Emissions with na-t is300 - Lexus IS Forum
post #1 of 3 (permalink) Old 12-20-2017, 05:09 PM Thread Starter
Im in ontario,Canada emissions are really strict here im just wondering can you pass obd2 emissions with na-t IS, im hoping to turbo my is this summer ill run standalone or piggyback which ever will pass emmisions is my choice thanks in advance
03IS3MT is offline
post #2 of 3 (permalink) Old 02-13-2019, 06:51 PM
Same problem in NY , it can be done but is hard. My problem is not emissons as i have a chip for the post cats, which is the easy part. .my problem with a fully built engine and agressive tune is misfires drom stock ecu. It has bee been documented all over this board , it can be done
American Complex, cock it and pull it
Str8 Six is offline
post #3 of 3 (permalink) Old 02-19-2019, 02:20 PM
Quoted: 74 Post(s)
My NA-T arrangement retains the OEM ecu, fully hooked up with exception of the coil ignitors and injectors - leaving fuel/spark control to a programmable ecu.
To pass emissions, I see two options:
1. Clear all codes, swap to stock injectors, and give fuel/spark control back to the OEM ecu, do some light load driving to pass all the OBD-II monitors and show emission readiness. I'd go in for my inspection, then go back home and swap back to the big injectors and give fuel/spark control back to my programmable ecu.
The injectors in my car are incapable of delivering the tiny amount of fuel required for a 14.7:1 AFR mixture at idle and very light loads, which would be required to prevent the toyota ecu from detecting an overly-rich condition. I also do not have an operating switching O2 sensor in my setup, which would be required for fast-closed loop control that dithers back and forth from rich to lean, right around 14.7 all the time.
2. By upgrading injectors to newer, fancier units with faster response and better low-fueling characteristics - and adding a switching O2 sensor, I believe I'd be able to satisfy my OEM toyota ECU "watchdog" - fooling it into thinking it was, itself, doing a fine job of fueling the engine.
...all of this obviously assumes you have a good working catalyst and all your OEM pre/post O2 sensors in place...
Hodgdon Extreme is offline
Nicks IS300 Turbo Re-build v.2 BNort2310 Member Build Threads - Lexus IS only 310 03-01-2017 09:34 PM
Jzx110 is300 1jzvvti swap Jzxdon Go Faster 2 09-08-2016 11:15 AM
2002 IS300 1jz-gte swap and engine management question LxBeef Go Faster 4 03-14-2016 06:50 PM
Not happy with my is300 Sanfou300 General Discussion 19 01-13-2016 01:14 PM
