IS300 P0161 or P0141 o2 Heater Malfunction FREE Fix - Lexus IS Forum
post #1 of 39 (permalink) Old 10-06-2007, 02:32 PM Thread Starter
Thanks to my.is member dasgalloway for this picture and sophiesleeps for the original tutorial this was based off of.
Originally Posted by dasgalloway View Post
In one simple picture.
SophieSleeps had posted this a while back with wiring diagrams, thought I'd follow up with a picture since I fixed one today. To confirm, all we did was cut/tap 1 wire to another.
Image shows what to do to fix a P0161 CEL on a 2002+ Is300.
To fix a P0141 (B1S2 Heater malfunction), all you have to do is switch which wire is cut and which is tapped, so instead of cutting red and tapping to green, you cut green and tap to red.
Enjoy!
Cobra Project:
longnights is offline
post #2 of 39 (permalink) Old 11-10-2007, 11:12 AM
Is there a 2001 diagram?
rlee is offline
post #3 of 39 (permalink) Old 12-28-2007, 08:48 AM
I'll do this, but I guess my question is what are the downsides to this? Will the O2 sensor wear out quicker due to not having the proper heating? Doesn't heat play a major role in the accuracy of this meter (that's not really a question since it does )?
Anyone list some downsides/side effects?
03 Charcoal Grey IS300. Stock, but will be turbo when funds are available.
443whp turbo LS Intergra
I tune all Honda and DSM systems. Will be doing 2JZ's shortly.
adseguy is offline
post #4 of 39 (permalink) Old 01-07-2008, 08:10 PM
So where is this cable located?
bluealteza is offline
post #5 of 39 (permalink) Old 01-16-2008, 09:58 PM Thread Starter
under the hood, under one of the plastic covers
Cobra Project:
post #6 of 39 (permalink) Old 02-03-2008, 08:56 PM
What if both are having heater malfunctions? :|
'02 TCM IS300T 14PSI - Powered by ProEFI128 Ecu
Rebuilt with ARIAS Pistons, GTE Headgasket, ARP Studs
18" Volks Gt-7 | Swift Springs | Tokico Illumina | Magnaflow | JDM Visors | JDM Tails | OBX Sidemarkers
Nikon D3000 18-55mm, Nikkor 55-200mm.
dangishchris is offline
post #7 of 39 (permalink) Old 05-01-2008, 10:39 AM Thread Starter
you need to be able to tap into one or the other, if both are malfunctioning than you need a new o2 sensor.
Cobra Project:
post #8 of 39 (permalink) Old 07-11-2008, 05:50 PM
I have it tapped the same exact way you have in the picture. However, the only code I'm throwing (with o2sim installed), is P0141. So I removed the B1S2 o2 sensor connect and used a resistor there instead to simulate the heater signal. I got the same code still. This time around, I spliced the actual wire and tapped the resistor into the heater wires instead of on the connector. I won't know if this will fix it but will have to drive a day or two to find out.
I was wondering if the method I'm doing is correct? It's the only code left. I used to have a lot of codes but the O2sim took care of those.
98 Toyota Camry LE V6 4AT S/C
02 Lexus IS300 GGP 5MT
bustarice is offline
post #9 of 39 (permalink) Old 11-16-2008, 08:50 PM
I Dont Understand
I checked the code today on my 2003 Lexus IS 300 and I got code p0037. Everwhere it says that's bank 1 2nd o2 sensor. That's the one closest to the front of the car, not the firewall, but on this site it says p0041 is that sensor, bank1 sensor 2. So what is p0041 and code I'm getting? What is p0037 then?
mclean987 is offline
post #10 of 39 (permalink) Old 11-26-2008, 03:32 PM
I have a P0161 on a 2001. I would like to do the above fix, but it specifically states 2002+ in the OP (original post). Is there a fix for the 2001 model?
desidude is offline
post #11 of 39 (permalink) Old 04-08-2009, 02:18 PM
Bump
I have the bank1 sensor 2 failure on 2001 IS 300, too..
Will this trick work for the 2001 model? =)
Thx
kevinl is offline
post #12 of 39 (permalink) Old 04-08-2009, 03:32 PM Thread Starter
Originally Posted by kevinl View Post
Bump
Thx
The same concept can be applied to the 2001, however, the harness is slightly different. You want to tap the b1s2 heater signal to the b2s2 heater signal. Use this diagram for which wires those are:
Cobra Project:
post #13 of 39 (permalink) Old 06-01-2009, 03:23 PM
Is this a permanent fix?
....2001 LEXUS I300 MSM E-SHIFT....
IS300Inline6 is offline
post #14 of 39 (permalink) Old 06-09-2009, 02:10 PM
I'm seriously contemplating doing this for short-term fix to get an inspection sticker (P0161 B2S2 Heater Circuit DTC failed), but I would never want to leave it like this long term... There has to be decreased O2 sensor life...
Signature goes here.
lextasy23 is offline
post #15 of 39 (permalink) Old 06-27-2009, 02:12 AM
Oooooh oooooh oooooooh, I got a quick fix... when you find those two wires (and, yes, this is serious) just cut up any extra wires you have in your garage (if you're like me and have extra wires everywhere) and just stuff it in each pin socket... it still transfers the same amount of energy (I honestly didn't think it would but it did). I did this the day before I got my smog check and i actually STILL have it in the way I described... don't cut your wires ,especially if it's gonna be temporary.
IS300 Project Underway
NOOOOOOOOT...
my project died
FS THREAD
blakaraknyd is offline
What's this? Code: P0161 - 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2) Wings65288 IS300 Owner's Forum 12 01-09-2011 11:59 PM
P0141 and P0161 jamian240 General Discussion 0 10-04-2007 10:47 AM
P0161 Code O2 Sensor Heater SweetSiren Basic Help & Repair 6 06-09-2006 03:20 PM
Engine code: P0161 Heater circuit malfuntion MiamiIs300 Basic Help & Repair 1 05-11-2005 05:32 PM
HTML code is On
