Any interest in 3.5 dia intakes - Lexus IS Forum
 4Likes
post #1 of 17 (permalink) Old 02-07-2019, 03:54 PM Thread Starter
Quoted: 340 Post(s)
I have been researching building a 3.5 inch diameter intake with signal conditioner.
I am sure I can do it. I am gauging interest at the moment. No one currently makes one. The last company was SRT. I do not know cost at the moment. Still figuring out materials. Please post if there is some interest.
black86 likes this.
post #2 of 17 (permalink) Old 02-08-2019, 12:05 PM
I'm somewhat new to the platform here, but not new to performance cars, as I've driven/modded everything from old GM musclecars to turbo Mustangs to German imports. IMO, I personally don't see a huge advantage (at least for NA applications) in running a 3.5" intake pipe when overall airflow is still limited by the MAF sensor and TB size, etc. I could be totally off base here, but past experience tells me that the system will only flow as much as the smallest choke point. I'm open for discussion though!
lexa$$01 is offline
post #3 of 17 (permalink) Old 02-08-2019, 02:24 PM
Quoted: 596 Post(s)
I've seen people on Facebook still wishing for SRT intakes
post #4 of 17 (permalink) Old 02-09-2019, 06:37 AM Thread Starter
Quoted: 340 Post(s)
I hear you. But it has been proven with the old SRT intake there is a slight gain with the stock throttle body. But as I said I will re calibrate the signal for the larger pipe. I am also looking at the people that run the 80mm throttle body upgrade. I will also be looking at doing a sheet metal larger intake Y. I already know I should be able to do a signal conditioner. But I am also looking at doing a better deal. Like a pro meter direst mapping. For N/A and forced induction.
My background is also in the performance domestic and import industry. I have and am building several different setups. I use to do this stuff with several others for a job. Now I am sort of retired.
post #5 of 17 (permalink) Old 02-09-2019, 06:39 AM Thread Starter
Quoted: 340 Post(s)
I do not go on that platform for the IS300/GS300 stuff. I guess if you do. Give them a heads up to watch for all the products I am working on.
post #6 of 17 (permalink) Old 02-12-2019, 02:33 PM
Quoted: 596 Post(s)
I don't barely touch/use the website either. I just happened to see it on the homepage of my feed once. If I can see it there, that means the demand must be real. Facebook is where it's at though, if only I felt like getting into things there
post #7 of 17 (permalink) Old 02-13-2019, 08:14 AM
I can maybe see where a larger intake pipe for ppl building like a max effort FBO NA car (as you indicated) may be useful, but I'm still of the opinion that a modified factory airbox is best for 90% of mildly modded folks. I believe that I even recall that someone posted up that they lost a good bit of performance off of their 0-60mph time w/an SRT pipe. Maybe you gain it back it at higher speed, but I haven't seen that data? Anyway, plz don't take my comments the wrong way, as I applaud yours or anyone's efforts to do stuff like this! I'm actually curious to hear more about your proposed sheet metal upper y-intake as well man!
lexa$$01 is offline
post #8 of 17 (permalink) Old 02-13-2019, 11:40 AM Thread Starter
Quoted: 340 Post(s)
The sheet metal Y. Was something I have been toying with for a while. The factory Y is a bit of a bottle neck. Especially if you go to the 80mm throttle bay off the LS.. It is funny I mentioned it a while back. But no one was even interested. That is why I put it on the back burner for a bit.
I know the result you are referring to on the intake pipe size. The torque drop is from the free flow of air and the fuel map and timing map. Unfortunately there is not a simple way to modify the timing map. So you must (fudge) it as much as the system will allow without hurting the over all power.
post #9 of 17 (permalink) Old 02-13-2019, 05:32 PM
Ya, I just more or less joined the forum...been lurking for a while and reading up on NA mods stuff. Please post up any progress on the sheet metal Y intake...would love to read/hear more about it!
lexa$$01 is offline
post #10 of 17 (permalink) Old 02-13-2019, 06:20 PM Thread Starter
Quoted: 340 Post(s)
I will let everyone know when I get back to it. When it comes down to it. I am retired and just like doing this stuff. It is hard to stop doing it after 33 plus years of doing it.
TobiasSing likes this.
post #11 of 17 (permalink) Old 02-13-2019, 10:13 PM
Quoted: 32 Post(s)
I would like to add food for thoughts here, a pretzel maybe
removing the Y intake and fitting either sheet metal or custom cast alloy intake between the TB and the runners is a normal practice in the UAE, HP figures are 300+ WHP or even more on a heavily massaged heads in either NISSAN TB48 or TOYOTA 1FZFE, below photos are courtesy of Hamad81333 on Instagram, eye candies
ID:	122533   Click image for larger version
ID:	122535   Click image for larger version
ID:	122537   Click image for larger version
ID:	122541   Click image for larger version
ID:	122543   Click image for larger version
ID:	122545   Click image for larger version
ID:	122549   Click image for larger version
Arzon is offline
post #12 of 17 (permalink) Old 02-14-2019, 01:19 AM
Location: 87.9 mi Ė about 1 hour 42 mins from east parking lot
Quoted: 48 Post(s)
forgot the intake manifold--look at those exhaust manifolds!
sauce
MAZZURI V2|toke'd
'03 MSM 5MT N/A
ae86 zenki liftback
mx72 zenki wagon
VOLKS FOR SALE!
black86 is offline
post #13 of 17 (permalink) Old 02-14-2019, 06:21 AM Thread Starter
Quoted: 340 Post(s)
Arzon Food for thought. I may do something like that as another version. If The first works well and looks like there is a need.
post #14 of 17 (permalink) Old 02-14-2019, 09:22 AM
Quoted: 33 Post(s)
I can help post on the FB groups... I'm part of a few of them (though not super active), but I can post and vouch for you and redirect them here if you plan on making an intake.
The market will be big because a lot people that I've seen in the groups aren't educated enough and/or can't afford to go FI or swap, so they buy into the NA mods. If you built a prototype and had some dyno figures with gains, then I'm sure your inbox will be flooded with PM's on orders. (You could do a pre-order at that point to jumpstart your business)
Arzon likes this.
toneekay is offline
post #15 of 17 (permalink) Old 02-14-2019, 10:08 AM
Quoted: 48 Post(s)
located in socal? I helped Danielm prototype the mazzuri header. I'm in love with n/a
sauce
MAZZURI V2|toke'd
'03 MSM 5MT N/A
ae86 zenki liftback
mx72 zenki wagon
VOLKS FOR SALE!
black86 is offline
3.5 stroker experiences 02is5spd Go Faster 24 01-31-2016 09:26 AM
