Emanate Ultimate beginner - Lexus IS Forum
post #1 of 15 (permalink) Old 03-09-2019, 10:57 PM Thread Starter
Quoted: 79 Post(s)
I recently just purchased a used Greddy emu and was wondering if anyone has a diagram on how to set the jumpers in the emu? Also where can I get the program so I can load it to my laptop. I found the thread for the wiring for my 01. On the wiring, am I tap into each wire or am I cutting and wiring straight to the emu on some? I would get the pnp harness but all I hear is bad experiences with them. Also do I need the Map sensor on the IS300? Any help with this is greatly appreciated.
This is going to be installed on my 2001 IS300 with the CX racing turbo kit. I will be upgrading the fuel pump, injectors to 330cc, and adding a fuel return and fpr. I will also be installing the O2 sensor simulator. I already have the valve body upgrade with transmission cooler.
allturbo98 is offline
post #2 of 15 (permalink) Old 03-10-2019, 06:39 AM
Quoted: 338 Post(s)
The PNP harness is fine from Boomslang other than one wire. But any way. If it did not come with the disck. I think I have a compressed file I can send you. PM me you email. As for the jumpers. It has been a while. I do not have a picture or listing. I would need to pull one out to tell or show you. It may take a while to do that. Sorry.. Hopfully someone else here can help.
post #3 of 15 (permalink) Old 03-10-2019, 10:43 AM Thread Starter
Quoted: 79 Post(s)
Only one wire is the problem? Maybe I might look into that. I just hear that everyone that gets the Boomslang harness have issues. PM sent
post #4 of 15 (permalink) Old 03-10-2019, 04:06 PM
Quoted: 338 Post(s)
Yeah one wire. That they ran to the greddy. But it screws with the tranny on the auto. Not sure on the stick. But ether way. You do not need it.
post #5 of 15 (permalink) Old 03-10-2019, 10:05 PM Thread Starter
Quoted: 79 Post(s)
I might look into getting the pnp harness if that’s the case. What about the VVTi? Does it cause any problems with that?
post #6 of 15 (permalink) Old 03-11-2019, 11:04 AM
Quoted: 338 Post(s)
No, Just the one issue on the 2001.
post #7 of 15 (permalink) Old 03-11-2019, 09:30 PM Thread Starter
Quoted: 79 Post(s)
Do I need the Greddy injector correction adapter?
post #8 of 15 (permalink) Old 03-11-2019, 11:28 PM
Quoted: 144 Post(s)
Nope. Just cut the injector wires and splice the emanage in between the stock ecu and injector.
Kris OK is offline
post #9 of 15 (permalink) Old 03-12-2019, 12:24 PM Thread Starter
Quoted: 79 Post(s)
Does anyone have a base Map tune for the emanage ultimate? Maybe some tune maps as well so I can get a starting point for mine.
post #10 of 15 (permalink) Old 03-12-2019, 03:18 PM
Quoted: 338 Post(s)
Once you set the settings. Everything is at 0 change. That is where you build from. Any map you get will be different than your motor and use. I remember seeing a few maps uploaded on the forum. But I think they are turbo maps.
post #11 of 15 (permalink) Old 03-12-2019, 06:54 PM Thread Starter
Quoted: 79 Post(s)
Does anyone know if the harness for the EMU would have the original colored wires in different places or moved around? Would a plug n play harness do that? I got the EMU with a plug and play harness from a RX8 so a lot of wires are not the same color or in the same place as a original harness. Just wanting to make sure if this is common?
ID:	122951   Click image for larger version
ID:	122953   Click image for larger version
post #12 of 15 (permalink) Old 04-12-2019, 06:08 AM
I have a emanage ultimate installed on a 2JZGTE VVTI
i had 3 issues before i had it running 100%
1. The jumper JP8 needs to be move from 5V to 12V so the car can start "JP8 Ignition Output Signal - This jumper will configure the Ignition output signal. Set to “1-2” for 5V system and “2-3"
2. Don't connect Pin 32 'Knock Signal 1 / Water Temp Signal' and Pin 38 'Knock Signal 2 / Intake Temp Signal' to the Water and Intake wire in the ECU since i think the emanage is adding resistance to the signal and will cause the ECU to see a lower temp and the car will think that the car is cold and will run rich and high RPM at IDLE since the ECU think the car is COLD. you can use those 2 pin to connect the ECU knock sensors
3.Don't use the Speed Cut Feature pin 40 and 41 in a AUTO car this will only work on a manual, you don't need this in a USDM since they are not limited to 180 like the JDM cars
dilosolid is offline
post #13 of 15 (permalink) Old 04-12-2019, 09:37 AM
Quoted: 338 Post(s)
allturbo98 I got the EMU with a plug and play harness from a RX8 so a lot of wires are not the same color or in the same place as a original harness. I guess you did not want a Boomslang. As far as colors of wires. Do not look at that. Just identity the wires by the pin out.
Careful & Consistent
post #14 of 15 (permalink) Old 04-29-2019, 01:57 PM
Hi, I have used Greddy ultimate for sale coming with is300 map in there, come harness and boomslang.I running N/a , aftermarket header, air intake, bc cam, no cats, 2,5 in pipe and can come out 220 hp.
Let me know if interested .
Thank you,
Dicky_tan
dicky_tan is offline
post #15 of 15 (permalink) Old 04-29-2019, 02:36 PM
Quoted: 229 Post(s)
Thank you,
Dicky_tan
make your FS thread instead of advertising your stuff in different threads.
Lucy; 04 manual sportdesign
mesooohoppy is offline
Greddy ultimate and misfiring why ?????? Flipz_is300 General Discussion 5 08-24-2017 11:45 AM
MICHELIN Pilot Sport A/S 3+ | The Ultimate in UHP A/S Discount Tire Discount Tire 1 05-05-2016 03:13 PM
Anyone running GReddy E-Manage Ultimate on a N/A is300? Turbo18psi Go Fast Stuff 1 02-29-2016 02:40 PM
