Brake Clicking Noise - Page 2 - Lexus IS Forum
post #16 of 25 (permalink) Old 02-21-2019, 03:33 PM Thread Starter
Attached is a photo, if this helps at all.
2002is300GGP is offline
post #17 of 25 (permalink) Old 02-21-2019, 03:52 PM
Quoted: 237 Post(s)
Originally Posted by 2002is300GGP View Post
I would never think it was the lower ball joints. Thank you for the info!
Can you explain how its the lower ball joints? I seriously thought i had issues with the braking system.
jack the car up, shake the wheel to feel for play. if you have play, figure out where its coming from. sometimes you may not be able to feel the play because its so small, but this is still a good, free way to test if there is any play in your suspension.
Lucy; 04 manual sportdesign
mesooohoppy is offline
post #18 of 25 (permalink) Old 02-21-2019, 07:18 PM
Quoted: 364 Post(s)
That is one way. But I did that and they were fine. But replacing them got rid of the noise.
post #19 of 25 (permalink) Old 02-22-2019, 11:28 AM
Quoted: 237 Post(s)
of course. its more of an initial/broad test. depending on your findings, you go investigate a more specific area.
as stated in my post, you may not be able to feel it immediately (or really ever), but this test is easy, free, and can be done before you even take the wheel off.
post #20 of 25 (permalink) Old 02-27-2019, 08:47 AM Thread Starter
Thank you all! I'll try that.
post #21 of 25 (permalink) Old 03-18-2019, 05:10 PM Thread Starter
Hello all,
As an update, I never had a chance to replace the bushings and ball points. However, this weekend I removed the "ABS Motor" fuse from the fuse box that's located by the battery. Once it was removed, I drove the car and that noise went away! I then put that fuse back, and then removed the "ABS SOL" fuse, and again the noise went away. I then put that fuse back (both fuses in the box), and drove the car and that noise returned!
I'm thinking this could be an ABS issue? Or maybe a defective ABS wheel sensor? I tried looking up wiring diagrams, but got nowhere as I really dont understand how the ABS system is wired.
Please advise.
Thank you all!
post #22 of 25 (permalink) Old 03-19-2019, 01:01 AM
Quoted: 10 Post(s)
I have the same damn clicking noise, right when coming to a stop. But I also get a violent vibration when coming to a stop quickly at high speeds.. don't know what it could be
Vroomin350 is offline
post #23 of 25 (permalink) Old 03-19-2019, 01:08 AM
Quoted: 10 Post(s)
dude where did you order the front lip, fitment looks pretty good , did you have to modify it much?
post #24 of 25 (permalink) Old 03-19-2019, 05:10 PM Thread Starter
Thanks! I bought the car with the lip, but it's a TRD lip (according to the previous owner). The fitment is exact, no mods, just paint.
post #25 of 25 (permalink) Old 03-19-2019, 05:14 PM Thread Starter
You should check the wheels if balanced properly if your getting violent vibration when coming to a stop. A four-wheel alignment would be good also.
I seriously think it's either the ABS module or ABS wheel sensors that's making that clicking noise. I think i should replace the wheel sensors first and see what happens, then the module.
Clicking noise coming from drivers side front wheel 10-20mph (video) dhaney85 General Discussion 3 02-19-2019 07:29 PM
Brake hissing noise after bleeding brakes. jerry-l Stop, Drop and Roll 6 09-13-2018 05:05 AM
clicking noise when going from Park to Drive rylanv91 General Discussion 3 07-23-2017 03:13 PM
Brake Pedal - Issue or Normal? looking for some confirmation chunktwo Basic Help & Repair 2 06-26-2017 10:17 AM
My Brake Squeaks/Knocks when Not Braking Cheez General Discussion 11 11-05-2016 11:22 AM
