Anyone have a picture of all the factory grounding points? I noticed a bunch of others with multiple points they were grounding. I only have two that I notice. One from the engine block to the bolt under the battery tray then to the battery. One more from the front of the transmission to the frame. And one more from the firewall to the side of the engine. I see other grounding points on the engine itself but no more going to the frame. Is this right?
When I replaced my stock ground battery cable, there were two points the same cable was connected to. The first being the one you mentioned, but there is another point in the same cable that bolts to the chassis. I have seen the transmission line as well but i'm not sure how much of an impact it has on grounding.
129.8K members
