~Official~ IS300 Header Thread - Page 11 - Lexus IS Forum
post #151 of 238 (permalink) Old 03-22-2012, 05:48 PM
Originally Posted by Nyke View Post
You are better off with OBX, the sensor is in the right location and OBX has a small lip at the Y-Pipe bolt up with helps with sealing. Megans do not have that.
Good to know, but I still can't get over that shitty collector design...
Kevin IS Drummer is offline
post #152 of 238 (permalink) Old 03-24-2012, 02:55 PM
I love my Megans. Seriously though, the placement of the O2 bung isn't that big of a deal. I fixed that situation in 5 minutes with a hammer.
2003 Satin Black WRX
2002fivespeed is offline
post #153 of 238 (permalink) Old 04-10-2012, 05:59 AM Thread Starter
Bezik777's Avatar
Quoted: 44 Post(s)
Update..........................
New Header maybe on its way to market later this year .....check out the Dezod Interest thread ....
https://my.is/forums/f184/gi-long-tub...y-pipe-441135/
-Boosted-
-JCE10 Midwest-
Bezik777 is offline
post #154 of 238 (permalink) Old 04-13-2012, 09:40 PM
Quoted: 17 Post(s)
got my obx header n ypipe on it was nice that the used header i bought came with sensors cause 2 in my header pulled threads even with heat. alot more up top power and its nice and opened up for future plans
polish man is offline
post #155 of 238 (permalink) Old 04-13-2012, 10:01 PM
noob question but are any of the after market headers good to pass with CA smog?
Rodz88 is offline
post #156 of 238 (permalink) Old 04-14-2012, 04:02 PM Thread Starter
Bezik777's Avatar
Quoted: 44 Post(s)
Magnaflow should pass smog ?!?!
-Boosted-
-JCE10 Midwest-
Bezik777 is offline
post #157 of 238 (permalink) Old 04-14-2012, 07:05 PM
Random question, is it normal to smell gasoline after header installation? I just slapped on a toyo header to try it out and only annoying thing is the smell of gas...
*01 Is300//1jz-gte//*
jesus954 is offline
post #158 of 238 (permalink) Old 04-14-2012, 08:50 PM
yeah, especially combined with a y-pipe (aftermarket).
03 5speed GGP
joel1212 is offline
post #159 of 238 (permalink) Old 04-15-2012, 07:03 PM Thread Starter
Bezik777's Avatar
Quoted: 44 Post(s)
Normal due to less burn off and less restriction of the complete exhaust system....
-Boosted-
-JCE10 Midwest-
Bezik777 is offline
post #160 of 238 (permalink) Old 04-16-2012, 10:22 PM
Quoted: 16 Post(s)
got my megan header and y pipe, did a quick mock up and.... not to bad, but damn these flanges are not flat. Warped from welding, probably why many have problems with leaks.
I'm going to try and using something flat with sandpaper, to square them up.
any good pictures of where I should weld a O2 bung in?? I'm fairly sure I know where to weld it in, but a couple pictures would help, as I want to weld it in and take header for ceramic coat.
02 1C0 5spd
Megomaniac is offline
post #161 of 238 (permalink) Old 04-17-2012, 09:57 PM
Hmm I'm running the toyomoto header and y pipe with stock b pipe and hks dragged 2 cat back. Dam, so there's no solution for the smell...I've read people welded their y pipe with their headers and a good portion of the smell went away, might this work?
jesus954 is offline
post #162 of 238 (permalink) Old 04-18-2012, 01:29 PM Thread Starter
Bezik777's Avatar
Quoted: 44 Post(s)
That would help . I'd only do it if you don't plan on changing your set up and don't mind welding them together.
-Boosted-
-JCE10 Midwest-
Bezik777 is offline
post #163 of 238 (permalink) Old 06-19-2012, 05:01 PM
I am having the same problem i got about a half of an inch gap, going to machine them down and that leak blew out the gasket for the header to the y pipe so i gotta fix that too at the same time... post up how yours went.
cambodianthunder is offline
post #164 of 238 (permalink) Old 06-22-2012, 11:33 AM
Quoted: 16 Post(s)
I didn't get any before pictures , but here is some after. Took me about 3 hours on my belt sander, can't really tell from the pictures but it's alot better then when i took it out of the box. My y-pipe is probably a knock off cause theres no megan logo on it, got it on ebay.
I'm also going to try this e-vac fitting from vibrant, going to try and put it just after y-pipe merge if it doesn't hit the under side of the car.
02 1C0 5spd
post #165 of 238 (permalink) Old 06-22-2012, 12:22 PM
stjarvis's Avatar
You need to have very low back pressure in the exhaust for those to work at all. On most exhaust setups they end up making things worse.
In 5 years I will have the worlds fastest IS300... because everyone else will have parted out and bought an M3.
stjarvis is offline
?Official IS300 Wallpaper Thread? BeansIS Showroom 183 08-22-2014 12:25 AM
IS300 - Official DIY (Do It Yourself)Thread JayMarino DIY/tutorial forum 2 05-18-2009 12:03 PM
