Fluid recommend for power steering flush and fill - Lexus IS Forum
post #1 of 8 (permalink) Old 04-06-2019, 07:42 PM Thread Starter
Quoted: 12 Post(s)
1st gen IS 300 what’s fluid? Some say Valvoline max life full synthetic?
(Gonna do the turkey baster method)
Beeeastman1 is offline
post #2 of 8 (permalink) Old 04-06-2019, 07:59 PM
Quoted: 36 Post(s)
Originally Posted by Beeeastman1 View Post
1st gen IS 300 whatís fluid? Some say Valvoline max life full synthetic?
Toyota usually recomends Mobil1 Oil. I work at Toyota and Mobil1 supply all our lubricant needs, Motor oil, ATF, MG75 -90, HD gear oil for transfert case.
Color: Cromax YR580M
TRD Carbon Fiber Shifter Ball
Fidanza Exhaust Cam Gear
SPC Rear Camber Kit
Continental ProContact Tires
Mathieu Bernier is offline
post #3 of 8 (permalink) Old 04-06-2019, 09:00 PM
Quoted: 321 Post(s)
It uses type IV transmission fluid. Just like the automatic. I have used multi-vehicle synthetic type IV compatible with no issues.
Careful & Consistent
post #4 of 8 (permalink) Old 04-06-2019, 09:40 PM Thread Starter
Quoted: 12 Post(s)
I’m confused I thought it says dexron IIIon the power steering reservoir
post #5 of 8 (permalink) Old 04-07-2019, 06:04 AM
Quoted: 36 Post(s)
Iím confused I thought it says dexron IIIon the power steering reservoir
You need to use power steering fluid. Kleen-flo makes an excellent one (might be better than the oem we sold) If you do not put the right fluid it will break the seals and powersteering rack will fail
SPC Rear Camber Kit
post #6 of 8 (permalink) Old 04-07-2019, 03:02 PM
Quoted: 109 Post(s)
I use valvoline MaxLife deron ATF and flush every 80,000 miles. Raise the front so the wheel are off the ground, disconnect return line to the resevior, catch the spillage and direct the return hose into a waste bottle. Cap the resevior port and fill the res with new fluid. Then turn the wheels lock to lock with the engine OFF. And top off the resevoir as you go. Once the fluid comes out clean, reconnect the hose and top off the resevoir. This is the easiest DIY you will ever do.
I go one step further and add a Magnefine filter 3/8" in the hose that goes to the cooler. I'm at 260,000 on the original rack and have no leaks. Keep the fluid clean and the seals will last forever (so to speak).
-- Pres. George Washington
Real gun stats will shock you
IM QUIKR is offline
post #7 of 8 (permalink) Old 04-07-2019, 07:58 PM
Quoted: 765 Post(s)
You just use regular Dexron 4. You don't need any special fluid. It won't hurt as long as it's at least as good as Dexron 4. Honda's require special PS fluid but the IS doesn't.
Ek9B18 is online now
post #8 of 8 (permalink) Old 04-17-2019, 10:51 PM
Location: 87.9 mi Ė about 1 hour 42 mins from east parking lot
Quoted: 43 Post(s)
per owners manual it called for dexron 2 or 3. atf Toyota fluid my parts guy gave me states it's formulated to replace dexron 3
sauce
MAZZURI V2|toke'd
'03 MSM 5MT N/A
ae86 zenki liftback
mx72 zenki wagon
VOLKS FOR SALE!
black86 is online now
