Engine build - Lexus IS Forum
post #1 of 5 (permalink) Old 05-17-2019, 07:02 AM Thread Starter
Engine build
Ok so everyone building a GE block uses GTE internals .... after searching for MY internals I see everything new on sites as GTE rods/pistons , now as a newbie I had originally thought ppl were using used internals ? Can anyone shed some light on this for me ? Wow internals are expensive, so much for a budget build . Are used internals a bad idea ?
Jstorch01 is offline
post #2 of 5 (permalink) Old 05-17-2019, 08:21 AM
Quoted: 71 Post(s)
People do indeed stick used gte guts into the ge. You'll need to cruise the forums and eBay and Craigslist for the right deal.
I'm ok with used rods and pistons, so long as they check out. Obviously I'm gonna do a visual inspection, but then I'm going to ensure they aren't bent or twisted (with a fixture), and then I'm going to torque the caps on and measure the big end with a dial bore gage.
Fwiw, I've seen K1/wiseco (or JE) rod and piston sets on eBay for $1100. Seems pretty reasonable to me. For that price, I wouldn't mess around with old used stuff.
Hodgdon Extreme is offline
post #3 of 5 (permalink) Old 05-17-2019, 08:39 AM
Quoted: 71 Post(s)
OP,
You've started 4 unique threads in the past day to discuss particulars of rods and pistons.
Please just pick one to ask your rods/pistons questions in.
post #4 of 5 (permalink) Old 05-17-2019, 09:43 AM
Quoted: 231 Post(s)
budget build. LOL. yes you can save a little money by going the GTE rod route, everything else is still going to be expensive.
just keep searching, you may have to wait but you will eventually find some. i believe some guys are checking supra forums. make accounts on those forums and make WTB threads. as hodgdon said, no need to make so many threads.
this took me less than two minutes to find:
https://www.ebay.com/itm/OEM-TOYOTA-...sAAOSwJclZmcb7
Lucy; 04 manual sportdesign
mesooohoppy is offline
post #5 of 5 (permalink) Old 05-17-2019, 11:02 AM
Quoted: 144 Post(s)
Non VVTi 2jzge rods are the same as GTE rods, so that may broaden your rod search. The non VVTi GE pistons are stronger than VVTi pistons, but they aren’t the same as GTE pistons. That said, if I was tearing an engine apart, I’d probably go all-new parts. It’s a lot of effort, and if one of those old rods or piston let’s go, it could damage the block, oil pump, cams...you get the idea.
Pick a horsepower goal and stick to it. It’s OK to dream and ask questions, but do some research, too. Most of this info is in the forums. Good luck!
Kris OK is offline
Need help swapped my blow engine SBLOWN General Discussion 8 02-20-2017 08:48 PM
Realistic at home engine swap (2GR for 2GR) FL_Silver_350 General Discussion 2 02-07-2017 08:48 PM
Low engine temp issues jwis300 General Discussion 4 10-25-2016 09:06 PM
My First 2jz build and it's a Lexus Heartofachamp General Discussion 46 04-13-2016 06:16 AM
Brian's Progressive 500HP+ 2JZ NA-T Build br1an184 Member Build Threads - Lexus IS only 3 03-07-2016 04:24 AM
