VVTI cam gear question - Lexus IS Forum
post #1 of 7 (permalink) Old 10-20-2015, 06:55 PM Thread Starter
I already had my timing belt changed so I am wondering if you can replace the vvti cam gear without having to remove the timing belt. The car is a 2001 with about 99000 miles on it. The cam gear has NOT started to leak yet any ideas as to when this cam gear will start to leak?
dannyboy89 is offline
post #2 of 7 (permalink) Old 10-20-2015, 07:24 PM
mm71522's Avatar
Quoted: 353 Post(s)
Its probably possible if you loosen the tensioner, but very difficult to do it that way.
Every car is different but I would say around 125K-150K is most common? Mine didn't leak till ~170K.
Mike
'02 AR IS300; M98 L-Tuned
TOKICO HP/TANABE NF210
ENKEI KOJIN 18X8.5+35/9.5+30
DIY: Nav+Aftermarket HU
DIY: Timing Belt
My Thread
mm71522 is offline
post #3 of 7 (permalink) Old 10-20-2015, 08:25 PM
Quoted: 32 Post(s)
You do have to remove atleast half the belt ( both cam pulleys ) leave bottom half on.. Mark belt remove tensioner and go from there...
IS_416 is offline
post #4 of 7 (permalink) Old 04-20-2016, 01:00 PM
I'm going in for the 90k service on my 2004 IS and the shop is recommending replacing the VVTi gear and water pump at same time. I agree with the water pump, but first time hearing about the VVTi gear. Service manager says he often sees VVTi gears leaking on the old IS / GS and cheaper to replace with timing belt (save half the cost). Any thoughts or help?
theazian is offline
post #5 of 7 (permalink) Old 04-20-2016, 08:22 PM
Quoted: 128 Post(s)
mine leaked at around 100k.
In this case, I'll save you some money/time and agree with your mechanic. It's best to replace both to save on additional time spent going in there.
That's if you're gonna keep this car for the long run. If not, sell it now cuz that thing will leak and cost you a good amount of money.
2001 auto eshift, Mileage 107891, Joe Z intake, Enkei RS7 wheels 17x7 ET42 Silver w/Polished Lip, 215/45/17 Michelin pilot sport A/S3 tires, Tein S tech springs, Bilstein HD shocks, Figs front LCA #2 poly bushing, New OEM front ball joints, Figs Rear toe links, Eibach Rear sway bar, Figs Rear sway bar end links, Carbon fiber Rear strut bar, Figs Rear sport mega arms, Figs Rear knuckle bearings
stuis is offline
post #6 of 7 (permalink) Old 04-21-2016, 08:15 AM
Quoted: 10 Post(s)
agreed, go ahead and get it done now.
'02 BD1 8N8 MLSD 143k - cruiser
'07 Accord SE - commuter
htekken is offline
post #7 of 7 (permalink) Old 04-21-2016, 08:41 AM
Quoted: 795 Post(s)
If you're going to do the gear, I'd do the cam seals too which are right behind the gear.
Personally, I think the cam seals are far more likely to leak than the VVTI Gear.
Ek9B18 is online now
VVTI Cam gear vid question... FrankieCarbone General Discussion 4 12-15-2014 08:27 AM
Think I Need A New Vvti Cam Gear jdub_gsx General Discussion 10 10-28-2012 09:12 PM
vvti cam gear? HolocaustOfThought Go Fast Stuff 6 10-17-2006 09:23 AM
