Over Pressurized Cooling System - Lexus IS Forum
  • 1 Post By Ek9B18
post #1 of 5 (permalink) Old 04-08-2019, 07:44 AM Thread Starter
So I've had a mysterious coolant leak for the last few months that I haven't bothered much to try & track down. Just top off the reservoir & move along. Well a couple weeks ago I decided to pressure test the system & see if I could track down the leak. Car off, pump the tester up to 15psi & let it hold for 10 minutes. Didn't budge. So I relieved the pressure, then hooked the gauge back up. Started the car up. Within 15-20 minutes she'd spiked up to 29psi before I finally had had enough & wasn't trying to push it any further.
It looks/feels like a standard head gasket blown. But I'm just not trying to dive into that without doing a little more research. It's got 188k on it, I just did the timing belt/water pump two years ago & have never had any issues with over heating.
I'll do a compression test before I start the tear down just to check everything else. I've already got my head gasket kit & new head bolts sitting here waiting for me to start. But I figured I'd check in & see if there's any other (far flung) idea that might be the cause.
Thanks.
Nates78ski is offline
post #2 of 5 (permalink) Old 04-23-2019, 09:41 AM
I would think head gasket also. Not on my IS, but on my older Civic, I had a mysterious coolant loss like this. Wasn't burning, it would just keep overfilling the overflow and drain the radiator. The explanation I read was that the air pressure from the motor running is leaking air into the coolant system around the headgasket and pressurizing it, essentially pushing the coolant out of the system. I replaced my headgasket and the problem went away immediately.
Test the headgasket and see what your pressure is in each cylinder.
Skryblz is online now
post #3 of 5 (permalink) Old 04-23-2019, 11:15 AM
Quoted: 790 Post(s)
I'm thinking HG too.
Ek9B18 is online now
post #4 of 5 (permalink) Old 04-23-2019, 12:35 PM
Quoted: 80 Post(s)
Buy a test kit and determine if you're getting oil in the coolant or coolant in the oil.
Hodgdon Extreme is offline
post #5 of 5 (permalink) Old 04-23-2019, 02:41 PM
Quoted: 790 Post(s)
There are testers that look for combustion gases in the coolant too. I might start with that.
Hodgdon Extreme likes this.
Air bubbles in cooling system ricka58 Basic Help & Repair 18 01-28-2019 09:44 PM
Mishimoto Performance Cooling System - Overheat Troubleshoot Posh469 General Discussion 14 04-28-2017 05:17 AM
Brand-New SP Series Short Ram Intake System by Injen for 2016 IS CARiD CARiD.com 0 08-04-2016 06:18 AM
Mishimoto Performance Cooling System - Advise Needed! Posh469 General Discussion 3 07-26-2016 06:27 PM
Please help me with my air condition system sugafree General Discussion 0 01-07-2016 08:26 PM
