8 codes, 1 problem, ABS system diagnosis. - Lexus IS Forum
post #1 of 24 (permalink) Old 05-12-2019, 12:46 PM Thread Starter
I just got my IS back from the body shop this week, with it i got a whole new set of triggered CEL codes,
C0278
C1225
C0200
C0205
C0210
C0215
C1246
C1201
All these codes are ABS related so i think it can be narrowed down to 1 simple fix, if anyone can help me get these dash lights to turn off, My Emergency Brake light is always on, my trac off light is constantly blinking, and my check engine light is on
FlameSpitter is offline
post #2 of 24 (permalink) Old 05-12-2019, 12:56 PM Thread Starter
Could it be a blown ABS solenoid relay fuse, the one that's hard to get to? or maybe busted Skid Control ecu?
post #3 of 24 (permalink) Old 05-12-2019, 02:50 PM
Quoted: 364 Post(s)
215 is a bad thermostat.
200 -210 is injector issue. check connections. otherwise it may be bad injectors.
1225 check connections at the throttle body.
1246 maybe a lose timing belt.
1201 is fuel pressure issue.
Careful & Consistent
post #4 of 24 (permalink) Old 05-12-2019, 06:56 PM
Quoted: 798 Post(s)
I'm not sure why you're not taking it back. If it didn't do this before you sent it to them, they fucked something up.
Usually when I see a bunch of unrelated CEL's I think there's a bad ground somewhere.
post #5 of 24 (permalink) Old 05-12-2019, 07:11 PM Thread Starter
these are the codes I'm pulling,
-0278/11
(DI-451 ) Open circuit of ABS solenoid relay circuit
C0279/12
(DI-451 ) Short circuit of ABS solenoid relay circuit
Trouble Area
ABS solenoid relay
-C1225/25
(DI-463 ) Open or short circuit of SM circuit
Trouble Area
Brake actuator SM1 or SM2 circuit
c0200- c0205- c0210- c0215, are all 4 wheel ABS speed sensors
-C1246/46*2
(DI-469 ) Malfunction in master ccylinder pressure sensor
Trouble Area
Master cylinder pressure sensor
Master cylinder pressure sensor circuit
C1251/51*1
Trouble Area
(DI-475 ) Pump motor is locked ABS & TRAC Actuator
ABS & TRAC Actuator circuit
post #6 of 24 (permalink) Old 05-12-2019, 07:16 PM Thread Starter
those codes don't match up to the ones I'm pulling, this is for a 2003 is300
post #7 of 24 (permalink) Old 05-12-2019, 07:21 PM Thread Starter
I work there, Im the assembler so anything wrong I probably caused myself.
post #8 of 24 (permalink) Old 05-12-2019, 08:16 PM
Quoted: 798 Post(s)
Dooh well that's probably different.
Where was the repair? Was the car welded on? The ABS block under the hood is pretty much just as bunch of solenoids and valves. The actual electronics are under the dash. You could probably get those codes if you forgot to plug in some of the connectors under the dash.,
post #9 of 24 (permalink) Old 05-12-2019, 08:46 PM Thread Starter
yes the car was welded on, it ran a high sidewalk curb, damaged the lower rad support on the passenger side so some cutting and welding was done, also the interior was completely redone,
what exactly under the dash would cause some of these issues?
post #10 of 24 (permalink) Old 05-12-2019, 09:27 PM Thread Starter
The ABS block is near the impact area, it could be the issue but I highly doubt it was damaged, all the ABS and Skid Control electronics are inside...
Im getting a code for the master cylinder pressure sensor.
The way i see it it has to be something really simply...
c1201 is for malfunction in engine control system / ABS & TRAC ACTUATOR ,
then the 4 ABS wheel speed sensor codes,
the code for the brake actuator,
And the code for the ABS Solenoid...
can anyone put the dots together? im gonna try replacing all 4 wheel speed sensors maybe??? just replace everything until it works lol? i think i can find a parts car
post #11 of 24 (permalink) Old 05-13-2019, 06:15 AM Thread Starter
C0278
C1225
C0200
C0205
C0210
C0215
C1246
C1201
-0278/11
C0279/12
Trouble Area
ABS solenoid relay
-C1225/25
Trouble Area
-C1246/46*2
Trouble Area
C1251/51*1
Trouble Area
post #12 of 24 (permalink) Old 05-13-2019, 02:01 PM
Quoted: 364 Post(s)
Sorry I forgot you had just C codes, not P...
Did you have these ABS codes when you dropped it off?
post #13 of 24 (permalink) Old 05-13-2019, 03:22 PM
Quoted: 798 Post(s)
Did you pull the ground before welding?
The connectors and ABS controller are right about where the clutch pedal would be under the dash. If you pull the lower dash cover and look up, you can see it. It's right about where the left knee is.
post #14 of 24 (permalink) Old 05-13-2019, 03:38 PM Thread Starter
No, don't think it was throwing any ABS codes before it got dropped off, the car was in a small collision passenger side fender and lower rad support, then went straight to the body shop, never noticed until the car was fully finished.
post #15 of 24 (permalink) Old 05-13-2019, 03:42 PM Thread Starter
yes the battery was pulled out during the welding, ill peek under my dash and check but I'm pretty sure none of those electronics were ever touched.
2001 IS300 won't start. Cleared and retrieved codes, but no answers. PaulE Basic Help & Repair 2 04-24-2018 07:15 AM
Bad ABS actuator wont established connection to the ABS ECU? Elion Basic Help & Repair 0 09-20-2017 12:27 AM
Help with bunch of ABS codes Landmaster General Discussion 6 01-22-2017 04:11 PM
ABS Light and Traction Light Blink - Code 43 & 44 jmooney5115 Basic Help & Repair 0 01-21-2017 04:05 PM
First post... Changed hub bearing and now getting ABS codes BeigeLexIS Basic Help & Repair 4 05-12-2016 02:14 PM
