Drain/fill tranny fluid at 200k? - Lexus IS Forum
post #1 of 12 (permalink) Old 04-08-2019, 10:35 AM Thread Starter
Quoted: 16 Post(s)
Was thinking of popping the tranny bolt and drain what I could and add some new fluid thru dipstick. Car has 200k miles with no previous maintenance record. My mechanic says they don’t shed clutch material so it’s be ok, whaddaya guys think? Also I would use probably the oem Toyota IV tranny fluid
Beeeastman1 is offline
post #2 of 12 (permalink) Old 04-08-2019, 02:09 PM
Quoted: 359 Post(s)
Originally Posted by Beeeastman1 View Post
Was thinking of popping the tranny bolt and drain what I could and add some new fluid thru dipstick. Car has 200k miles with no previous maintenance record. My mechanic says they donít shed clutch material so itís be ok, whaddaya guys think? Also I would use probably the oem Toyota IV tranny fluid
It should be fine. I have done it several times.
Careful & Consistent
post #3 of 12 (permalink) Old 04-08-2019, 02:27 PM
Quoted: 604 Post(s)
I can't see anything wrong with that
post #4 of 12 (permalink) Old 04-08-2019, 07:14 PM
Quoted: 131 Post(s)
It might not "shed clutch material" but it does have bearings and sprag (?) plates that wear so fluid changes help remove the debri. The risk is the particles will enter and jam up the solenoids and other moving components if not cleared somehow. Also the fluid is in a hydraulic circuit and is subject to shear and breakdown of its own properties, so new fluid is essential over time. I probably wouldn't both changing the gauze filter in the trans unless you have it apart, its more of a large particle filter than a fine micro filter like the engine uses.
2001 Altezza Gita JCE10
Pnut00 is offline
post #5 of 12 (permalink) Old 04-10-2019, 09:45 PM Thread Starter
Quoted: 16 Post(s)
Doc looks Ike’s everyone suggests to do a drain and fill (I think this adds about 3.5 quarts of new fluid to the system from what I’ve read)
post #6 of 12 (permalink) Old 04-11-2019, 11:49 AM
Quoted: 792 Post(s)
Yeah 3.5 out of maybe 10 quarts. Might want to do it periodically till the fluid remains a nice red color.
post #7 of 12 (permalink) Old 04-13-2019, 12:18 PM
If you are the least bit capable, I recommend the "exchange" method described in this thread. My post is the last on the thread.
https://www.my.is/forums/f87/auto-tr...rocess-606013/
It was quite easy, just make sure you have a big enough bucket, etc. And use Toyota fluid, a case on Amazon is quite reasonable. I sleep better knowing I did this at just under 200K.
Allgonquin is offline
post #8 of 12 (permalink) Old 05-31-2019, 01:14 AM
Do you have a link for the fluid on amazon?
dongiri is offline
post #9 of 12 (permalink) Old 05-31-2019, 04:45 AM
Quoted: 359 Post(s)
Just search "Toyota type IV" It is not hard to find.
post #10 of 12 (permalink) Old 06-25-2019, 07:51 AM Thread Starter
Quoted: 16 Post(s)
Did the drain and fill and 1000 or so miles later the fluid is kinda medium brownish again should I do another drain and fill?
post #11 of 12 (permalink) Old 06-25-2019, 02:44 PM
Quoted: 359 Post(s)
I would. At least one more time.
post #12 of 12 (permalink) Old 06-25-2019, 02:55 PM
Quoted: 131 Post(s)
If you only drained the pan then you have mixed about 1/3 new with 2/3 old, so yeah its going to be a lighter but same old colour. You will have to change it 3-4 times like that to get it all fresh and looking the right colour.
Pnut00 is offline
2001 AT tranny shudder 1800-2000 rpm IM QUIKR General Discussion 5 04-14-2018 07:08 PM
Transmission fluid replacement, when to do this? chashsportx General Discussion 10 09-19-2017 06:01 PM
2011 IS 350 F Sport Transmission Fluid Change AND Adding an External Tranny Cooler Jbamonte General Discussion 5 06-20-2017 09:43 PM
GM Synchromesh MT Fluid 10-4014 in a manual trans IS300 alexbartlett93 General Discussion 37 01-28-2017 10:57 AM
MT owners: Bleed your clutch fluid! tonynca General Discussion 7 12-17-2015 06:01 PM
