When to replace fuel filter? - Lexus IS Forum
post #1 of 9 (permalink) Old 03-29-2019, 04:12 PM Thread Starter
Quoted: 16 Post(s)
Some say it’s a lifetime filter. Have 200k on is 300, should I replace filter? Thnks
Beeeastman1 is offline
post #2 of 9 (permalink) Old 03-29-2019, 09:12 PM
Quoted: 359 Post(s)
Follow the rules. Double posting is not cool and will not get you an answer quicker.
post #3 of 9 (permalink) Old 03-30-2019, 04:58 PM
Quoted: 112 Post(s)
There is no filter. But its a good idea to replace the fuel pump as they tend to fail before 200,000 miles.
-- Pres. George Washington
Real gun stats will shock you
IM QUIKR is offline
post #4 of 9 (permalink) Old 03-31-2019, 11:19 AM
Quoted: 792 Post(s)
There is no filter.
The filter is the plastic thing that surrounds the pump in the tank. I replaced mine when I replaced my pump. If the pump has failed, it's probably a good time to replace the filter.
post #5 of 9 (permalink) Old 06-25-2019, 07:55 AM Thread Starter
Quoted: 16 Post(s)
Will changing the plastic filter housing extend the functioning of the pump?
post #6 of 9 (permalink) Old 06-25-2019, 02:46 PM
Quoted: 359 Post(s)
Possibly, But if you go that far. Why not replace all of it.
Careful & Consistent
post #7 of 9 (permalink) Old 07-04-2019, 03:03 PM Thread Starter
Quoted: 16 Post(s)
So the consensus is to leave it? Or replace the filter as preventative maintenance?
post #8 of 9 (permalink) Old 07-04-2019, 10:05 PM
Quoted: 148 Post(s)
At that mileage, I would replace it. It’s cheap, like 30-40$, and not hard to do. I guess it could prolong the pump lifespan, by having less head pressure to overcome due to a maxxed out filter. I’d think the pre-pump strainer sock would affect pump life more than the post-pump filter. It’s more for the injectors than anything. On that note, there’s probably way more IS300’s on the road running the original fuel filter vs a replacement, so I’m sure it’s not a must-do maintenance item. But I would totally do it. Take not of all the little pieces and o rings and make sure they go back where they belong.
Kris OK is offline
post #9 of 9 (permalink) Old 07-05-2019, 10:59 AM
Quoted: 792 Post(s)
My take is that if you're not getting "lean" codes that you traced to low fuel pressure, that it's probably not needed. If it's plugged, you'll know it. Either the car won't run or you'll get codes.
Maybe it improves the fuel pump life. Mine lasted 250K miles on the original filter.
Replace fuel filter on is 300? When? Beeeastman1 Basic Help & Repair 3 03-30-2019 05:59 AM
blkaltezza's build blkaltezza Member Build Threads - Lexus IS only 349 03-05-2018 02:18 PM
White 2003 Lexus IS300 Build Thread **HD Pix** White2003Lexus General Discussion 188 07-04-2017 11:24 AM
Fuel Injector O-ring Seal kit. homedepotmade DIY/tutorial forum 0 08-08-2016 08:42 PM
