Been in love for over a month now. 03 auto - Lexus IS Forum
  • 1 Post By Jaydee.AZ03
post #1 of 4 (permalink) Old 05-22-2019, 08:40 AM Thread Starter
Names Jeremy you can call me "Jerm" If you'd like. I didn't have much growing up with the life I was givin and I've worked hard for everything I've ever had or own to this day, and this is by far the best vehicle I've ever purchased..
I'll be honest, I've owned almost all hondas/Acuras (other than a wrangler and a ranger) and was into those growing up from 15. After building/owning those for almost 4-5 years, plus having the last Integra I owned stolen twice, I knew it was time to move on for good!
I never even intended for my next car to be a lexus nor have 2j (even if it's a ge)
But I did need something with 4 doors since I have a 1 year old, and I love driving, love being on the road, being able to look good doing it and also love to photograph where I go and what better way than to put a beautiful is300 in that picture.
About the car
Got my 2003 auto with 227k on chassis and 107k on motor and trans. Their are a few minor things wrong but all together and for what I payed for I think she was a great buy. On lowering springs (unknown brand) with tsw wheels. Other than that, a aftermarket double din radio, and tint, it's completely stock.
Seller was asking 3800. First things I noticed on first time inspecting vehicle myself is
a small crack in windshield not obstructing my view,
previous owner did a horrible job on the Fenders while rolling them so one has a noticeable dent,
The back tires were shot with camber wear,
When checking plug wires and plug well, noticed a tiny bit of what looked like oil residue but not much work didn't think too much of it,
And the front driver seat did not move forward or backward yet up down, and backrest would work.
Ended up offering him 2800 because of all those small issues and he did not want to except anything less than 3k. But showing 2800 all in 100s in front of his lady and him selling it due to financial issues, she told him to basically.
But how hard was I fooled?
So first thing I had to battle with, seriously from the third night I owned it, the front driver headlight is a lot dimmer at first then will turn off after a minute or two of being on and if I cycle the light, it comes back on yet turns off again. I was thinking ballast. But after talking to someone on a Facebook page, they said the bulb could be loose or just going out and needs a new one. The housing to get to the bulb seems kinda loose. Is that causing the issue or the actual bulb possibly? Haven't tooken headlight off to look. And I also had a problem with running brake light fuse blowing and after not being able to locate the ground and reading a forum from my.is, realized someone had the same issue told met on checking on top of exhaust near rear bumper and blam, fixed it. But then, driver side trunk running light isn't on but when I brake it does work?
And also, After owning the car for a month, one day randomly I was cruising like normal and cel came on with Trac off flashing.
I was nervous at first because I know lexus is known to be a luxury brand and to be somewhat pricey, but I tend to do most things requiring labor on a vehicle myself. And after looking into it, found the cause was oil had filled the plug wells pretttty good. And after that, away I went with the order. Did valve cover gasket job with plugs and wires and solved it. No more cel, and power was back with more it seemed.
Anything else I should look out for?? I do notice my front sway bar links seem to need to be done soon. I sometimes hear a clanking noise from front end when hitting bumps in the road.
Lastly, sometimes when going 45 or so and I give it too much gas, I think when it downshifts, theres a thud coming from the rear end or tranny and it's not the tranny mount I don't believe because going from park to reverse to drive it doesnt do it when warmed up. But if it warmed up and I give it gas like that it does. Tranny fluid looked new practically when I bought it and I've put about 1k miles on the car and fluid is dark. Not black but dark redish to almost getting black. After driving for longer period I checked the fluid after cooled off for like 20 minutes and it has a slight burnt smell so what's that mean 😣😣
ID:	124399   Click image for larger version
ID:	124401   Click image for larger version
ID:	124403   Click image for larger version
Mathieu Bernier likes this.
Jaydee.AZ03 is offline
post #2 of 4 (permalink) Old 05-22-2019, 12:39 PM
Quoted: 141 Post(s)
Welcome to the forum Jeremy, nice car.
The clunking in the front end is most likely lower ball joints. Those and the No. 2 control arm bushing are one source of hurt to the wallet when you first buy a high mileage 1st gen. The control arm causes bad tire wear, so those rear tires were probably on the front at some point.
Piggity is offline
post #3 of 4 (permalink) Old 05-23-2019, 02:46 AM Thread Starter
Thank you! And exactly what I had figured I failed to hear those noises while test driving the car before buying, but i do know that with a high mile chassis, comes lots of other work besides mechanical. I gotta get on those ASAP!
post #4 of 4 (permalink) Old 05-23-2019, 03:34 AM
Quoted: 36 Post(s)
Welcome in the happy world of IS300, Congrats for the find, this will be the begin of a long love story
Color: Cromax YR580M
TRD Carbon Fiber Shifter Ball
Fidanza Exhaust Cam Gear
SPC Rear Camber Kit
Continental ProContact Tires
Mathieu Bernier is offline
  Lexus IS Forum > Lexus IS > New Member Introductions
My love for IS300's jesuspuppy General Discussion 8 04-08-2019 03:54 PM
Need help with css/nss on a auto to manual car NickNa-t General Discussion 7 05-02-2018 04:32 PM
Start up high idle seems short duration, low rpm IS300 2002 Auto greasemonkey2 General Discussion 3 11-09-2017 06:22 PM
Doing some auto trans work/ tuning next month tngazazel Go Faster 7 06-29-2017 09:14 AM
aristo 2jzGTE vvti paired with is300 auto trans? tngazazel Go Faster 4 02-25-2017 02:10 PM
