Steering feels super stiff - pump? rack? psi? - Lexus IS Forum
post #1 of 10 (permalink) Old 05-16-2019, 07:16 PM Thread Starter
Quoted: 14 Post(s)
Steering feels super stiff in my 02 is300.
About 6 months ago, noticed my rack was leaking. Got an ebay used rack for around $100, had it installed by a shop only for the steering to feel horribly stiff afterwards. Shop told me it should loosen up a little after driving. Brought it to a different shop a week later that said it was definitely a bad rack. So they swapped it out, assuming with another used rack, steering still felt horrible. Brought it back three times to the same shop, complaining about how stiff the steering was. They changed out my lower ball joints. Didn't change anything. Went to a different shop, had my power steering flushed. It felt a little better for about a week then back to stiff.
I'm running rpf1 18x9.5 up front on 225/40, in the rear 18x10.5 on 255/35 with no spacers. The tire/alignment shop I use recommended 39psi up front and 35psi in back, does that same super high?
Not sure what to do next, I'm thinking either the power steering pump, wrong psi, or worse, another rack which would be my third this year, maybe get a new one instead of used. Never changed my upper controls and could probably use a full bushing refresh up front, because its never been done and have 183K miles on it, but its so bad I almost sold the car last week because it feels like a witch hunt trying to figure out the problem. Any help greatly appreciated! Happy with how the car looks finally, but hate driving it with this issue, I'd compare it to driving a 15ft uhaul or some huge truck.
02 GGP 5spd - BC BR Coilovers, Dezod Green Headers, Stoptech SS Brake Lines, Hawk HP pads, Monster Service +40mm Front Fender Flares, Monster Service +30mm Rear Fender Flares, Fiber Fab Ducktail, Eibach Front/Rear Sways, Sport Design Headlights, Enkei Rpf1 F: 18x9.5+15 Federal 225/40/18 R: 18x10.5 +15 Toyo Proxes HP R-255/35/18
dhaney85 is offline
post #2 of 10 (permalink) Old 05-16-2019, 07:48 PM
Quoted: 339 Post(s)
Make sure line are hooked up to the right port. As far as pump. If you disconnect the lines and it feels the same. It may be the pump.
Careful & Consistent
post #3 of 10 (permalink) Old 05-19-2019, 12:22 PM Thread Starter
Quoted: 14 Post(s)
Got a used pump from a friend that worked just fine, will install next week, it didn't come with this little banjo bolt, is this necessary to replace? Can't seem to find the part number anywhere.. Is this bolt needed just for the lexus gs not is? Pic is from ebay and not the pump I got.
Name:	Screen Shot 2019-05-19 at 11.19.36 AM.jpg
dhaney85 is offline
post #4 of 10 (permalink) Old 05-19-2019, 03:05 PM
Quoted: 339 Post(s)
I would need to look. I can not remember.
post #5 of 10 (permalink) Old 05-19-2019, 04:07 PM
Quoted: 46 Post(s)
looks like both IS and GS use union bolts. let me know if you can see the p/n
sauce
MAZZURI V2|toke'd
'03 MSM 5MT N/A
ae86 zenki liftback
mx72 zenki wagon
VOLKS FOR SALE!
black86 is offline
post #6 of 10 (permalink) Old 05-19-2019, 04:08 PM
Quoted: 46 Post(s)
side note: look how much more cooling and fluid the GS power steering has... I'll be installing a power steering fluid cooler. it bubbles over at the track
sauce
MAZZURI V2|toke'd
'03 MSM 5MT N/A
ae86 zenki liftback
mx72 zenki wagon
VOLKS FOR SALE!
black86 is offline
post #7 of 10 (permalink) Old 05-19-2019, 08:36 PM
Quoted: 782 Post(s)
I installed one on my car because there was no room for the factory cooler. It seems to make the pump whine. I think it's restrictive. The GS and IS coolers seems to be close to the same size.
As for the banjo bolt. You just use the one that's already on your IS. I'd have to compare the tanks too. Maybe swap them over. The GS has far more room under the hood than the IS.
post #8 of 10 (permalink) Old 05-19-2019, 09:45 PM
Quoted: 46 Post(s)
there's more piping in the GS. just having that extra fluid helps in cooling I bet
sauce
MAZZURI V2|toke'd
'03 MSM 5MT N/A
ae86 zenki liftback
mx72 zenki wagon
VOLKS FOR SALE!
black86 is offline
post #9 of 10 (permalink) Old 05-21-2019, 11:11 AM
Quoted: 142 Post(s)
If the power steering system checks out, I'd look at replacing the upper ball joints. Especially on a low car that has probably had the upper control arms smashing the shock tower at some point. As you might know already, the upper and lower ball joints hold the spindles in place allowing them to rotate with any steering rack movement.
Piggity is offline
post #10 of 10 (permalink) Old 05-21-2019, 03:53 PM
Quoted: 231 Post(s)
you can re use banjo bolts as long as they appear to be in good condition. its the crush washers they utilize that you should not re-use.
Lucy; 04 manual sportdesign
mesooohoppy is offline
Strong Flex Bushing Review and Comparison to Super Pro mesooohoppy Stop, Drop and Roll 49 02-26-2019 11:17 AM
Steering Rack Bushes/Grommet HELP! IS200/ALTEZZA dont know what ones to buy? Boogatee Basic Help & Repair 4 10-23-2017 08:41 PM
IS300 Power Steering Pump Fix? weekendwarrior Basic Help & Repair 4 04-29-2017 11:58 AM
HELP to solve power steering pump problem @ high rpm engine w/ ATI crank pulley RoadRash Go Faster 9 04-17-2016 12:35 AM
