Aristo Swap Lean Idle - Lexus IS Forum
post #1 of 4 (permalink) Old 12-28-2018, 02:42 PM Thread Starter
Hello,
Just completed the aristo swap in my 2003 is300. Iím using the stock aristo ecu and have a single turbo. When I start the car, the idle would drop below 500 and car would show 18+ AFR but when I rev it a bit AFR will show around 14.7 then jump back to 18+ and idle low. When Iím cruising around AFRs would stay in the 14-15 range and when I get into boost around 12-13. Seems only when itís idling or let off throttle it would just lean out. Any pointers would be appreciated thanks.
Relk is offline
post #2 of 4 (permalink) Old 12-28-2018, 03:57 PM
Quoted: 144 Post(s)
Did you do a fuel return? And if so what is the base fuel pressure?
Also where is the MAF - pre or post - turbo?
I wouldn’t boost it til you fix it. 13 is too lean. You shouldn’t hurt it at idle with no load while you’re sorting it out. Decel lean-out is pretty normal, your cruising A/F are pretty normal too.
Kris OK is offline
post #3 of 4 (permalink) Old 12-28-2018, 07:42 PM Thread Starter
Yea Iím using the aristo sending unit with 5/16 return line. Running Aeromotive 340lph fuel pump. Have not checked fuel pressure, using stock fuel pressure regulator.
My air flow meter is post boost connected to the pipe just before the throttle body.
Relk is offline
post #4 of 4 (permalink) Old 01-03-2019, 05:22 PM
Quoted: 144 Post(s)
Okay. I’m pretty sure the MAF is pre turbo in an Aristo...now whether that’ll cause your problems I don’t know. But it might.
Aristos have an fpr on the injector rail. So that is what you’re using? I’d go for an aftermarket Aeromotive fpr, and bigger injectors. You possibly are running out of fuel on the stock 440ccs and single turbo causing leanout in boost.
Kris OK is offline
2001 Manual Aristo Swap boostdreams Go Faster 0 04-09-2018 11:01 AM
Aristo swap in limp mode day General Discussion 0 02-16-2018 02:02 PM
FIC issues with aristo swap (stock twins) Leaning out at high RPM rude_boyja Go Fast Stuff 18 12-11-2017 12:20 PM
Need a shop in NYC to do clean straight Aristo swap to my 03 IS300 L.1.3 Go Faster 4 05-04-2016 06:07 PM
