Misfire on #2 and #6 - Lexus IS Forum
  • 1 Post By trd_inside
post #1 of 9 (permalink) Old 03-17-2016, 01:11 PM Thread Starter
Quoted: 20 Post(s)
I've been plagued with misfire codes ever since i bought the car. It drives well, but the lumpish idle and lean spikes/hesitation when crusing are kind of annoying.
I got the car retuned recently with new spark plugs a few weeks ago, but the issue is still here. (Maybe they were fouled during the tune.. ?)
I get random cylinder misfire codes as well as #2 and #6 misfire codes.
I'm going to replace the plugs again next oil change, but other than that what else should I look at?
02 GGP E-Shift // PTE5858 - 7psi - 350whp
trd_inside is offline
post #2 of 9 (permalink) Old 03-17-2016, 01:39 PM
Quoted: 92 Post(s)
ignition coil packs should be something to look at, maybe try switching them out.
665whp/600wtq on ethanol
my instagram
garrettej8 is offline
post #3 of 9 (permalink) Old 03-17-2016, 01:55 PM Thread Starter
Quoted: 20 Post(s)
I was thikning packs, but I wonder why only #2 misfies, but not #5 and why #6 misfires, but not #1 since those cylinders are linked.
post #4 of 9 (permalink) Old 03-17-2016, 02:06 PM
Cherisher
blkdout's Avatar
Quoted: 631 Post(s)
Have you replaced the spark wires? I would OHM out the coils if so. The specs are floating around here somewhere... I posted them a few times with pics from the manual
What are you gapping the plugs to?
'03 Wagon - Stock
'02 Sedan - Not Stock
-Hiral
blkdout is offline
post #5 of 9 (permalink) Old 03-18-2016, 08:38 AM Thread Starter
Quoted: 20 Post(s)
Stock plug wires. I'll prob order a set of NGK plug wires the same time I do my plugs since they are cheap.
I'll look around and get familiar with ohm'n out the coilpacks too.
I am using NGK6282 Copper Plugs gapped to .30.
post #6 of 9 (permalink) Old 03-18-2016, 12:23 PM
Quoted: 12 Post(s)
2 years ago I had misfire issues with only #1 & #6 . I changed to NGK plug wire and still misfired. It turns out I had tiny vacuum leak causing the misfires.
jmooney5115 is offline
post #7 of 9 (permalink) Old 03-18-2016, 12:30 PM Thread Starter
Quoted: 20 Post(s)
I sprayed half a can of break cleaner on all the hoses i could see and it didnt hear a change in idle. What method did you use to identify the leak?
post #8 of 9 (permalink) Old 04-11-2016, 12:32 PM Thread Starter
Quoted: 20 Post(s)
Just an update. I got my car back a few months ago from a shop that replaced my turbo. They changed the spark plugs after a compression test so I figured they were all good.... They were gapped anywhere from .22 to .30. Ridiculous.
I got some new NGK wires (old ones had some wear on the rubber head), 6 new spark plug and gapped by my self with a feeler gauge @ .28, tested the resistance of all 3 coil packs (came out at .7ohms across the board), swaped the position of all 3 just to be sure.
Runs smooooooth now. Finally.
I guess if you want it done right you gota do it yourself!
garrettej8 likes this.
post #9 of 9 (permalink) Old 04-21-2016, 11:52 AM Thread Starter
Quoted: 20 Post(s)
ITS BACKKK!
My idle slowly got more and more lumpy. Two days ago I replaced my MAF sensor with a new OEM one. Today I got a cel form misfires from cyl 2 and 6 again.
What do i look at next? Injectors? Increasing/decreasing my gap? Fuel pump? I am annoyed to say the least.
EDIT: I just remembered i dropped my idle timing last night from 17.5 to 13.5. What have you NA-T guys have your idle timing set at?
All cylinders misfire and trac light blinking Crunch3 Basic Help & Repair 3 04-05-2016 10:59 AM
Hesitation Hiccups Misfire Accellerating ohhhlando Basic Help & Repair 3 02-08-2016 01:41 PM
