Throttle jerk off the line or slow speeds - Page 3 - Lexus IS Forum
post #31 of 34 (permalink) Old 02-28-2019, 11:53 AM Thread Starter
Quoted: 35 Post(s)
Originally Posted by Pnut00 View Post
If you are getting a cel for an o2 sensor it could well be that, they will cause bogging and spluttering with incorrect air fuel etc. Even if its intermittent cel i wouldn't rule it out, could be loose or broken wires in the sensor or the connections, heater wires, etc. that touch and then move apart again.
Would it be so consistent though? Like it has never ever sputtered or bogged other than when im going a low speed or pulling away from a stop sign and (like the other guy said) im trying to apply smooth normal throttle. Has happened for years even when I never did have this CEL.
Originally Posted by Baube View Post
My winter beater does what you describe. it only does it when I try to accelerate at a slow rate. If I smash the pedal or go maybe above 50% throttle the issue doesn't seems to appear.
it have been doing it since I bought it 3 years ago.
I always tought it was because the previous owner replaced the O2 sensors with some cheap generics ones and it was messing with the air fuel. I can't remember if I cleaned the TB when I did the timing belt back then.
the issue did went away for a while when I installed a SRT intake with race ecu, but came back 6-12month later
Probably same problem. That sucks
2002 IS300. Auto, Intensa Blue Pearl, Factory LSD, Stock.
treehunna is offline
post #32 of 34 (permalink) Old 02-28-2019, 09:19 PM
Quoted: 131 Post(s)
Hard to know for sure, but having the cell flash on for it is something worth checking out. When my o2 went on the As200 i had it would always bog and cough at low revs like the mix was too rich, it didn't throw a code till a day or 2 later.
2001 Altezza Gita JCE10
Pnut00 is offline
post #33 of 34 (permalink) Old 03-06-2019, 07:44 PM Thread Starter
Quoted: 35 Post(s)
So, finally had the throttle body cleaned. Fixed the issue. It's much smoother now. As long as it doesn't come back, I'm super happy.
post #34 of 34 (permalink) Old 03-07-2019, 09:46 AM
Quoted: 26 Post(s)
I'll give it a try too when the wheater won't be freezing cold up here
thanks for the follow-up
Baube is offline
*New Find*Throttle Lock Xcessive Manufacturing IS-2JZ Go Fast Stuff 51 10-29-2018 08:18 AM
DIY: TB coolant line delete. az989 Go Fast Stuff 13 01-22-2017 04:00 PM
