Car won’t start - Lexus IS Forum
post #1 of 5 (permalink) Old 03-03-2019, 08:27 PM Thread Starter
Quoted: 79 Post(s)
Car won’t start
I recently replaced my starter with a new one because I thought my starter was bad. My starter was just clicking so I replaced it. After replacing it, the car started and drove fine for about 3 weeks. Today it wouldn’t start. It was doing the samething as before. I would turn the key and get a click and that’s all. I then disconnect the battery and wait 10mins and reconnected the battery. Then the car starts, but now the radio won’t give any sound. Then I would unplug the radio and the metra and then reconnect everything. Now the radio makes sounds again.
Has anyone ever had something like this ever happen and if so what was the problem? What should I check?
allturbo98 is online now
post #2 of 5 (permalink) Old 03-04-2019, 03:37 AM
Quoted: 36 Post(s)
Originally Posted by allturbo98 View Post
I recently replaced my starter with a new one because I thought my starter was bad. My starter was just clicking so I replaced it. After replacing it, the car started and drove fine for about 3 weeks. Today it wouldnít start. It was doing the samething as before. I would turn the key and get a click and thatís all. I then disconnect the battery and wait 10mins and reconnected the battery. Then the car starts, but now the radio wonít give any sound. Then I would unplug the radio and the metra and then reconnect everything. Now the radio makes sounds again.
Ground related issue! look for your grounds if they are clean and sturdy, there is one from the battery to chassis, anotther one from the alternator to chassis, another one from the engine to chassis and another important one : Tranny to chassis
Color: Cromax YR580M
TRD Carbon Fiber Shifter Ball
Fidanza Exhaust Cam Gear
SPC Rear Camber Kit
Continental ProContact Tires
Mathieu Bernier is offline
post #3 of 5 (permalink) Old 03-04-2019, 06:04 AM
Quoted: 112 Post(s)
If it was a ground it would not have worked for 3 weeks. Its either the battery or alternator. My money is on the alternator is failing.
-- Pres. George Washington
Real gun stats will shock you
IM QUIKR is offline
post #4 of 5 (permalink) Old 03-04-2019, 08:03 AM
Quoted: 795 Post(s)
I might pick up one of those lithium ion jump packs. If the car won't start, try jumping it with the pack. If it starts, you know it's not the starter. At that point, as IM suggested, you're looking at battery or alternator. If you have a volt meter, you might want to check the voltage at the battery when it's running again.
If the battery is more than 4 years old, it's probably due for replacement anyway.
post #5 of 5 (permalink) Old 03-04-2019, 09:54 AM Thread Starter
Quoted: 79 Post(s)
I will check those grounds. But do you think that would cause the car not to start until after I unplug the battery?
The battery was replaced about a year ago. I guess the next would be the alternator but why would it not start then start after I disconnect the battery for a bit?
I’ve tried jumping it before when this was happening because I thought it could of been the battery. Nothing happened. Disconnected the battery for a bit and it started. Any other suggestions?
My Is 350 Won’t start Please help Eleazarhtx Basic Help & Repair 3 10-17-2018 04:32 PM
P0303 code, car wonít start now thezinfan General Discussion 2 02-21-2018 02:45 PM
new alternator fuse now car won't start judylink New Member Introductions 2 03-26-2016 02:59 PM
