Coolant bypass on the back leaking - Lexus IS Forum
post #1 of 8 (permalink) Old 04-21-2019, 07:41 AM Thread Starter
Hey my coolant bypass on the back of the water pump is leaking after a timing belt service. It’s got a gasket and I just put a little more torque on it. Is there anything fancy to this? The gasket felt like it was metallic almost and maybe had a direction to it? I couldn’t find much info when I installed it. Any help is appreciated!
trowe2 is offline
post #2 of 8 (permalink) Old 04-21-2019, 08:19 AM
Quoted: 51 Post(s)
The gasket is not directional, it is a metal shim style. Sounds like your sealing surfaces were not clean and flat prior to assembly.
Recommend disassembling, clean & inspect, and reassemble.
Hodgdon Extreme is online now
post #3 of 8 (permalink) Old 04-21-2019, 09:45 AM Thread Starter
I scrubbed it and hit it with some 220 grit sand paper when it was off the car. Is there anything else I can do to sure it up? Like add sealant or something?
Also it isn't leaking a little, its leaking a good amount. If the mating surfaces were a little dirty it would be a small drip
trowe2 is offline
post #4 of 8 (permalink) Old 04-21-2019, 02:51 PM
Quoted: 321 Post(s)
I always put a slight film of RTV on mine when reassemble.
Careful & Consistent
post #5 of 8 (permalink) Old 04-21-2019, 03:08 PM
Quoted: 51 Post(s)
It's a simple two bolt flange. Obviously the two sealing faces are not coming to bear on one another with enough force, or squarely enough...
Adding sealer to the outside of a leaking joint is not the answer. You can use sealer during assembly, but it is absolutely not required.
Disassemble, inspect, repair problem and reassemble.
post #6 of 8 (permalink) Old 04-21-2019, 04:13 PM Thread Starter
I tried like the dickens to get that pipe off with everything assembled. I’m guessing I have to tear it all down again to be able to unhook it. Is that right or can you think of a way to get access to those surfaces?
trowe2 is offline
post #7 of 8 (permalink) Old 04-22-2019, 02:21 PM
Quoted: 79 Post(s)
Doesn't this connection have an o-ring? If this is the same one I'm thinking of, some people forget to make sure the old o-ring is taken out before replacing it and re-installing the part. I could be wrong on the part though.
allturbo98 is offline
post #8 of 8 (permalink) Old 04-22-2019, 03:01 PM Thread Starter
No o-ring. It has the metal shim gasket like someone mentioned above. It is the pipe that runs under the header to the back of the engine bay where a rubber hose runs coolant through the fire wall. I'm thinking I can maybe get that hose off and slide the pipe backwards on the studs. I'll make an attempt tonight.
trowe2 is offline
Bypass coolant running through throttle body? Dsthez General Discussion 1 04-14-2019 06:26 PM
Coolant Leak Adam_AntiAir General Discussion 2 02-18-2019 07:59 PM
2002 IS300 manual leaking coolant sombo1 General Discussion 1 07-31-2016 12:48 PM
Help please, Leaking Coolant Be.Parker Basic Help & Repair 2 03-17-2016 03:09 PM
Coolant Leaking? Better check your Rad Cap pjmorozov General Discussion 3 01-20-2016 09:18 AM
