-   General Discussion (https://www.my.is/forums/f87/)
-   -   Got Gas? Have Questions? (https://www.my.is/forums/f87/got-gas-have-questions-361274/)
JayMarino 05-14-2008 07:45 AM
With the rising costs of gasoline lately...more and more questions are being asked about gas. Why do we have to use premium? What can I do to save gas? Where can you buy the best gas? So, if you have questions about gasoline or why your MPG sucks, post 'em here.
What is the real MPG for my car?
Find a Car
What is the best BRAND of gasoline to put in my car? Some would say TOP-TIER FUELS. For more information or to find who is a TOP-TIER retailer click below.
Top Tier Gasoline
The Lexus Manual says that "Premium Gasoline is REQUIRED"....not reccomended....but can I put in Regular gas? Some great information can be found here.
Your Car is a Temple, so Put in the Good Stuff. - Column/Larry Webster/C/D Staff/Columns/Features/Car and Driver - Car And Driver
The short answer is yes. The car will run fine with 87 octane. However, if used over a long period of time, your risks are: Decresed MPG, Decreased Performance, Possible Engine Knock and potential damage to your engine.
Here is a study from Car and Driver about the performance difference between Regular and Premium.
Regular or Premium? - Feature/Features/Classic Cars/High Performance/Hot Lists/Reviews/Car and Driver - Car And Driver
Basically for most cars if the car can use regular unleaded, you probably won't see much of a difference to add premium. Some cars might even lose power. However, if your car REQUIRES (not Reccomends) 91 octane or Premium, then you will lose power and have a potential knock problem. You're "seat of the pants" might not be able to tell the performance difference as it might only be 2-5hp. But anyone who has driven an IS300 knows....we need all the power we can get.
I will add to this list/thread as I have time.
ChinoXS203 05-14-2008 11:14 AM
nice post. Top Tier Gasoline link was interesting. i always used mobil for years until i had no choice but to stop at a shell station because i needed gas. i was able to feel a difference in performance. i have switched back and forth between mobil and shell and i now use shell every time i can.
galiza0925 08-12-2008 08:21 PM
So if I get gas at one of the "Top" gas stations, I can put regular in my car?
ricey poo 09-25-2008 01:54 PM
yeh, shell gas works, u really notice a difference. on top of that, not having a heavy foot or road rage helps a lot too as far as gas effecienfy goes
LexIS30o 10-21-2008 11:44 AM
Hello, everyone my name is Mike and I'am new to this forum. I own an '01 black IS 300 which I purchased a couple of weeks ago. I have a question....Will putting 89 hurt? I know many people with an IS use 89 and it's just one step lower then premium, has anyone here experienced problems while using an octane rating of 89 for a long period of time? I've had my car for a month and so far so good.. lol
kayotik 10-21-2008 11:50 AM
use search and 91+ octane. If you can't afford $1.50 more a tank, go pick up an econobox that uses 87 octane..
LexIS30o 10-21-2008 12:12 PM
I could get 91, I just wanted to know I usually pump gas at a bp or shell and I wanted to know if I use 89 for a long period of time will hurt my car if I get gas at a top gas station
Phantom1260 10-22-2008 10:56 AM
I was told by the dealer that my car requires 94 octane I had been using 91 before that but I use 94 now. Which is only available at Sunoco here in Canada. Itís not the price I'm worried about itís only a $5 difference per tank but the question is do I really require 94 or is 91 just as fine.
I drive a 06 IS 250 AWD
Also the car starts going crazy with the AVG Tank MPG after i fill up I'm not sure which reading I'm suppose to look at.
SupraMan1784 10-22-2008 12:07 PM
hmmm...not sure...93 is the highest we have here. actually didnt see this thread before. but describe how it goes crazy? once i got my car i just put in shell v-power all the time, with my old ride i just put whatever was the cheapest.
Phantom1260 10-23-2008 08:55 PM
by crazy i mean it starts to go up and down..like its not stable goes from 8.0MPG and keeps rising to 30.4 MPG then back down to 24 MPG and usually stops around 19-21 MPG
kbkura 10-23-2008 09:20 PM
Yes, I've noticed this too. I hope I'm not misunderstanding you and giving you a silly response or something, but this is my understanding so far:
1.) When you re-fill your car, obviously the Tank AVG will be reset to 0,
2.) When you first start driving, you'll be generally in lower gear, accelerating more, etc. thus using more fuel than coasting/driving on a highway and such. This would probably be why you see 8 mpg,
3.) Once you hop on to the interstate/highway or even just a street where you don't stop much, you'll see your mpg shoot up to 30 (I've even gotten mine up to 37 straight up on the highway going at around 55 mph about 5 mins after I filled up the tank),
4.) Then as you average out your city/highway driving your mpg will pop back down to normal or estimated mpgs.
It's your simple mathematics principle of averages... which is why your mpgs fluctuate much less near the end of your fuel tank and settle to your actual average value.
Anyway, I apologize if I misunderstood you and am over-analyzing what you wanted for an answer; but I just wanted to make sure I tried to answer your question.
Good luck with your mpgs!!!
-kbkura
P.S. I pour 93 octane gas in my car... nothing but the best for a Lexus!!! There's a Shell near my house, but Chevron is much cheaper (although no V-Power...), so I usually go there...
Phantom1260 10-24-2008 07:33 PM
ye thats exactly what happens..but thanks for the response makes more sense to me now why it does that.
morning_stoge 11-05-2008 12:38 PM
Anyone use Costco gas? What's the difference between Costco and shell, chevron etc.? I used costco for my camry cause it's super cheap.
Car Conversion Kits 11-11-2008 10:23 AM
No I haven't. I think most people follow it as a safety precaution because we all LOVE our IS. However I might be one of those very few who are willing to take a risk with the LOVE OF THEIR LIVES.
JayMarino 01-21-2009 05:31 PM
Read the first post of this thread?
