Car is stalling after FFIM swap - Lexus IS Forum
post #1 of 15 (permalink) Old 07-23-2018, 05:33 AM Thread Starter
Hello everyone this is my first post on here, I’m stuck on a problem looking to see if anyone can help me out.. I recently replaced my oem manifold. With a Frankenstein Aristo top runners/throttle body and GE bottom runners that were mated together. I did this with the intention of going turbo soon, at the moment I have the FFIM on and the cold side pipe on, with a new MAF sensor. so it’s pretty much a Aristo manifold with a cold air intake. My big problem is that now my car won’t hold a steady idle, specially when the cooling fans turn on, it dies.
So my question is, is there a way to reset the throttle body?? or is my Ecu not compinsating for the extra air coming in?? This Frankenstein manifold was previously running on a turbo car with no problems.
ID:	120211   Click image for larger version
Redrckets300 is offline
post #2 of 15 (permalink) Old 07-23-2018, 07:51 AM
Quoted: 145 Post(s)
I'd check to see if you have any air leaks in the manifold/gasket and the possibility of a bad wiring connection (from you picture it looks like you have extended the wiring).
Piggity is offline
post #3 of 15 (permalink) Old 07-23-2018, 09:11 AM
Quoted: 795 Post(s)
What ECU are you running?
Ek9B18 is online now
post #4 of 15 (permalink) Old 07-23-2018, 03:32 PM Thread Starter
I sprayed everything with brake cleaner to check for a leak, no changes... some parts of the harness have been extended, I’ve double checked everything..
post #5 of 15 (permalink) Old 07-23-2018, 03:33 PM Thread Starter
The factory 04 auto is300
post #6 of 15 (permalink) Old 07-23-2018, 03:36 PM Thread Starter
Would make a difference since the charge pipe has no filter.. to much air being sucked in?!?
post #7 of 15 (permalink) Old 07-24-2018, 05:54 AM
Quoted: 795 Post(s)
Are you using a MAF?
Is the MAF tube the same diameter as the OEM one?
Will the OEM ECU drive the FFM throttle body properly?
It sounds like a mismatch between the ECU and the throttle body and/or like you're not using a MAF.
post #8 of 15 (permalink) Old 03-09-2019, 04:46 PM Thread Starter
Sorry couldn’t get back in my account, alone the ARISTO FFIM didn’t work, once I turbo the engine with that manifold everything works well! Only problem I have is that on cold start my car idles at 2000-2200rpm.. till it’s warmed up
post #9 of 15 (permalink) Old 03-09-2019, 07:37 PM
Quoted: 360 Post(s)
Originally Posted by Redrckets300 View Post
Sorry couldnít get back in my account, alone the ARISTO FFIM didnít work, once I turbo the engine with that manifold everything works well! Only problem I have is that on cold start my car idles at 2000-2200rpm.. till itís warmed up
I have not done this swap. But I know on the LS400 throttle body swaps I have done. They idle a bit high. Well when it is real cold. After a bit the GE ECU adjusts a bit lower. Make sure your TPS is ohmed right for the ECU you are using.
post #10 of 15 (permalink) Old 03-09-2019, 11:31 PM
Quoted: 32 Post(s)
did you do an FFIM with LS400 TB or happen to know anybody who did so?
i'm piecing the components to do that along with a piggyback and built head,
my concern is the physical space requirement of the huge TB!!
Arzon is offline
post #11 of 15 (permalink) Old 03-10-2019, 07:02 AM
Quoted: 360 Post(s)
Like I said before. I have not done this swap. (FFIM) But as to your question. I do not know if it could be done on this intake style without some serious mods. Also I am referring to the 80mm one.
http://i44.tinypic.com/33wtyrc.jpg
If you are referring to the smaller 75mm Long style throttle body. It uses the same flange I believe. This tread has a picture of it.
https://lh6.googleusercontent.com/-R...2/IMAG0736.jpg
post #12 of 15 (permalink) Old 03-10-2019, 05:58 PM Thread Starter
That’s exactly what’s happening, idle on cold start is 2000-2200 for 5mins and then I guess the GE ecu makes adjustments and lowers idle to 1500...it’s just annoying with a 3in turbo back, it’s pretty loud in the morning.
post #13 of 15 (permalink) Old 03-10-2019, 06:00 PM Thread Starter
post #14 of 15 (permalink) Old 03-10-2019, 07:00 PM
Quoted: 360 Post(s)
Make sure the TPS sensor is adjusted for the GE ECU.
post #15 of 15 (permalink) Old 03-10-2019, 09:46 PM Thread Starter
Will do, thanks for the tip.
blkaltezza's build blkaltezza Member Build Threads - Lexus IS only 349 03-05-2018 02:18 PM
NA-T build GTE swap or sell the car and get a WRX or 335? nrbeal12 Go Faster 23 01-31-2018 05:37 PM
Choosing the right Outdoor Car Cover nipaarovi New Member Introductions 0 10-26-2016 11:36 PM
