'01-'05 IS300 DIAGNOSTIC MANUAL W/Full Wiring Schematics/TSB repair DOWNLOAD - Lexus IS Forum
post #1 of 24 (permalink) Old 09-28-2011, 07:31 PM Thread Starter
Here it is! This is the 1326 page 14.4Mb Diagnostic Manual. This is not the FSM, which is already a sticky, only the DI section of it that's not included in any link and hasn't been available until now. It includes complete, easy to read troubleshooting for all major systems on all years of the IS300. It also contains part numbers(for parts and SST's), the complete wiring schematics and electrical troubleshooting, TSB's, and much more. It also contains all major codes(DTC's), the definition of them, and an easy guide on how to repair the fault(s). It's the same manual Lexus uses and I constantly reference it when helping out on here. Enjoy!
https://www.dropbox.com/s/nji5xr398l...anual.pdf?dl=0
Here's some pin outs for the loose connectors in the ECM box.
https://my.is/forums/f87/ecu-body-har...5/#post7002209
Last edited by jasonm4; 07-08-2017 at 09:57 PM. Reason: broken link fixed-permanent
post #2 of 24 (permalink) Old 10-15-2011, 02:09 PM
AMAZING manual! This looks JUST like alldata -- but it has WORKIGN hyperlinks!!
antISanISfreak is offline
post #3 of 24 (permalink) Old 01-27-2012, 11:25 AM Thread Starter
OP link fixed again. Should be good for awhile now. Please lemme know if it's down again and i'll re-host it.
post #4 of 24 (permalink) Old 02-22-2012, 11:06 AM
Nice! Another good manual to accompany my old Service Manual PDF. Thanks.
-Eric
"Dammit, where are my driving mocassins?!"
SOLD: '01 SY SRT 2.75
mixtnutz532 is offline
post #5 of 24 (permalink) Old 08-14-2012, 08:46 AM
This is Greatly appreciated,are their other manuals available for 02 IS300.Its getting to the age of project time of PMs and some needed replacement work.
caseybphx is offline
post #6 of 24 (permalink) Old 08-14-2012, 08:58 AM Thread Starter
No problem. Check the first gen Showroom forum for FSM. I just updated it not too long ago, so there's a link i have added in the OP to a download page.
post #7 of 24 (permalink) Old 10-09-2012, 08:33 PM
I'm in the same boat as caseybphx. Greatly appreciated.
BTW, what does FSM stand for? Full Service Manual?
chashsportx is offline
post #8 of 24 (permalink) Old 10-09-2012, 09:15 PM Thread Starter
Factory Service Manual. The 1300+pg diagnostic section download is just the DI portion of it.
post #9 of 24 (permalink) Old 05-06-2013, 09:57 AM
wingzero's Avatar
Quoted: 17 Post(s)
Jason, do you know if there is a diagnostic manual for the Body? I'm throwing some B-codes, specifically B1421, B1423 and B1411 and I'd like to read up on them.
Looking to do an Aristo swap?
Aristo Swap with IS ECU
Aristo Swap with Aristo ECU
wingzero is offline
post #10 of 24 (permalink) Old 05-06-2013, 10:11 AM Thread Starter
I believe the diagnostic manual is actually much larger than what is hosted here and may have body codes. I believe there is some in the link here but not many. The FSM covers some of this but not code related. I can tell you...
B1421 is solar sensor malfunction(driver side bubble). FSM shows what the voltage should be and how it fluctuates.
B1423 is open in pressure sensor circuit/abnormal refrigerant pressure. Sensor located in front of radiator/driver side.
B1411 is Room temperature sensor circuit malfunction(located on the driver side and behind panel below steering column.
Now you could use the FSM's specs and see what you have at sensors. Almost sounds like you have some opens. Here's the indexed FSM which you probably have. http://db.tt/xmQ2dI4r
post #11 of 24 (permalink) Old 05-06-2013, 10:18 AM
wingzero's Avatar
Quoted: 17 Post(s)
Roger that...I'll read the entire Air Conditioning section.
Thanks bro!
wingzero is offline
post #12 of 24 (permalink) Old 06-30-2013, 04:41 AM
Mile30's Avatar
I just bought an '05 yesterday; getting a copy of the full fsm was/is a high priority; so thanks for the download!
Is there a good place to get a paper copy, or did the mfg go 'all-electronic' with this one?
Mile30 is offline
post #13 of 24 (permalink) Old 07-08-2013, 09:11 AM
thanks for sharing this. Just picked up an 02 and this will come in handy.
fortillian is offline
post #14 of 24 (permalink) Old 01-28-2015, 02:51 PM
the link says from 2002-2005.................Are these the same for the 2001? Im going to attempt to wire in my aemv2.....any help on what schematics and where to find them that are needed is GREATLY appreciated.
thanks
gabe
also, can I get the "wiring for dummies" version please this is my first Toyota/lexus
nIStwoJZ is offline
post #15 of 24 (permalink) Old 03-24-2015, 02:35 AM
Thank You! This will absolutely be useful.
Buddro is offline
NEW STICKY/Download! Lexus IS300 complete Diagnostic Section. jasonm4 General Discussion 15 10-05-2011 04:23 PM
Download reopened-2 days only! IS300 complete Diagnostic manual jasonm4 IS300 Owner's Forum 17 09-28-2011 01:31 PM
Anybody have the 'DI' Diagnostic part of the service manual for an 02? ISwagon IS300 Owner's Forum 7 06-27-2011 03:00 PM
Anyone know where i can download the Electrical Manual for the is300 disonesaplaya Basic Help & Repair 3 10-06-2009 02:45 PM
ISx50 diagnostic manual.....? roe74 Mobiletronics 0 02-02-2007 12:03 PM
