Help Diagnosing 2001 is300 - Lexus IS Forum
post #1 of 6 (permalink) Old 02-23-2019, 03:58 PM Thread Starter
I am the 2nd owner to a 2001 is300, with about 160k miles, and have owned the car for a few years now. It is pretty much all stock. I replaced my alternator about 2 years ago.
So a few weeks ago (last time I drove the car), I was on the highway and my battery light turned on. I noticed as well that when I accelerated, the voltage meter would quickly climb up to the max value (18v) and everything would get bright. When I stopped accelerating, the voltage would fall back down to below average, and everything would go dim. I tested the battery and it came back OK. Now after a few weeks of not driving it, it wont start. I have charged the battery and even tried to jump the car to at least get it to start, to no avail. I was wondering if anyone else has had this issue, and what was causing it. I can install a new alternator if I need to, but I wanted to be sure it wasn't something else causing the issue. Thanks in advance for any help.
tylerslexus is offline
post #2 of 6 (permalink) Old 02-23-2019, 05:20 PM
Quoted: 362 Post(s)
Bad alternator. Replace. If you are a little industrious. You can upgrade to a larger one.
01 SolarYellow is online now
post #3 of 6 (permalink) Old 02-23-2019, 07:50 PM
Quoted: 796 Post(s)
Sounds like the regulator popped inside the alternator. I wouldn't drive it like that. It might bake all the liquid out of the battery. It's possible it already killed your battery and that's why it won't start now.
Ek9B18 is online now
post #4 of 6 (permalink) Old 02-24-2019, 03:49 PM
Quoted: 112 Post(s)
Dont drive it. You will fry your wiring. Buy a new alternator ASAP.
-- Pres. George Washington
Real gun stats will shock you
IM QUIKR is offline
post #5 of 6 (permalink) Old 02-24-2019, 04:58 PM
Quoted: 132 Post(s)
As the others mentioned above with the alternator, though I've only seen the regulators drop voltage when they fail a short can make them do some strange things depending on where it is. Also there is a possibility the high voltage may have popped a fuse or 2 which wont help things start.
2001 Altezza Gita JCE10
Pnut00 is offline
post #6 of 6 (permalink) Old 02-28-2019, 08:36 PM Thread Starter
Thanks for the replies. I changed out the alternator and that was indeed the issue. The alternator was not outputting anything. Everything runs as normal now!
2001 IS300 GTE Wiring akarilo Go Faster 1 01-09-2017 05:02 PM
New member from LA | IS300 2001 kevfjs New Member Introductions 1 07-13-2016 08:42 PM
Buying 2001 IS300 w/ 180K miles? BScott General Discussion 22 05-24-2016 03:24 PM
