Check engine light - Lexus IS Forum
post #1 of 21 (permalink) Old 01-04-2007, 09:46 AM Thread Starter
Check engine light
Hey everyone I am new to this forum. I am having lots of problem with my 2001 is300. First my CEL light came on. I ran the scanner and came up with to codes. P0171 and P0174. Which is for the o2 sensor. I replace both of the and still the light came back on. Now they are four codes P0171 twice and P0174 twice. I did a search on the forum and some people have the same problem but different codes. Some people change the MAF sensor but did'nt post back up the say if the problem was fixed. I am also having slow take of in 1st gear and sometime a jerk in 3rd gear.
Can someone please help me out.
thank you.
Anthony Persaud is offline
post #2 of 21 (permalink) Old 01-04-2007, 10:05 AM
Sounds like your throttle body needs to be cleaned out. the MAF sensor will cause all the problems you are describing. What you can do is either replace the MAF sensor, or attempt to clean it. Let me dig up some info on it for you in a PDF format. I will PM you with my findings.
abrx7 is offline
post #3 of 21 (permalink) Old 01-04-2007, 10:07 AM
Also what O2 sensors did you replace? There are 3 in the car. 2 before the y pipe and one after the y pipe. I know its another stupid question but are the plugs securly fastened? I am only saying this because I had the same problem (on a different car) and the cable wasnt pushed in far enough
abrx7 is offline
post #4 of 21 (permalink) Old 01-04-2007, 10:17 AM Thread Starter
I replace the first two before the y pipe. The plugs are securly fastened.
thank you.
post #5 of 21 (permalink) Old 01-04-2007, 10:47 AM
Well if you are still getting that code then I would say there is a high probability that the one after the y pipe is bad.
abrx7 is offline
post #6 of 21 (permalink) Old 01-04-2007, 11:37 AM
Where have you been??
"I feel liked I've been mauled by Jesus."
OneEyedFaces is offline
post #7 of 21 (permalink) Old 01-04-2007, 01:18 PM
Dude thats the bus!! hahaha
+rep for a good laugh
abrx7 is offline
post #8 of 21 (permalink) Old 01-04-2007, 02:35 PM
thank you.
who told you that? You were screwed as far as diagnosis as soon as you started by having incorrect/incomplete information.
P0171/0174 are for A/F system too lean.
P0171=bank 1
po174=bank 2
This does not automaticly indicate a o2 sensor problem. More likly in fact it is a mass airflow sensor issue since it involves both banks.
Check tghe Mass airflow meter as it is almost always the culprit with these codes. probably dirty giving incorrect information.
(2 trip detection logic)<<<means its happened at least twice
 Air induction system
 Injector blockage
 Mass air flow meter
 Engine coolant temp. sensor
 Fuel pressure
 Gas leakage on exhaust
 Open or short in heated
sensor 1)
 Heated oxygen sensor
ECM
 PCV piping<<<loose or disconnected????
Lextech1 is offline
post #9 of 21 (permalink) Old 01-04-2007, 02:45 PM Thread Starter
Should i replace to MAF or try to clean it.
post #10 of 21 (permalink) Old 01-04-2007, 03:31 PM
remove it and inspect. if the two wires inside are filthy, clean it and reset the ECM. If they are spotless, troubleshoot the problem. Throwing parts at it will be very costly. Perhaps swap MAF's with another member for diagnosing the problem.
Lextech1 is offline
post #11 of 21 (permalink) Old 01-05-2007, 09:57 AM Thread Starter
how do i reset the ECM.
post #12 of 21 (permalink) Old 01-05-2007, 10:37 AM
disconnect battery.
wait a few min.
reconnect
Lextech1 is offline
post #13 of 21 (permalink) Old 01-05-2007, 11:22 AM Thread Starter
Everytime disconnect the battery the car feels like its running on two cylinder after. Is the the right way to reset the ECM
post #14 of 21 (permalink) Old 01-07-2007, 06:50 PM Thread Starter
I removed the MAF and cleaned it using the MAF cleaner from Auto zone and also cleaned the throttle body, after reinstalling the MAF sensor I cleared the CEL using the pocket scaner. After about 45 mins of driving the CEL came back on. The car seems to be driving much better except for a little hesitation while switching through 1st and 2nd gear.
post #15 of 21 (permalink) Old 01-08-2007, 10:38 AM Thread Starter
bump bump
