Cam and Crank Seal Packing Question - Lexus IS Forum
 3Likes
  • 2 Post By IM QUIKR
  • 1 Post By trowe2
post #1 of 8 (permalink) Old 04-18-2019, 07:58 AM Thread Starter
Hello,
I'll be changing my timing belt and seals this weekend. Its not only time, but I have a good oil leak on the front and my AC compressor is out, so I'll be quite busy.
Last night i laid out all of my parts on a bench and gave it a good look over. I noticed that the gates kit I bought included cam seals and the crank seal but there is no packing in the seals. When I look at the back they are hollow and there are no springs or whatever is usually in them. The two cam seals included in the kit are packed in sealed bags with a toyota sticker on them, while the cam seal was just naked in the box. The crank seal is more of a rust color (Viton, I'm guessing) and the cam seals are black.
Should I be going to the dealership or is this the new OEM? I called a local Lexus dealer and they wouldn't give me much information about what they had in stock.
Thanks!
trowe2 is offline
post #2 of 8 (permalink) Old 04-18-2019, 09:34 AM
Quoted: 140 Post(s)
Can you post a pic? I’ve done the job twice using Toyota parts. I’m pretty sure they all had springs inside the seal. Wonder if they are counterfeit parts?
Kris OK is online now
post #3 of 8 (permalink) Old 04-18-2019, 11:52 AM
Quoted: 766 Post(s)
This is what google shows me.
I couldn't find a good backside view an a cam seal.
post #4 of 8 (permalink) Old 04-18-2019, 12:02 PM Thread Starter
That is exactly what mine looks like. Its the same color and everything. I can see what looks like a spring showing around the center. I'll take a look around the box it was floating around in and see if it just fell out.
Also I edited my first post. I didn't mention that this is the ever popular "Gates" kit.
trowe2 is offline
post #5 of 8 (permalink) Old 04-18-2019, 03:26 PM
Quoted: 322 Post(s)
I have seen some companies do there seals without tension springs. I have not had luck with them. When the factory has the spring. I would replace the one that normally has a spring with a factory seal.
Careful & Consistent
post #6 of 8 (permalink) Old 04-18-2019, 05:48 PM
Quoted: 109 Post(s)
Man you dont want to do this job twice like me using aftermarket seals. Mine leaked badly right away. Go buy toyota oem cam and crank seals. Its important to know not to deep set the crank seal. Just make it flush with the outer surface. There are oil drain holes which get blocked if you press it all the way in.
black86 and TobiasSing like this.
-- Pres. George Washington
Real gun stats will shock you
IM QUIKR is offline
post #7 of 8 (permalink) Old 04-19-2019, 06:41 AM Thread Starter
I found the spring for the crank seal in the box. little tiny guy. There is a spring in the cam seals its just hidden under the front lip (likely as it should be). The dealer has a new crank seal waiting for me so I'll go get that today.
IM QUIKR, I don't think I ever though that far about the crank seal. I'll take your advice, thanks.
TobiasSing likes this.
trowe2 is offline
post #8 of 8 (permalink) Old 04-19-2019, 06:15 PM
Location: 87.9 mi – about 1 hour 42 mins from east parking lot
Quoted: 44 Post(s)
I've gotten all my stuff through a Toyota dealer which is cheaper. the only thing that is IS300 specific is the water pump but it's an aisin sourced part so I get it directly from them.
sauce
MAZZURI V2|toke'd
'03 MSM 5MT N/A
ae86 zenki liftback
mx72 zenki wagon
VOLKS FOR SALE!
black86 is online now
DIY: Complete Timing Belt+Water Pump+ Seals mm71522 DIY/tutorial forum 39 10-23-2018 10:35 PM
Cam Seal Leaking or VVTi Gear? Stanri010 General Discussion 6 05-16-2018 06:18 PM
VVTi Cam Gear Oil Leak? Crank Seal? Other Recommended Maintenance? toneekay General Discussion 7 02-07-2018 10:10 PM
Misfire, bearly runs, replaced MAF, Cam and crank sensors, etc. Inlinesixfan Basic Help & Repair 3 01-18-2018 06:53 AM
Cam gear timing question Syrii General Discussion 0 09-16-2017 03:09 PM
