Need advice please!!! - Lexus IS Forum
post #1 of 10 (permalink) Old 03-16-2019, 06:29 PM Thread Starter
2015 Lexus is250 with 25000 miles on a clock.Went to 2 different Lexus dealer for service and had a question why my rotors are so corroded( rear one's) . As I'm assuming rear brakes don't work properly. Need advice what should I do. Picture attached. Thank you in advance
Denimtrust is offline
post #2 of 10 (permalink) Old 03-16-2019, 08:12 PM
Quoted: 36 Post(s)
seems you've got some blown seals in your calipers. your pistons a possibly seized due to water and rust. You should rebuilt them or have them rebuilt
Color: Cromax YR580M
TRD Carbon Fiber Shifter Ball
Fidanza Exhaust Cam Gear
SPC Rear Camber Kit
Continental ProContact Tires
Mathieu Bernier is offline
post #3 of 10 (permalink) Old 03-17-2019, 11:02 PM
Quoted: 24 Post(s)
wouldn't you have a warranty that will cover that? Lexus should hook you up on that one.
2004 Absolutely Red 5 speed
nismofan240 is online now
post #4 of 10 (permalink) Old 03-18-2019, 07:13 AM
Quoted: 796 Post(s)
Traction control on modern cars often makes use of the rear brakes. I'm thinking it looks like the front brakes aren't pulling their weight so the rears get over-used or that you're engaging traction control a bunch which wears out the rear pads.
post #5 of 10 (permalink) Old 03-18-2019, 10:46 AM Thread Starter
Well interesting fact that Lexus dealer said it's normal wear and tear. I really hoping you guys see at picture that one of brake pads is at 0% and another one at 70%. And both of this brake pads from one wheel
post #6 of 10 (permalink) Old 03-18-2019, 06:57 PM
Quoted: 362 Post(s)
Caliper is not moving freely.
post #7 of 10 (permalink) Old 03-20-2019, 11:19 AM Thread Starter
Kinda lost at this point. Front brake pads still good. Rear one's are gone and
uneven wear . Dealershipp telling me it's normal wear and tear and don't want to fix issue that involves exesive wear on pads
post #8 of 10 (permalink) Old 03-20-2019, 11:24 AM Thread Starter
And also car still under factory warranty. But dealership keep saying that everything functional proprerly in a rear brake system
post #9 of 10 (permalink) Old 03-20-2019, 01:17 PM
Quoted: 362 Post(s)
What is happening is the caliper is not moving freely on the pins. Remove the pins and clean the holes in the bracket out. Put new pins and boots with plenty of grease. When the pads wear uneven. This is because of this movement. Brakes 101. You can slap pads on all day long and it will do this everytime. Untill you do this. You will need new pads and rotors also.
post #10 of 10 (permalink) Old 03-20-2019, 03:20 PM
Quoted: 132 Post(s)
Agreed, start here. Mine had siezed on one of the pins when i bought it so had done something similar, not quite so extreme. Had to get another pin and caliper frame and use high temp antiseize grease on it to fix mine, the joys of floating calipers. Its not often a seal in the caliper would have gone and caused this kind of mayhem . . . though i guess it depends where you live, no snow or salt on the roads over winter where i live
2001 Altezza Gita JCE10
Pnut00 is offline
Moron Needs Wiring Advice Hokusai General Discussion 4 10-16-2017 06:16 PM
Buying my first Lexus IS300 (Need Advice) Oh Nah Its Vic General Discussion 19 02-14-2017 06:51 PM
IS300 in VA Beach, Needing 90K advice Vikeshiva16 New Member Introductions 1 02-09-2017 01:57 AM
Track Gurus - Alignment Advice su_maverick Stop, Drop and Roll 12 08-12-2016 04:55 PM
Need Advice on Wheel/Tire Combo SPIKEZis300 Wheels and Tires 3 05-04-2016 05:01 AM
