Replacement Water Pump Kit - Best? - Other Bolt-On Mods to attack? - Page 3 - Lexus IS Forum
 28Likes
post #31 of 42 (permalink) Old 04-30-2019, 07:07 PM
Quoted: 132 Post(s)
Just so i am clear, did you adjust your shims or can you just throw those cams in and the clearances still match the OEM cams?
2001 Altezza Gita JCE10
Pnut00 is offline
post #32 of 42 (permalink) Old 04-30-2019, 11:56 PM
Quoted: 32 Post(s)
Originally Posted by Posh469 View Post
The price jumped to $205.00USD so I purchased the lovely Purple HKS Adjustable Cam Gear for $175.00USD Shipped! :D Score!
Originally Posted by TobiasSing View Post
Wow $200? Yeah when I bought it, it was only $100 lol. Good parts though
Hmm, makes me wonder just how good of a deal I got when I got my generic 5 bolt adjustable 2JZ ECG for only $15 shipped
DH_71631 is offline
post #33 of 42 (permalink) Old 05-01-2019, 06:14 AM
Location: 87.9 mi Ė about 1 hour 42 mins from east parking lot
Quoted: 50 Post(s)
man, I just did a 90k along with cam and valve gaskets to get my car ready for the track. I should of considered this since it was cracked wide open. maybe next 90k. looking good tho! post a Dyno if you have a chance
Posh469 likes this.
sauce
MAZZURI V2|toke'd
'03 MSM 5MT N/A
ae86 zenki liftback
mx72 zenki wagon
VOLKS FOR SALE!
black86 is offline
post #34 of 42 (permalink) Old 05-01-2019, 08:06 AM Thread Starter
Shim clearances were checked.
None are loose - one is a little tighter but still within spec.
- Essentially plug and play.
black86 likes this.
<3 IS LUV <3
Posh469 is offline
post #35 of 42 (permalink) Old 05-01-2019, 08:18 AM Thread Starter
I wish, but I didnt have a dyno done prior to the install so nothing to readily compare.
Plus, after all this work its not like were talking a ton of added HP. So I am not sure what the real before and after difference will be other than an audible one or as most say here the "Butt Dyno".
From other people's reviews, it seems like it simply will make the car a bit more peppy.
- I am more curious to see if the VVTI will improve - albeit when it kicks in it has always been a negligible difference but the VVTI Solenoid was cleaned and VVTI Cam Gear completely replaced with a new OEM one. - For whatever reason, I started to feel a real dip in the powerband in 4th gear around 3K prior to the install - would like to see the powerband there improve.
- Eventually, I'd like to get rid of my wheel spacers as theyre simply adding to more unsprung weight.
Some smaller wheels would have also been a more proactive approach as well; but seeing as I purchased the wheels years ago I lacked any longterm vision of this car.
black86 likes this.
<3 IS LUV <3
Posh469 is offline
post #36 of 42 (permalink) Old 05-01-2019, 08:48 AM
Quoted: 50 Post(s)
I hear ya. I'd love to get more oomph out of the turns. but I've gotta work on the suspension more since more power will make things even worse with the current setup yeah, I've gotta run adapters since my track tires are on 5x100 wrx wheels... looking to go 245/40 on 17x9 +35 or 255 if it'll fit
what wheel/tire do you have? track, street, drag? just wondering &#x1f60a;
sauce
MAZZURI V2|toke'd
'03 MSM 5MT N/A
ae86 zenki liftback
mx72 zenki wagon
VOLKS FOR SALE!
black86 is offline
post #37 of 42 (permalink) Old 05-01-2019, 11:20 AM Thread Starter
Some cast cheapos:
Motegi Racing Mr119 18" x 8.5"
Michelin AS Pilot Sports
Ichiba Wheel Spacers (+15mm Front - +25mm Rear)
<3 IS LUV <3
Posh469 is offline
post #38 of 42 (permalink) Old 05-01-2019, 11:21 AM Thread Starter
Alternator and Purple Aluminum Pulleys on.
black86 and TobiasSing like this.
<3 IS LUV <3
Posh469 is offline
post #39 of 42 (permalink) Old 05-08-2019, 07:17 AM Thread Starter
Closing out this thread.
Replacement of the Water Pump and Installation of the BC Cams was a success. It was nice seeing all the old rusted parts come off and get a few bolt-on mods going down at the same time.
- The only real unforseen was replacing the OBX Underdrive Pulley with a Fluidampr one - not cheap but in the end it was money well spent.
- Now using some break-in oil for the next 200 miles before I open her up and see how she really sounds.
For now, the HKS Adjustable Gear has been set at 0į - just for the initial break-in period.
- Then I hope we can retard it a little and get some more lopes. Haven't really reved the car but the exhaust sounds a bit more crackely under low revs. (Trying not to exceed 4K RPM)
Does anyone know if the Megan Mid-pipe's resonator section adds more rasp?
- I'm sure a majority is coming from the Headers but Wondering If I should delete that section of the megan racing mid-pipe? Thoughts?
Thanks for the support everyone!
<3 IS LUV <3
Posh469 is offline
post #40 of 42 (permalink) Old 05-08-2019, 10:28 AM
Quoted: 237 Post(s)
Interesting choice to cut open the cam gear cover like that.
surely you've seen this before? it allows you to verify what your gear is set at.
Lucy; 04 manual sportdesign
mesooohoppy is offline
post #41 of 42 (permalink) Old 05-08-2019, 03:43 PM
Quoted: 605 Post(s)
it also allows dirt and junk to enter the timing belt and gears and pulleys...
I have seen it left exposed, but usually it's just with the cover off or something exposing both gears, I've never seen it cut perfectly like that. I guess I never thought I had to cut mine to verify the gear. I set it, and forget it.
post #42 of 42 (permalink) Old 05-09-2019, 09:35 AM
Quoted: 237 Post(s)
yes of course, im just saying its still popular among jzx owners who want to show off their shiny cam gears. also along the lines of people not putting filters on their turbos or ITBs.
TobiasSing likes this.
Timing belt and Water Pump Brian2900 Basic Help & Repair 3 07-19-2019 07:31 PM
Water pump lucky_300 General Discussion 2 09-03-2018 10:46 AM
Oil leaking onto water pump Heykw General Discussion 6 05-21-2018 02:52 AM
Noise after Timing Belt and Water Pump Service bradleyhenry94 General Discussion 8 09-19-2017 05:39 AM
Leaking water pump pcjohnson_ohio General Discussion 3 04-05-2016 08:36 AM
