ECU Body harness plug pinout - Lexus IS Forum
 3Likes
post #1 of 16 (permalink) Old 06-05-2013, 09:58 PM Thread Starter
Hey guys, trying to find a pinout list of the body harness plugs in the ecu box.
I downloaded every pdf i can find but everything is for the ecu or internal body plugs only.
Please help!
03 IS300 GGP SD -- 2JZilla
VisBits is offline
post #2 of 16 (permalink) Old 06-06-2013, 05:33 AM
Not entirely sure what you mean because the body system uses CAN BUS to the engine ECU, meaning only two wires go to the engine ECU from the body control functions(MPX wires on connector E4-orange pin 20 and blue pin 21. The body circuit is completely played out in the diagnostic manual as well as the pin outs and all connectors. Download this link..
https://my.is/forums/f90/new-01-05-di...-dowoad-435090
Page #907-918 is all the body functions and you can see the engine ECU gets two signal wires, those also go to the AC console, cluster, ABS module, etc.
Page 805-808 shows the complete layout of the body harnesses then go to pages #1079-1088 for tur connectors. Sorry if this isn't what you're looking for but it can actually help and hope it does. Only two wires go between the body and engine ecu.
post #3 of 16 (permalink) Old 06-06-2013, 07:49 AM Thread Starter
Hi Jason,
You know when you plug in the ecu to the ecu box in the front of the car. All those connectors that don't go into the ecu itself...yeah those are what I need to know the pinouts for.
VisBits is offline
post #4 of 16 (permalink) Old 06-06-2013, 08:01 AM
Ah, the four connectors towards the driver side I'm betting. Those are junction points 1,2,3, and 4(J1, J2, J3, J4). I will try to find a better description of what's what.
post #5 of 16 (permalink) Old 06-06-2013, 08:13 AM Thread Starter
Yes! ok awesome thank you!
VisBits is offline
post #6 of 16 (permalink) Old 06-06-2013, 08:22 AM
Getting closer, I was wrong, they are EA1, EA2, and EA3. Remember if it's a solid brown wire or a white w/black stripe then it is simply a constant ground wires for the IS300. I see one is grey, one is blue, and the other is black I think and they are junction points.
https://www.google.com/url?q=http://...xDgJ7K4Jg-K9wg
Now to find out about these lil guys...
post #7 of 16 (permalink) Old 06-06-2013, 09:23 AM
Well, I took the time(yes, about an hour lol) and went through the whole print and got the pins that were available. I hope it's the same ones we're talking about lol. The link I have above shows the layout of the pins on the connectors. These are from 2002-2005 print book and I couldn't find all of them so there must be some spots not used, the rest are verified. Hopefully this helps.
EA1
1-BROWN-OBD2 port ground
2-BLACK/WHITE-park/neutral safety switch
3-BLACK/WHITE-ignition coils 1-3
4-BLACK/RED-feed for VSV's, heater circuits(O2), MAF
5-PINK-AC lock sensor(compressor clutch)
6-BLACK-return from park/neutral switch
7-BLACK/RED-injector feed 1-6
8-BLACK/YELLOW-to starter solenoid
9-WHITE/BLUE-to alternator(7.5A STA feed)
10-WHITE/BLACK-engine oil level sensor to ground
EA2
1-GREEN-from parking brake switch to ECU
2-Not used
3-BLUE/YELLOW-VC(5v feed to TPS, APPS, power steering pressure sensor)
4-Not used
5-WHITE-B1S2 signal to ECU
6-RED-SE from vehicle speed sensor
7-RED/BLUE-IG+ for vehicle speed sensor
8-RED/YELLOW-SI from vehicle speed sensor
9-GREEN/BLACK-B1S2 heater to ECU
10-Not used
EA3
1-Not used
2-PINK/BLUE-VPA1 return from APPS
3-BLUE/YELLOW-VC(5 volt supply to TPS, APPS)
4-BLACK-RED-EFI feed
5-Not used
6-BLUE/WHITE-VPA2 return from APPS
7-Not used
8-BLUE/BLACK-to fan relay #1 coil from ECU
9-Not used
10-BROWN-vapor pressure sensor E2(ground)
post #8 of 16 (permalink) Old 06-06-2013, 10:33 AM Thread Starter
Looks right man thank you so much! I'll let you know when I dig into it tonight if anything is missing.
VisBits is offline
post #9 of 16 (permalink) Old 06-06-2013, 10:37 AM
No problem bud, you're welcome. Yea, please lemme know if I missed any and we'll get it. These connectors are seperate from J1-J4.
post #10 of 16 (permalink) Old 01-02-2015, 01:16 PM
Do you know which pin is the transmisson temp sensor pin
the2jzgod is offline
post #11 of 16 (permalink) Old 01-28-2015, 02:46 PM
Are these the same for the 2001? Im going to attempt to wire in my aemv2.....any help on what schematics and where to find them that are needed is GREATLY appreciated.
thanks
gabe
nIStwoJZ is offline
post #12 of 16 (permalink) Old 01-28-2015, 02:47 PM
also, this is my first Lexus/Toyota so I need the "wiring for dummies" versions. haha
nIStwoJZ is offline
post #13 of 16 (permalink) Old 05-24-2016, 08:37 PM
Quoted: 9 Post(s)
Sorry to bring up this old post.. but I was wondering if you guys had a 2001 EA1-EA3 pin out.. based on my wiring, I have noticed that only EA1 is the same as what @jasonm4 posted, EA2 and EA3 are different so I would assume its because those are for 02-05.
thanks..
Daily Drifter BO '01 IS300 | 1JZ VVTi x JZS171 | W58 | LSD | CX Racing | FutureFab | Blitz SS | OEM Altezza Interior
07 CBR 600RR | Stretched
Next: .....
#SXMHoonigans | Check Us Out @SXMHoonigans on Instagram
TNCMAviator is offline
post #14 of 16 (permalink) Old 10-05-2018, 11:50 AM
Quoted: 18 Post(s)
Sorry me too, bring up old post. How do I figure on the ecu which is pin 33 vpa and pin 32 vpa2. Trying to fix code p2121.
I got the download of manual but can't see where I can "search" it for 2121?
I have a 2004, found a pink/blue, no blue white. Are the wire colors different on model years, thx.
I can find the blue/white and pink/blue at the throttle, but can't find at the ecu so far. thx
MAYBE I found the pins. So key on gas pedal off I will read the voltages.
2015 Merc 350GLK, 2007 BMW 328i coupe, 2004 Corvette Z06, 2004 IS300, 1995 BMW M3, 2013 Z06, some SUV's, some gone.
SCCA Regional SOLO champion 06,09,10,11, & more
My Car Channel http://www.youtube.com/user/1947froggy?feature=guide
froggy47 is offline
post #15 of 16 (permalink) Old 10-05-2018, 01:05 PM
Quoted: 790 Post(s)
There were harness changes between 01 and 02+. The ECU connectors completely changed.
Best way to get the updated diagram is to sign up for "techinfo.toyota.com". You can look up and get specific diagrams for your car.
P2121 is in the repair and diagnostic manual DI-305.
Ek9B18 is online now
02+ ECU pinout help Tyrant Go Faster 3 12-12-2010 04:48 PM
Need to find ECU plug connector off the wiring harness [email protected] Go Faster 8 11-11-2010 12:19 AM
Ecu Pinout OKCIS Go Fast Stuff 1 09-30-2004 09:27 AM
