Changed Valve Cover seals, Spark Plugs and Coil Pack.. wet again.. - Lexus IS Forum
 2Likes
  • 2 Post By kream
post #1 of 5 (permalink) Old 03-31-2019, 07:17 PM Thread Starter
Hey all,
First post here, but had a quick question. In October I replaced my spark plugs, coil packs, and Valve Cover Gaskets. Car's been running fine, but did an oil change, and it started miss-firing. Pulling a p0305 code, so I went and took everything a part, and sure enough all plugs are wet again. A mechanic friend told me I had should have also replaced the "plug hole seals" but, I'm not entirely sure that's relevant with this car. Unless there is something I'm missing. Any help would be appreciated. I went through the search function, but I'm mainly seeing valve cover seals as the resolution.
kream is offline
post #2 of 5 (permalink) Old 03-31-2019, 07:37 PM
Quoted: 359 Post(s)
Originally Posted by kream View Post
Hey all,
I would say bad gasket install. The only other time I have seen an issue. Would be crank case pressure getting to high. Basically the PCV was not working right.
Careful & Consistent
post #3 of 5 (permalink) Old 03-31-2019, 09:23 PM
Quoted: 601 Post(s)
when you installed the seals, you put the gasket sealer on the corners at the cam seals?
post #4 of 5 (permalink) Old 03-31-2019, 10:50 PM Thread Starter
You know what... now that you mention that, I don’t think I did. Looks like I know what I’m doing tomorrow.
TobiasSing and Bempa like this.
kream is offline
post #5 of 5 (permalink) Old 04-09-2019, 10:42 AM
Quoted: 7 Post(s)
Use only OEM toyota seals.
A dab of silicone on the corners
Mating surfaces cleaned and free of oil
02 Onyx Black 5 spd rhd w/13B rotary turbo
wasabiboi is offline
Coil Pack replacements skyebaby22 General Discussion 19 03-07-2019 11:33 AM
Valve cover breather hoses are cracked and coil pack wiring is chewed 7:34pm General Discussion 7 04-07-2018 07:13 PM
