Likes
post #46 of 51 (permalink) Old 11-11-2017, 09:17 PM
Quoted: 15 Post(s)
I should be getting my car back tomorrow ill make a youtube video about them when i do. I still need to do load resisters to stop hyper flashing but the lights work great in all other aspects
208Tezza is offline
post #47 of 51 (permalink) Old 12-23-2017, 09:14 AM
Originally Posted by VegasIS3 View Post
I like the aftermarket lights that I put on my car. They don't have provisions for the auto-leveling, but they are easily adjusted up or down with a bolt. The light spread is pretty good and I like the halos and led bar. They were from ebay.
I have the same lights, they do have the provision to install the auto-level motor.
TobiasSing likes this.
2003 IS300 Sport Design -5SPD Manual- K-Sport Air Suspension, Subframe Connector, HID/LED Lights, CAI, Eibach Rear Sway Bar
1979 280ZXT -Manual-Ground Control Coil-Overs, 330cc Injectors, Custom Fuel Rail, RRFPR, CAI
2007 TL Type-S -6SPD Manual - CAI - LED Headlights
12volt is offline
post #48 of 51 (permalink) Old 07-11-2018, 03:49 PM
Quoted: 32 Post(s)
I just finished installing the same single halo with LED strip from spyder too, B- quality construction at best. I currently have the stock HID bulbs in now, and I plan on installing high output LED's (55w/light) that are D2S compatible. I still like the design and hopefully the LED's will help with the strange light spread, with shadows from the HID bulb design.
One thing to note for anyone looking to install housings without the auto-leveling, is that you'll want to remove the harness under the drivers side steering column, it's found right above the OBD II wiring harness and slides right out. That way you avoid the annoying light on the dash
DH_71631 is offline
post #49 of 51 (permalink) Old 07-12-2018, 02:53 PM
Quoted: 595 Post(s)
I believe that trying to use an LED bulb for the main projector output would only make it stranger
post #50 of 51 (permalink) Old 07-18-2018, 10:30 PM
Quoted: 32 Post(s)
I wouldn't say stranger, honestly with how the LEDs are designed, it's more predictable. With HID's you have to account for the glass and outer construction of the bulb causing weird patterns. That's not the case with the LED's, since the only obstruction would be the surrounding aluminum. While it's not perfect, light throw is now acceptable to where I don't mind driving at night with these projectors. And what i've found is that the throw is so good I can see reflections (not to be confused with direct light beams) of street signs up to 800 yards out. And the cutoff for the light projection is pretty low, so the light that is hitting the street signs is just the outer edges (ambient light), to which i'm not blinding others on the road.
I have a comparison of the HID vs LED attached
LED is considerably brighter as well.
ID:	120191   Click image for larger version
ID:	120193   Click image for larger version
ID:	120195   Click image for larger version
DH_71631 is offline
post #51 of 51 (permalink) Old 07-19-2018, 04:34 PM
Quoted: 595 Post(s)
well, as long as you're happy with them
Aftermarket HU with Stock Amp & Speakers + New Sub noloc4545 Mobiletronics 6 01-14-2018 08:22 PM
DIY Restore your nasty headlight lenses. Permanently. willthehill DIY/tutorial forum 6 09-15-2017 10:02 AM
aftermarket headlight Hmoob General Discussion 1 05-05-2017 10:26 AM
Wet Sanding works on car paint and headlight scratches & oxidation Cheez General Discussion 0 10-15-2016 10:49 PM
