having trouble with tail light not working but break lights are - Lexus IS Forum
post #1 of 24 (permalink) Old 03-06-2010, 08:04 AM Thread Starter
i got my IS 300 last week and i noticed that when i turn the light on at night the back lights dont come on but when i press the break they light up. what could be causing this problem?
jorgito01 is offline
post #2 of 24 (permalink) Old 03-06-2010, 08:32 AM
Same thing happened to me bout a month ago. Checked my fuses and realized the taillight fuse was blown. Replaced it and blew it again once I tried to turn on the lights. Turns out my fog light wires were stripped and were grounding out my taillights. They must run on the same circuit... So start with ur fuses
02 Onyx Blk
*Aristo VVT-I GTE swap
Stealth_IS is offline
post #3 of 24 (permalink) Old 03-06-2010, 08:44 AM Thread Starter
i replased all the fuses yesterday and my brake light fuse was blown so it wouldnt let me put it in gear but as son as i changed it it worked. even after replasing the fuses the lights still dont come on. im wondering if one of the sensors is busted because the check engine light came on when the lights started acting up.
post #4 of 24 (permalink) Old 03-06-2010, 11:38 AM
Do your parking lights turn on when you turn your headlights on?
04 IS300 Ultra White
Black suede headliner|Z edition grill
Q45retros|R G B demon eye|GT40R|
Wedssport SA60r|Airlift 3p|L-Tuned
'12 IS350 Nebula Gray
Intake|Invidia Exhaust|Airlift 3p | AG M550|RGB demon eyes|
'17 IS350 F Sport USB 2.0
Greddy Intake|Invida exhaust| J5 Coilovers| AG M652| TRD|
RGB demon eyes|
whiteis33 is offline
post #5 of 24 (permalink) Old 03-11-2010, 11:46 PM
tail light problem
I have the same problem with my 04 is300. I put an intake on and later on that night the tail lights stopped working. Fuse isnt the problem either
'04 is300
pnw04is300 is offline
post #6 of 24 (permalink) Old 03-12-2010, 12:08 AM
Its not a fuse, your brake light has 2 filaments inside the bulb. Simply put you blew out the one that stays on, so you are still able to press on the brake and have the light turn on. If you want to check to make sure, you can always unplug the bulb from the other side that works and plug it into the side you are having problems if it works fine replace your bulb
01 GGP SSR SP1's 18x8F 18x8.5R
looney is offline
post #7 of 24 (permalink) Old 03-13-2010, 05:14 AM
same happened to me a couple weeks ago... tail light fuse (10A) was blown... drivers side panel. check it out.
nabiller is offline
post #8 of 24 (permalink) Old 03-13-2010, 09:02 AM
Happened to me before, my bulb was going out.
Maybe thats the case?
MSM '01 IS300 8/15/2008 - 4/2/2011, RIP
Silver '03 RSX Type-S 4/13/2011, SOLD
Carbon Steel Grey '14 GTI MK.VI 6/24/2015
Montego Blue '96 Mazda Miata 2/10/2017 SIDEWAYS
My Super Cool MSM Build =)
Rubedo is offline
post #9 of 24 (permalink) Old 03-13-2010, 11:59 AM
Get new bulbs!
+ 2JZ-GTE IS300 +
stirlingw is offline
post #10 of 24 (permalink) Old 03-18-2010, 07:10 PM
Another issue may be the Lamp failure sensor. Its a little red box on the drivers side of the trunk underneath the trunk lining. My brake lights worked but my taillights did not work. Also, the lamp failure indicator light on the dash will not come on if this is the case since it is the failure sensor that is blown. Its something like $300 from lexus to replace.
o97616 is offline
post #11 of 24 (permalink) Old 04-02-2010, 08:19 PM
having similar issue that brake lights work turn signals work but tail lights won't stay on and have replace bulbs and fuse so kind lost at this point and no indicator of light out on the dash
kid1323 is offline
post #12 of 24 (permalink) Old 04-17-2010, 06:42 PM
i'm having this same issue, i work at lexus, have had lexus tech's look at it...its a nightmare
i have no brake lights, no tailights, rear turn signals both work...thats it...also cannot move the shifter into gear
i have replaced fuses/relays/stop light switch assy., bulbs, even switched out the failure lamp red box too....still NOTHING
Master Certified Lexus VEHICLE TECHNOLOGY SPECIALIST and INTERNET SALES MANAGER @ LEXUS OF PALM BEACH
2015 NX200t F-SPORT ULTRASONIC BLUE
1993 Toyota Supra
SOLD 2002 IBP JDM NEO/RANDO TURBO
[email protected] 17 psi
R.I.P. 2001 SBM L-TUNED Toyomoto Built TURBO
LEXOTIC CONCEPTS NE017
tsopranoMB is offline
post #13 of 24 (permalink) Old 05-04-2010, 01:53 AM
I'm having the same problem too, so if the 10A fuse keeps on getting blown out what do I do? Check if my tail light wires are being grounded out or check the lamp failure sensor is broken?
Minheeers is offline
post #14 of 24 (permalink) Old 12-01-2010, 12:29 PM
has any one found a solution to this?
Hector
2002 AR iS300
Stock, SRT Intake
email - [email protected]
xREDiS300x is offline
post #15 of 24 (permalink) Old 12-01-2010, 02:29 PM
You guys have replaced the TAIL relay correct? Maybe possible ground...b/c the print shows they are all tied together and landed on the left fender. Anyway...can you check both of the two lamp wire to a known ground to see if your getting +12 back there...to verify if a bad ground. When you turn on your parking lights...do you hear the TAIL relay click...if not...a bad combination switch on you turn signal stalk.
CHOOSE YOUR TAIL LIGHT - Carson, Phillz, Custom, Tail lights, Taillights, taillight sdfontanini Showroom 54 02-27-2011 09:24 PM
Tail lights not working RAGAMP_IS300 Basic Help & Repair 5 02-10-2010 06:26 AM
Trouble removing my tail lights turboa Showroom 5 04-05-2009 12:50 PM
