Multiple misfire issue - Lexus IS Forum
post #1 of 8 (permalink) Old 05-25-2017, 07:56 AM Thread Starter
Good morning everyone, I used to work mechanics years ago although not doing it for a while has gotten my diagnostic skills a little rough around the edges and would really appreciate some help!
I have a 2001 IS300 with 166K miles on it. I am receiving multiple misfire codes (P0300, P0301, P0302, P0304) with an intermittent misfire from cylinders 1, 2, and 4. It seems to misfire more at idle and when I apply a decent amount of throttle (tends to do it more after the engine is warm). I have pulled the plugs from cylinders 1 and 2 and they are sitting at the correct gap spec and don't look fouled at all. I pulled the intake off to look at the coils and it looks like each of the three coils handle one of the misfiring cylinders. I replaced the coil that direct feeds to cylinder 2 last night and today it seems no different in reducing the level of misfire.
I sprayed down the plug wires looking for shorts in the insulation and that all looked good. I am looking for recommendations on where to go next. I am going back and forth between throwing new plug wires in or replacing the corresponding fuel injectors. I listened to the injectors with a long screwdriver and they all seem to be ticking about the same sound.
Thanks!!
rdawg1985 is offline
post #2 of 8 (permalink) Old 05-25-2017, 08:58 AM
Quoted: 787 Post(s)
1 - Compression check
2 - Check cam timing.
3 - Clean the VVTI oil control valve.
post #3 of 8 (permalink) Old 05-25-2017, 12:49 PM Thread Starter
I will give those a check, thank you!
post #4 of 8 (permalink) Old 06-06-2017, 07:42 AM
I had multiple misfires a month ago. New plugs and ignition leads later and car is as happy as Larry.
funkmasterjay is offline
post #5 of 8 (permalink) Old 06-06-2017, 08:17 AM
If the car was running okay I'd start with ignition. Just to be sure I'd check the spark plugs for a blue spark. Pull the EFI fuse and then take the plugs out and while grounded (any metal part of the engine should do) crank the engine over and see. You should get very strong blue spark. Since none of those cylinders share the same coil it is probably not those. You check the ohm resistance of the coils also. I'm a fan of ruling everything out before spending money on parts. Good luck and let us know when you fix it!
ColonelShots is offline
post #6 of 8 (permalink) Old 06-06-2017, 08:21 AM
Quoted: 34 Post(s)
The 2JZ-GE does share 1 coil per 2 cylinders. 1 and 6, 5 and 2, 3 and 4.
02 IS300 | 5mt | LSD (174k Daily Driver)
01 Acura CL type-s | (132k miles Daily Driver)
08 WRX | 16g | E85 (Sold)
onsit is offline
post #7 of 8 (permalink) Old 06-06-2017, 08:23 AM
Right to clarify the op has misfires on 1, 2 and 4. That combination does not point to any one coil. If he had let's say cylinder 1 and 6 misfire that would be more like a coil output issue.
post #8 of 8 (permalink) Old 06-06-2017, 08:31 AM
indeed, which is why I recommended replacing the plugs and wires as they can be often overlooked and degraded over time.
Issue causing starter to stay engaged on warm starts Shadowen925 General Discussion 11 03-28-2017 03:51 PM
Hot start issue DriftzIS Basic Help & Repair 6 02-07-2017 04:43 PM
Misfire, Rough Idle and hard to cold start laurencepeel Basic Help & Repair 7 12-17-2016 06:24 AM
Interesting Engine Issue jake42385 General Discussion 9 06-27-2016 07:02 AM
Misfire on #2 and #6 trd_inside General Discussion 8 04-21-2016 11:52 AM
